Old Mar 04, 2009, 03:27 PM
DCT1 is offline
Find More Posts by DCT1
DCT1's Avatar
Joined Oct 2008
Question , can you run Nicad/Nimh battery setting using Lipo 3 cell batteries?
Yep that's right, I need to know if I can use my Thunderbird-18 esc settings with Nicad/nimh but run 3 cell lipo battery? Why you ask,, I can't get my new motor to run on there firm ware 1.05 that will let me set low volt cutoff .
The motor runs great with firm ware 1.03 but it doesn't have settings for battery low volts.
I would rather kill a battery then my scale airplane hitting low volt cutoff . Oh yes I use a timer , but you can't hear it when there are big gas airplanes flying all over you!
Anyone ever do this?
DCT1 is offline Find More Posts by DCT1
Old Mar 05, 2009, 11:29 AM
lestingoy is offline
Find More Posts by lestingoy
Lee Estingoy
Overland Park, Kansas, United States
Joined May 2003
If you can wait another few weeks we'll have the software update out that brings the motor run improvements from the Phoenix beta release to the Thunderbirds.
Should solve for your concerns.
You can always set a lower cutoff voltage than you need, like 6 volts or such and the controller won't ever auto shutoff.
Lee
lestingoy is offline Find More Posts by lestingoy
Discussion Question, can you use Nicad battery setting running Lipol batteries? DanT Power Systems 4 Mar 05, 2009 07:41 AM
Discussion Newbie question: Can you charge a half used battery? GetterDragun Batteries and Chargers 5 Jul 27, 2008 11:23 PM
Discussion can you run rx of flight battery ldub Power Systems 2 Jul 03, 2007 02:29 AM
CBA test question? If you run a battery test, does it destroy the battery? 2dogrc Batteries and Chargers 18 Sep 08, 2005 02:38 PM
Can you run a 8xcp1300 pack on a s400 motor? Ripley Power Systems 3 Jul 11, 2002 01:09 PM
