| RCCars | Crack Roll | Flying Giants | RC Power | The E Zone | Lift Zone | Our Sponsors | |||||||||
#1 | ||
1.21 gigawatts
Sapac L39 test flight and build pictures
Hi everyone I test flew one of the new L39s that I built
all I can say the performance was awesome for a stock 70mm bird if you took a look at this plane you would think a 70mm EDF is too small it had plenty of power ,,speeds where around around 125 mph or more I was a little skeptical about the scale wing ,it looks kind of small because other RC L39s out there have over size wings like pylon planes to help with the wing loading well I was wrong the planes wing loading was rock solid like the T45 hawk it couldn't be any better ,,and to top it all off ,, the fans impeller was damaged with 2mm of small chunks missing from all the blades,,it happened when I ran the fan before test flight,I didn't tightened it hard enough and the impeller lodge its self in to the intake,didn't have another one, I had a 15 to 20 mph cross wind take off was no problem got some small vids here is the power set up motor Sapacs new black tornado 3200 kv out runner =1055 watts 75 amps installed battery Sapac new black tornado 25c 3500 4 cell Lipo retracts Sapacs ESC castle 80 servos HS55s ailerons and flaps and rudder + steering and valve HS56 on elevator
#2 |
Soviet Aircraft nut !!!
Excellent!!! I knew it would fly well. Is the factory ch spot on or.....???????
#3 |
1.21 gigawatts
if youre talking about the CG,, don't know what the factory calls on the CG
this was a kit that was missing lots of parts I just got a production model from Mike let Me compared them and I have also lots build pictures |
#4 |
Ok! Oops type-o there. I meant CG. But you knew that.
#5 | ||
1.21 gigawatts
OK the CG on mine is 60mm from the leading edge of the wing
the plane was a little nose heavy Lav here is the a end
#6 |
did you use flaps on landing or take off?
#7 |
It looked good. This 70mm version is quite a bit larger than my k&a composite l-39. So I bet even with a lot of watts ie...1400-2kw it will hit a wall at some point with speed.
Yours looked good. No flutter? No problems?? Hope not. Than that is a big plus. |
#8 |
1.21 gigawatts
Lav couldn't imagine 1400 watts ,it flys with plenty power and vertical at 1075
I thought I was going to get flutter on the elevators ,because this one had a carbon rod system to link both elevators,the new one has a metal rod 200% better also this plane sit,s up tooo high ,I will lower it about a 1/2" and move the wheel wells apart so the wheels drop in,,next time I,ll try the flaps |
#9 |
Up and at 'em F-35
Sweet.
Nice to see a plane with scale wings flying so well. Steve C |
#10 |
This think looks great. Do you think it would fly off of grass with the retracts or would it be better to bungee and belly land it or neither?
#11 |
keep the videos coming! Cant wait to see more of this great plane. Flaps should make a big difference on the landing speed , i hope!
#12 |
EDF Nut
Faster than I expected and that's a good thing! Looks very stable.
Got a radar gun? |
#13 |
Eddie it was good to meet you today at FLJETS. Thanks for all the info. I'll need more and I'm looking forward to you posting the build pics we spoke about. If I don't stay home and build this thing while your still in Lakeland.
#14 |
1.21 gigawatts
Ok here is some build pic,s of the prototype and the V1 production L39
#15 |
1.21 gigawatts
I used a HS56 for the elevator
| Thread Tools | |
| Build Log Large 70 to 90mm Fan SAPAC JAS-39 build and first test flight video | EDDIEGIGOWATTS | Foamy EDFs | 1636 | Nov 17, 2009 05:18 AM |
| Bleroit III test flight | Rocksnake2 | Parkflyers | 8 | Sep 22, 2001 01:44 PM |
| Test flight: Zagi 36" | Al P | Foamies (Kits) | 2 | Sep 08, 2001 08:34 AM |
| Mini Ellipse E & Hacker B20L test flight | Ron Williams | Electric Sailplanes | 6 | Jul 25, 2001 03:08 AM |
| Adrenalin test flight report | Erik Johansson | High Performance | 5 | Jul 02, 2001 04:58 PM |
