| RCCars | Crack Roll | Flying Giants | RC Power | The E Zone | Lift Zone | Our Sponsors | |||||||||
#16 |
1.21 gigawatts
I rudder Mod both L39s one with CA hinges and the other with robart hinges
#17 |
TEAM EJF
I got Mine!!!
Guys,
I got mine in today and will start building. Here is the first mod I did. I got the idea from someone on the other L-39 thread. http://www.rcgroups.com/forums/showthread.php?t=929931 |
#18 |
1.21 gigawatts
here is my wing Mod to increase speed and flying time
#19 | |
1.21 gigawatts
those are nice think I,ll get a pair
#20 |
TEAM EJF
Hey Eddie,
Once I open up the wing for the retracts is there any building needed? Or any recommendations for sturdying them up? And lastly, what replacement wheels would you suggest. I dont want to use the stock ones. Thanks for any help. James PS...Any one have pictures of were they are putting batteries. Are you going to use 1 large battery pack 3700 mah or higher, or 2 2200-2500 packs?? I am also going to run a A123 rcvr pack about 1100-1500mah. But just wanted to get some idea for battery placement. Thanks guys. Last edited by lashmett75; Mar 18, 2009 at 11:55 AM. |
#21 |
1.21 gigawatts
[quote=lashmett75]Hey Eddie,
Once I open up the wing for the retracts is there any building needed? Or any recommendations for sturdying them up? And lastly, what replacement wheels would you suggest. I dont want to use the stock ones. James go over it with thin CA and thick CA all over the retracts mounts and ribs ,I,m using parkzone TYPHOON 3D wheels for the mains and the stock wheel for the front ,,one of my favorite fields has a grass runway,,for the Lipo I used Velcro stuck to inside of the nose with two glued acros will post pics when I get home |
#22 | |
TEAM EJF
[quote=EDDIEGIGOWATTS]
Thanks for the info. I look forward to the pictures. tonight I am going to tackle the elevator setup, and edf unit install. James |
#23 |
Front retracts.
Hey, Eddie I hate to ask but do you have any pictures of the front retract install. I'm guessing the center of the braced area in front of the rib. Did that work well on the prototype?
#24 |
1.21 gigawatts
here is some pics of the prototype and Lipo velcro set up,,
give a minute to post pics of the new set up |
#25 |
Thanks, Eddie what size front wheel is that? I need to use as tall as possible. I was thinkin one of the stock backs on the front and typhoons on the back is that what you did?
#26 |
1.21 gigawatts
that's a MPI wheel 1.5" very fragile ,,I have a another set for the front
I am not sure what they are let Me post pics of them will like to get the same set for the rear they are nicer ,,the TYPHOONS have to be turn down with a dremel with a sanding drum to fit the wheel wells,, also you have to CA them or they will fly off,,they are very light |
#27 |
1.21 gigawatts
here is how I balance my fans if they are out of balance,,
I used a 3 cell LIPO for the test, take maskin tape ,,stick it to a glass table make it thick as a match book cut it in to small squares then you take your fan flip the rotor over to a pusher configuration mark it ,hold the fan and run it till you feel vibrate take a piece of square put it on one of the slots run it again, if it vibrates move the square in to another slot,, by moving it around you will feel the vibration increase or decrease,you can add more or take off till it runs smooth, once you're are satisfied flip the rotor over and run it again if it vibrates twist the rotor or the spinner you can also do this with out flipping the rotor over by adding a piece to the spinner and moving the spinner around NEVER RUN THE FAN FULL THROTLE unless is installed bench or fuse I can balance 10 rotors in less the 15 minutes perfectly like this for Me the balancers are a waste of time especially with small rotors I got the idea when I watch my friend balance race car tires on a lift Last edited by EDDIEGIGOWATTS; Mar 19, 2009 at 09:08 PM. |
#28 |
1.21 gigawatts
when looking from top ,,both of the L39s 3500 4 cells sit almost in the middle of the canopy opening ,,also here is a pic of the front gear cut out
#29 |
1.21 gigawatts
the blue L39 sits up too high ,,cut the gear opening that matches the belly pan
my guess is that the lower one is for scale gears,the plane was too wobbly I didn't use the wire springs on the rear |
#30 |
First off, thanks Eddie for putting up these pics, helpful.
Question, I am outfitting my L-39 for maximum speed (Hoffman Wild Beast, wemotec fan, CC 125 esc). Do you think the stock control clevis is sturdy enough or do you know of a better one? I know I need to get everything as slop free as possible. Thanks Z |
| Thread Tools | |
| Build Log Large 70 to 90mm Fan SAPAC JAS-39 build and first test flight video | EDDIEGIGOWATTS | Foamy EDFs | 1636 | Nov 17, 2009 05:18 AM |
| Bleroit III test flight | Rocksnake2 | Parkflyers | 8 | Sep 22, 2001 01:44 PM |
| Test flight: Zagi 36" | Al P | Foamies (Kits) | 2 | Sep 08, 2001 08:34 AM |
| Mini Ellipse E & Hacker B20L test flight | Ron Williams | Electric Sailplanes | 6 | Jul 25, 2001 03:08 AM |
| Adrenalin test flight report | Erik Johansson | High Performance | 5 | Jul 02, 2001 04:58 PM |
