Old Mar 04, 2009, 02:16 PM
Willmsy is offline
Find More Posts by Willmsy
I am the BBQ Ninja
Willmsy's Avatar
United States, MN, Woodbury
Joined Jan 2003
Build Log
F-9F Panther/Cougar build logs Mk.I (70mm)
Well here I go again, starting something new before I have the last one done! Actually I have had a little extra time at work lately and it makes me look busy.
I am starting with the Panther and then I will probably go to the Cougar. I am also looking to people for help on setting up the proper airfoils. (I have no clue on those)
Here are a couple of screen shots of what I have so far.
Willmsy is offline Find More Posts by Willmsy
Old Mar 04, 2009, 02:36 PM
eatond is offline
Find More Posts by eatond
EDF Jet Jam 2015, May 28-31st
eatond's Avatar
United States, MO, St Charles
Joined Nov 2002
Hi Will,
shucks, I was hoping you'd give the L-39 a try. Is this going to be for 70mm or 90mm?
Dan Eaton
eatond is offline Find More Posts by eatond
Old Mar 04, 2009, 03:17 PM
jrb is offline
jrb
Find More Posts by jrb
jrb
Member
jrb's Avatar
Edina, MN, USA
Joined Oct 1999
Cool Matt!
Have you heard Mundt's story?
jrb is offline Find More Posts by jrb
Old Mar 04, 2009, 03:25 PM
Lear45 is offline
Find More Posts by Lear45
Omaha, NE
Joined Jun 2004
Looks good so far. Scale size inlet ducting then?
Jim
Lear45 is offline Find More Posts by Lear45
Old Mar 04, 2009, 03:29 PM
Willmsy is offline
I am the BBQ Ninja
Willmsy's Avatar
Joined Jan 2003
Dan, don't lose hope, this one is going to help me get to the L-39. And this is for the 70mm and I may scale it up to the 90mm.
jrb - I think I have heard his story.
Lear45, yes scale inlets.
Old Mar 05, 2009, 11:23 AM
Willmsy is offline
I am the BBQ Ninja
Willmsy's Avatar
Joined Jan 2003
Here is a little more progress, I put in the "Mock" wings in to get a feel for the size and angle that the wings are sitting at in my 3-view. At the moment I am a touch over 38" wingspan and I don't have the tip tanks on yet. I plan on tackling the tail today. I am going to stay away from flat basla stock that I have used in the past for control surfaces, Humidity plays havoc with them. On with the picture show.
Matt
Old Mar 05, 2009, 11:43 AM
Larry Dudeck is online now
Find More Posts by Larry Dudeck
Larry Dudeck's Avatar
Williamsville, NY, USA
Joined Sep 2000
It is so refreshing to see a scratch build. In this day and age of overpriced, foamie junk ARF's, the ability to roll one's own is a fast disappearing talent.
The F9F has been a favorite. Attached is my 48" WS F9F, 75mm Ky fan, HET2W, 3Sx4400 LiPo, 200+ flights
I will follow this thread. Good luck with your build.
Larry Dudeck is online now Find More Posts by Larry Dudeck
Old Mar 05, 2009, 04:30 PM
Willmsy is offline
I am the BBQ Ninja
Willmsy's Avatar
Joined Jan 2003
Looks like this is as far as I am going to get today. I made some really good progress and now I need to think about what types of wood for this baby!
Old Mar 05, 2009, 06:26 PM
Joined Sep 2000
If it were mine - 1/8th formers, 1/16th ribs, 1/32nd sheeting, 1/8 x 3/8 spruce longerons, 3/16th stringers
all balsa
Old Mar 05, 2009, 09:38 PM
AIR SALLY is offline
Find More Posts by AIR SALLY
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
i started a depron F-9 a couple of years ago ..70mm with retracts ...aft fuse comes off to service fna ...about 75% done .....do a serch for depron F-9 panther.lots of pics in the thread.
AIR SALLY is offline Find More Posts by AIR SALLY
Old Mar 06, 2009, 02:47 AM
gghisleri is offline
Find More Posts by gghisleri
gghisleri's Avatar
Joined Apr 2004
I have a little Panther with a 65 Vasafan.
Flies very well with S6061.
By the way this is a wing section I use on aerobatic slope sailplane.
gghisleri is offline Find More Posts by gghisleri
Old Mar 06, 2009, 03:45 PM
Willmsy is offline
I am the BBQ Ninja
Willmsy's Avatar
Joined Jan 2003
Got a bit of the nit picky stuff done today, still have alot of nit picky stuff yet to do. I am getting closer to wanting to see it laser cut. As if I didn't have enough with the other planes I NEED to get done soon. On with the picture show.
Matt
Old Mar 06, 2009, 04:10 PM
hul is offline
hul
Find More Posts by hul
hul
hul's Avatar
Switzerland
Joined Mar 2003
looking good.
I think you could move the fan back a bit, it looks nose heavy. That would give you more room for the ducts. Try to avoid the sharp corner on the outside of the ducts just before the fan, more S-shaped would help. Attached is a picture of the ducts in my Hunter: http://www.rcgroups.com/forums/showthread.php?t=950537
Don't think airfoil really makes that much difference. I use the S3021 on all my small stuff, incl. the Hunter above.
Hans
hul is offline Find More Posts by hul
Old Mar 09, 2009, 04:58 PM
Willmsy is offline
I am the BBQ Ninja
Willmsy's Avatar
Joined Jan 2003
Well I got a good amount of stuff done with the tail and adding an extra body former... I still have to work on the openings for routing the wires and whatnot, but I think I am getting really close to getting a final set of files ready. I moved the Fan back and worked on the tail, I still have a little bit to do there.
Matt
Old Mar 09, 2009, 11:42 PM
BOB MOORE is offline
Find More Posts by BOB MOORE
Texas
Joined Dec 2007
F9F Panther/Cougar build logMk1(70mm)
I worked on the Panther and Cougar when I was with the Blue Angels in 1952
1954. I also worked on the F7U1 in 1952. I have a 90mm Panther now. Will you have plans on these planes
BOB MOORE is offline Find More Posts by BOB MOORE
Discussion Grumman F-9F Panther for EDF-40 Esprit440 Micro EDF Jets and Power Systems 292 May 31, 2012 09:32 PM
Build Log F-18 Blue Angels Formation Flyer Beta Test build log (video added) Joe 1320 Pusher Prop Jet Models 230 Dec 04, 2010 04:53 PM
Build Log ISR F-86 Build Log Brian Koester Slope 364 May 31, 2007 02:23 PM
Careful! F-20 Utube Video Build Log Chief High Horse Slope 1 Nov 12, 2006 11:06 PM
Discussion Aeronaut Panther F-9F slightly shipping damage wbs Electric Ducted Fan Jet Talk 21 Feb 25, 2006 10:42 PM
