Dennis,
Something is fishy ! Based on what you said, I suspect your batteries. The combo you have should be giving you 75 oz thrust and pulling around 50 amps with a 13x8 APCe It should pull the Accord 47 straight up until it is out of sight ![]() Get yourself a Whattmeter and check the amps and watts. I have Kirk Massey @ New Creations R/C build my packs. http://www.newcreations-rc.com/ Personally, I like the Sanyo 2600's, even though they take a bit longer to charge. Ed |
I flew my Accord 47 for the first time today. I'm using a Axi 2820/10 swinging a APC 11x7 prop and a 10 cell 3000 nimh battery pack. It flew with great authority and was really smooth. The handling was very predictable and it didn't have any bad tendencies. It should make a great pattern/sport flyer. My only recommendation is to reinforce the landing gear. I glued some extra ply around the gear and used some landing gear straps on the outside like Ed did.
Congratulations :D
sgil2001,
Glad to hear things went so well on your maiden flight ![]() My buddy Gary Krasicky is flying a 2820/10 on 10 cells in a Skyvolt and he LOVES it. Simple, quiet and excellent power. I believe he is running a 11x5.5 APCe. I also believe he said it was pulling right at 40 amps. Did you put a Whattmeter on it ? Amps ? If you are over 40 amps static .... I'd try a 11x5.5 APC e prop. Ed |
| Thread Tools | |
| Sold HOTLINER DEAL! MiniNYX-E, Aveox 27/26/1.5 with 4.3:1, Hacker 70-B ESC + MORE! | Z06kal | Aircraft - Electric - Airplanes (FS/W) | 4 | Aug 03, 2005 04:49 PM |
| WTB: Aveox 27/26/1.5 with 3.3 GB | geng | Aircraft - Electric - Airplanes (FS/W) | 8 | Feb 20, 2004 11:46 AM |
| Min480 Fan with Aveox 27/26/1.5 questions. | rcjetpilot | Electric Ducted Fan Jet Talk | 10 | Jan 08, 2004 10:13 PM |
| corona with aveox 27/26/1.5 brushless | Grant Lord | Aircraft - Electric - Airplanes (FS/W) | 9 | Dec 11, 2003 09:26 PM |
| FS: Aveox 27/26/1.5 with Maxon 4.4:1 Gearbox | dw1122 | Aircraft - Electric - Airplanes (FS/W) | 11 | Nov 11, 2003 10:49 AM |
