Old Apr 20, 2001, 10:51 AM
Ralph Weaver is offline
Find More Posts by Ralph Weaver
Ralph Weaver's Avatar
Indianapolis, IN USA
Joined Nov 2000
Sanyo CP-1300SCR are here!
Hello All,
I just go my first batch of Sanyo CP-1300SCR cells for sale. These cells are shorter than the 4/5 Sub-C cells such as the N-1250SCR and weigh the same as 800AR cells. They donít have quite the capacity of the 1250, but are a very good replacement for the 800AR.
1300 beside Sub-C 2000
Iím selling these for $5 each plus $5 S&H per order. Price breaks at 50 and 100pc. See http://www.magtechinc.net for more info. The price may come down a bit over the next few months as these cells become easier to get.
CP-1300SCR specs:
Weight: 33g
Diameter: 23mm
Height: 26mm
Capacity at 20A: 1100mah
Measured Internal Resistance: 7.4mOhm
For comparison:
N-800AR specs:
Weight: 32g
Diameter: 17mm
Height: 50mm
Capacity at 20A: 810mah
Measured Internal Resistance: 7.8mOhm
CP-2400SCR specs:
Weight: 58g
Diameter: 23mm
Height: 42mm
Capacity at 20A: 2270mah
Measured Internal Resistance: 5.3mOhm
N-1250SCR specs:
Weight: 40g
Diameter: 23mm
Height: 34mm
Capacity at 20A: 1250mah
Measured Internal Resistance: 6.5mOhm
[This message has been edited by Ralph Weaver (edited 04-20-2001).]
Ralph Weaver is offline Find More Posts by Ralph Weaver
Old Apr 20, 2001, 01:30 PM
wiley is offline
Find More Posts by wiley
wiley's Avatar
owosso, mich
Joined Mar 1999
Hmmm...these cells look like the N600SCR that i have, a couple 10 cell packs. i bet these are way under rated, more so than the 1000SCR. these cost me $2.20 each 1/2 sub c sized.
<img src=http://members.aol.com/wileyeco/n600scr>
[This message has been edited by wiley (edited 04-20-2001).]
wiley is offline Find More Posts by wiley
Old Apr 20, 2001, 02:25 PM
Joined Nov 2000
You are correct. Same size, almost twice the capacity. Sanyo cells used to be under rated, but not any more. They've started rating their cells the same as everyone else.
Old Apr 20, 2001, 02:26 PM
GregG is offline
Find More Posts by GregG
Speed Demon
GregG's Avatar
Antioch,CA,USA
Joined Dec 1999
HMMmmmm, at this physical size you can fit 26 CR1300 cells in the same space as 20 1250SCR cells. The weight of a 26 cell pack is less than 2 ounces more. Oh no, I had better hide the credit card! Here goes another entry in the <a href=http://www.ezonemag.com/disc/Forum1/HTML/006480.html target=blank>Flying $$$'s</a> subject!
GregG is offline Find More Posts by GregG
Old Apr 20, 2001, 03:44 PM
avalanche
avalanche
Guest
n/a Posts
Any idea what the max current these cells can handle is? I don't think they are a replacement for applications using 1250 SCR's at 70 amp currents.
I am not even sure the new 1700's that are the same size and weight as the 1250SCR's can be used at really high current.
steve mangum
Old Apr 20, 2001, 05:05 PM
Joined Nov 2000
Probably not. They seem to perform a quite a bit better than 800AR's but not at 1250 levels.
I've got 30 CP-1700SCR samples and they look REAL good - higher voltage than 1250's. If the production cells are that good I think they will work fine at 70A.
Old Apr 20, 2001, 06:42 PM
Daveairway is offline
Find More Posts by Daveairway
Santa Rosa, Northern CA, USA
Joined Oct 1999
Wiley, Thought I was the only one that played with the Stubby Cells! 18 of them on an Astro 40 (non FAI) went straight up in a 2 meter ship. Got mine real cheap when the extra packs for the Kraft Chipmunk went on sell. Think it was about 6/7 bucks for a 6 cell pack. They say N-600 SCF though, not AR.
Only have about 30 of them left, a few did die in action...
Glad Sanyo got smart again. Boy, and I just bought the "last 800AR" pack at the local HS...
Ralph,
Thanks for the heads up. The new ones should be great
Dave
[This message has been edited by Daveairway (edited 04-20-2001).]
Daveairway is offline Find More Posts by Daveairway
Old Apr 24, 2001, 02:16 PM
eplanedude is offline
Find More Posts by eplanedude
Electric Airplane Crazy!
Joined Feb 2001
Ralph, It seems that these are a super lightweight new technology. How hard can they be pushed? Will they hold up at F5b/d currents of ~100 amps or will they be good at Nimh currents only ~35 amps? Have you run any tests on them yet?
[This message has been edited by eplanedude (edited 04-24-2001).]
eplanedude is offline Find More Posts by eplanedude
Old Apr 24, 2001, 09:18 PM
wiley is offline
wiley's Avatar
owosso, mich
Joined Mar 1999
hey dave like them cells? i sure like mine, and they do say scr. yes these are about 1000ma, but only say 600. found them at local electronics store.
FS: Sanyo CP-1300SCR 7 and 8 cell packs - new kyril Aircraft - Electric - Airplanes (FS/W) 0 Aug 31, 2003 11:51 AM
FS 8 new Sanyo CP-1300SCR Loose cells mickydee Aircraft - Electric - Airplanes (FS/W) 3 Oct 14, 2002 01:56 PM
Are Sanyo CP 1700, that much better? PaulF Power Systems 17 Jan 05, 2002 05:42 PM
What are the smallest Sanyo CP cells? sblack Sport Planes 7 Dec 17, 2001 10:32 PM
My CP 8 x 1700's are here. (Yeah!!!) hmhoshi Electric Sailplanes 16 Oct 31, 2001 04:10 PM
