Old Mar 19, 2003, 09:10 AM
efurche is offline
Find More Posts by efurche
ft. worth, tx
Joined Nov 2002
Rant
li-poly pack failure (title edited by Brian Cullen Mar 20, 2003 due to language)
New at li-polys. made a 2 cell series pack of 560's. Everything seemed okay, charged okay with the LIPO 402 charger set to 560 mah and 7.4 volts. Pack ran fine. Charged for a few minutes, semed fine, then charged for about 20 minutes and pack fried, swelled up, and emitted an awful smell.
What happened?
I replaced the pack with the ni-cad pack and charged thru the jack on the model, it works fine, so nothing shorted out in the model. I looked at the solder connections and they are fine.
Ed
efurche is offline Find More Posts by efurche
Old Mar 19, 2003, 10:38 AM
JJ HONG is offline
Find More Posts by JJ HONG
KOREA
Joined Dec 2002
very sorry to hear the situation.your set up of 2 series 7.4volt is right.to determine the reason we need following data
1)swelled both cell ?
2)check the voltage of the swelled each celland let me know.
Then we can advise. Thanks
JJ HONG is offline Find More Posts by JJ HONG
Old Mar 20, 2003, 08:53 AM
efurche is offline
ft. worth, tx
Joined Nov 2002
Don't really want to mess with it, as it may leak or something. The odor emitted when it swelled, was awful.
The pack measures about 5.1 now.
I am using the LIPO 402 charger set to 7.4 volts and 560 mah. All voltages were correct prior to the swelling incident.
There are no shorts in the model charging jack, as I put the Ni-Cad pack back in and charged it just fine.
Old Mar 20, 2003, 09:05 AM
JJ HONG is offline
KOREA
Joined Dec 2002
I fully understand your points but to determine the reason,pls tell whether both cells were swelled or one cell was swelled.
Thanks in advance
Old Mar 20, 2003, 07:44 PM
efurche is offline
ft. worth, tx
Joined Nov 2002
fma direct asked me to send the charger and the 2 cells to them for evaluation.
In answer to your question, both cells swelled the same amount.
Old Mar 21, 2003, 12:55 AM
Danny Troy is offline
Find More Posts by Danny Troy
Danny Troy's Avatar
Westchester County, NY, USA
Joined Jun 2000
Ed,
I had a similar experience after having reversed the charging leads. Is it possible you might have reversed the charging leads? My experience with Lipolys so far shows that they are as robust as nimh when it comes to abusing them, but reversing the charging leads I guess will destroy any battery but quick.
Danny
Danny Troy is offline Find More Posts by Danny Troy
Old Mar 21, 2003, 10:16 AM
JJ HONG is offline
KOREA
Joined Dec 2002
Originally posted by Danny Troy
Ed,
Danny
reverse charging lead will not cause that problem because kokam lipo 402 was designed to protect this possible case already.
If both cells are swelled,it will be one/millions posibility of cell failure.If every setting ware correct,it should be a charger problem.FMA will investigate the reason.anyway,if the user is not satisfy,we are reposible for that.
sorry for his unconvenience. Thanks
Old Mar 21, 2003, 11:02 AM
lrsudog is offline
Find More Posts by lrsudog
Go get them Meg!
lrsudog's Avatar
Cabin 21...
Joined Jan 2001
WOW!
That is a responsible manufacturer!
I am very impressed Mister Hong.
lrsudog is offline Find More Posts by lrsudog
Old Mar 21, 2003, 11:03 AM
Dave Hederich is offline
Find More Posts by Dave Hederich
Walled Lake, MI, USA
Joined Feb 2000
It sounds as if you may be keeping your battery packs inside the aircraft, and charging them through a jack in the side of the aircraft. Am I understanding this correctly? If so could there be something in the wiring circuit that would cause a problem with the LiPo pack and LiPo charger that does not show up with a NiCd pack and NiCd charger?
Dave Hederich is offline Find More Posts by Dave Hederich
Old Mar 21, 2003, 09:00 PM
Danny Troy's Avatar
Joined Jun 2000
JJ Hong,
You're right about reversing the charging leads. What I forgot to mention is that on had been distracted when assembling a Kokam pack and accidentally connected - + + -
instead of - + - + . I then hooked the misconfigured pack to the charger. I believe one cell swelled and vented and the other was fine. I'm sure that could not have happened in Ed's case.
Danny
Old Mar 30, 2003, 07:43 AM
hoppy is offline
Find More Posts by hoppy
Space Coast USA
hoppy's Avatar
Space Coast
Joined Oct 2000
Re: li-poly pack failure (title edited by Brian Cullen Mar 20, 2003 due to language)
What happened?
Ed
Ed, Have you heard anything about the charger yet?
hoppy
hoppy is offline Find More Posts by hoppy
Old Mar 30, 2003, 09:06 AM
rkramer is offline
Find More Posts by rkramer
Frequent flyer
Grand Forks, ND
Joined Aug 2002
no one mentioned it yet, but DO NOT SMELL THEM!! some of the stuff they release can be extremely toxic. If they are ballooned, handle with extreme care.
rkramer is offline Find More Posts by rkramer
Old Mar 30, 2003, 04:31 PM
electroman is offline
Find More Posts by electroman
Gaithersburg, MD, USA
Joined Jun 2000
In handling any battery, if the cell outgasses. a residue with some toxicity , as defined by EPA, is generated. The outgas from Lithium Ion or Li Po can have a minute trace amount of hydrogen fluoride in it. However, "smelling" a cell isn't going to expose you to any real harm because the release is in such trace amount. If you have ballooned a cell and want to dispose of it, it works perfectly to have a container of salt water handy, punch a small hole in the plastic envelope and drop the cell into the water. You will see a small stream of bubbles as the gas enters the water. Let the cell sit in the water a few hours and you can throw it in the garbage with no concern. Lead acid batteries outgas hydrogen that can be explosive and, of course, lead is a heavy metal like cadmium with attendant toxicity. NiCds outgas minute mounts of strong base (hydroxy) compounds because they use potassium hydroxide as electrolytic. NiCds are the bad actor as the Cadmium in them is sufficiently toxic that one must recycle NiCds and never throw them in the trash.
electroman is offline Find More Posts by electroman
Old Mar 30, 2003, 06:00 PM
hoppy is offline
Space Coast USA
hoppy's Avatar
Space Coast
Joined Oct 2000
I interpret your statement as saying if you want to pick up the cell and smell it, that's OK. Is that what you meant to convey?
I would think it would be prudent to try ones best not to smell the gases released from any battery.
hoppy
Old Mar 30, 2003, 07:19 PM
efurche is offline
ft. worth, tx
Joined Nov 2002
fma hasn't looked at the charger or the cells yet(said early this week). Meantime, I ordered a 2 cell series pack made up by another company. I'm so ready to get this thing going....
Charging Li-Poly pack questions? John Ball Batteries and Chargers 5 Jun 26, 2003 03:34 PM
Discharging LI-Poly pack with regular charger? pullin-gs Batteries and Chargers 1 May 15, 2003 10:27 PM
WTB-- 1020 li-poly pack MrFlyer Aircraft - Electric - Airplanes (FS/W) 1 Apr 09, 2003 08:36 PM
Building Li-Poly pack Splash Batteries and Chargers 34 Mar 24, 2003 08:58 AM
Which Li-Poly pack for a Tiger Moth ? Al P Batteries and Chargers 6 Mar 05, 2003 05:43 PM
