Old Mar 02, 2009, 02:30 AM
Heritic is offline
Find More Posts by Heritic
Portchester Nr Portsmouth, Hampshire UK
Joined Nov 2006
Hi-Tec 500 Gyro tail end points
I have partly set this up but have set too little tail blade end point travel.
I cannot find out how to re-set the gyro for this.
Could someone please advise.
Also in normal mode (set to -25% Spectrum 7) REAL floaty back end.
Fairly ok in HH - though feels quite different to my Gy401's
AND typically what horn length to use mine is 12mm.
Cheers
Heritic
Heritic is offline Find More Posts by Heritic
Old Mar 02, 2009, 09:32 AM
dan c is offline
Find More Posts by dan c
EVOL OT YLF
Weston-s-Mare Uk
Joined Nov 2008
You should be able to just reset it. Put the rudder travels back up to max, and just reset it. Theres a really good video on Helifreak on the setup. It's on Finless Bob's heli freak Techroom. Check it out, it helped me noend when setting up my Logictech 2100t, as it's pretty much the same gyro.
Dan
dan c is offline Find More Posts by dan c
Old Mar 02, 2009, 02:00 PM
RMG2 is offline
Find More Posts by RMG2
RMG2's Avatar
Oregon, USA
Joined Dec 2007
Cheers
Heritic
You do realize the Hitec5000 has independent left and right travel adjust don't you? You have to work pushing the button in the correct order to make it function properly.
My Hitec5000 requires really high gain settings.
Set it up mechanically so it holds in rate mode first. Then set your left and right end points for max travel without binding. Setup like this my 5000/5083 holds dead perfect in both rate & HH with no adjustment to either!
Don't forget to turn the rudder travel volume in your TX all the way up to 150 (whatever a DX7 has) both directions.
My ball is setup at 10.5mm on the servo arm.
Have you watched Bob Whites setup video for the 5000?
http://www.helifreak.com/showthread.php?t=68319
RMG2 is offline Find More Posts by RMG2
Old Mar 03, 2009, 07:38 AM
Heritic is offline
Joined Nov 2006
Brilliant thanks both
Heritic
Discussion HI -Tec 5000 Gyro Combo Heritic Mini Helis 4 Feb 26, 2009 02:20 AM
Discussion Std mini Titan 401 gyro Hi-Tec HS5425 mini Heritic Mini Helis 11 Jun 20, 2008 07:26 AM
Discussion Hornet FP - gyro -tail end not locked Heritic Micro Helis 6 Jul 14, 2007 05:45 AM
Discussion slow tail servo with end points / anyone know how to stop? djdaveq Micro Helis 12 Apr 09, 2006 11:44 PM
End points for Corona Tail Servo gregw Electric Heli Talk 2 Feb 21, 2003 11:33 AM
