Old Mar 19, 2003, 10:09 PM
rparigoris is offline
Find More Posts by rparigoris
Kings Park, New York, USA
Joined Sep 2001
How do you measure Static Amps? Within 5 seconds of a fresh charge or?
For instance Astro Bob told me to prop static for no more than 18 amps. is that 18 amps for the first few seconds on a fresh peaked pack, or after 10 or 15 seconds or after 30 seconds or 45 seconds?
I have a AF020 7T with a superbox.
Anyway with 8 CP1700SCRs and a 11x8 Graupner cam Folder
On a fresh pack i get 20.8amps static for a very short time
After 15 or 20 seconds down to 17.7 amps and goes lower from there.
Ron Parigoris
rparigoris is offline Find More Posts by rparigoris
Old Mar 20, 2003, 02:47 AM
steve lewin is offline
Find More Posts by steve lewin
N. Staffs, UK
Joined Jan 1997
In terms of the value that the motor can stand, I usually count it as the current after around 30 sec running. It will stay close to the value for most of the run. It's a bit tricky to measure though because I don't like to run the system for much more than 30 sec static (i.e. with no air cooling etc) so I have to be quick .
The absolute peak value for a second or two on a freshly charged pack isn't really of much interest.
Steve
steve lewin is offline Find More Posts by steve lewin
Old Mar 20, 2003, 09:39 AM
Fredrik W is offline
Find More Posts by Fredrik W
Fredrik W's Avatar
Stockholm, Sweden
Joined Jul 2002
When I do my motor tests I start take readings after 1/6 of the batterys capacity has been used. This to avoid the initial peak of the pack.
// Fredrik Wergeland
Sweden
www.flyingmodels.org
The Great Electric Motor Test
Fredrik W is offline Find More Posts by Fredrik W
Old Mar 20, 2003, 10:30 AM
hoppy is offline
Find More Posts by hoppy
Space Coast USA
hoppy's Avatar
Space Coast
Joined Oct 2000
You can always let the battery sit overnight before testing...or
You can run the motor at 1/2 power for several minutes before testing at full power......or
If you have some foam cutter wire, you can bleed off some of the battery energy by using a 12-18" piece of that wire across the battery terminals.
It takes about 1 min of full throttle to get the battery on the "level" part of the discharge curve.
From your description, looks like you are OK. Remember, a hot battery, hot off the charger, can put out quite a bit of juice for a short time as compared to a cool battery that has set for awhile.
hoppy
hoppy is offline Find More Posts by hoppy
Discussion How do you measure motor Amps missle Beginner Training Area (Aircraft-Electric) 10 Dec 30, 2006 07:43 PM
How do you measure AMPS with a multimeter? DsWright Power Systems 6 Dec 05, 2004 06:55 AM
How do you measure engine/prop thrust? Slow Riser Power Systems 0 Jul 30, 2002 07:19 PM
How do you measure thrust epilot Scratchbuilt Indoor and Micro Models 2 Dec 24, 2001 01:50 PM
How do you measure motor contstants? Aero-BearAZ Power Systems 4 Jul 19, 2001 11:33 AM
