Old Mar 19, 2003, 08:13 AM
ED209 is offline
Find More Posts by ED209
ED209's Avatar
Charlotte, NC
Joined Dec 2002
Power system for 43" P-51?
I'm currently in the construction stages of a House of Balsa P-51. Here are the specs:
Wing span = 43 in.
Wing area = 334 sq. in.
Weight with radio = 40 oz.
I'm considering going with a brushless motor, probably a Mega 22/30/3. I'd also prefer to use Li-Poly batteries, too. Does anyone have suggestions regarding a suitable motor/gearbox/battery set-up? Thanks in advance.
ED209 is offline Find More Posts by ED209
Old Mar 19, 2003, 07:26 PM
Jim Finn is offline
Find More Posts by Jim Finn
Damascus Md
Joined Oct 2002
I have a Herrr P-51 that has a 42" span that I powered with a Maxcim motor on 12 cells with a 3:1 gearbox and 14" prop. It weighs all up weight 64 OZ. It screams!!!! I plan to try 10 cells. I had to fly it at 1/2 throttle with 12. It flew great but way too fast for me. I may take the maxcim out and try a Jeti Phaser 45/3 direct. Mine has no LG and no rudder with a folding prop, I bungee launch it .
Jim Finn is offline Find More Posts by Jim Finn
Old Mar 20, 2003, 08:44 AM
Megowcoupe is offline
Find More Posts by Megowcoupe
Balsa Flies Better!
Stamford, CT
Joined Oct 2000
Do some searching
Ed
Lots of folks have done this airplane. IIRC- a happy setup is about 300 watts on an 8" prop which should be pretty close to glow performance. I have the kit- I'd probably go with a Mega 22/20/3 and an 8 cell 4/5F AUP 1950 pack- which is nice and lightweight, but this airplane is sturdy- takes power well, and I've heard of things from direct drive ferrite motors to Astro 05 brushless setups. I'm flying an Apache which is a similar layout- 37 oz- 8 cell CP 1700, Mega 22/20/4 and a 9 x 5 folder- this would give better vertical pull at the expense of some top end. Might add a cell just for ha/has.
Jim- Now I've heard everything- that poor little Herr P-51 was supposed to weigh 24 oz or so with a 10 in the snoot, and you drop a Maxcim in it? That has got to be the record for overpowering that airplane.
Sam
Megowcoupe is offline Find More Posts by Megowcoupe
Question Hyperion Power System for Hanger 9 P-51 PTS UnPossible Electric Warbirds 1 Jan 11, 2007 04:10 AM
Question Hyperion Power System for Hanger 9 P-51 PTS UnPossible Power Systems 0 Jan 10, 2007 11:01 PM
Question Power system for 48" wing lmopar69 Flying Wings 6 Jan 15, 2006 03:44 AM
Question Power System for World Models P-51D (57 inch wing span) @ 6 lbs. guapoman2000 Power Systems 2 Jan 24, 2005 04:09 PM
HofB 43" P-51 Electric Conversion w/ Retracts ED209 Scale Kit/Scratch Built 30 Nov 03, 2003 12:56 AM
