Space Coast
Joined Oct 2000
Other considerations
1. Even the best batteries operated continuously at their maximum continuous duty rating will only last 50 cycles or less. Cheaper batteries will not last as long if at all. 2. A pack operated at 20C continuous will give a max 3min flight. A pack operated at 30C continuous will give a max 2 min flight. 3. To get a 10min flight you need to limit the draw on the battery to an average of 6C. Get a big enough battery (mah) so that you can fly 10 min which is an average 6C draw. I don't have any idea of how you fly with the throttle, wide open 100% or mostly 50%, but that's the key. Let's assume you use 100% 5% of the time and 50% the rest of the time. For the 100% throttle you need 50A and for the 50%, let's say 15A. A 20C 3000mah battery will give you 50A for the times when you need 100% and loaf along at 15A. 15A is a 5C draw. 15000/3000 = 5C. 60min/5C = 12 min flight 25A average draw would be 8C. 25000/3000mah = 8.33 60min/8C = 7.5min If you wanted to operate full throttle for 100% for 10min you would need a 6666mah 15C pack. And that's how it goes. |
Also,
Please remember that the motor doesn't set the amount of current alone! Your propeller will also determine the draw from the battery. 2dogrc www.2dogrc.com |
Latest blog entry: Drunk Reindeer Spotted
| Thread Tools | |
| Discussion Question about C rating. | jpwkeeper | Power Systems | 5 | Aug 02, 2007 03:45 PM |
| ? about C rating on Poly's | BlueDevil | Batteries and Chargers | 1 | Aug 26, 2005 09:52 AM |
| question about autorotate hub on eco 8? | SKYWARN | Electric Heli Talk | 11 | Jan 22, 2003 11:12 PM |
| Question about Heat Sink on Tiger Moth? | glenclif | Parkflyers | 10 | Jun 20, 2002 07:06 PM |
| question about pinion gear on 3.8 geardrive | Ripley | Electric Sailplanes | 1 | Jun 10, 2002 10:10 PM |
