Old Mar 26, 2009, 05:08 AM
PeterO_UK is offline
Find More Posts by PeterO_UK
PeterO_UK's Avatar
Joined Aug 2006
Originally Posted by sr71fan
I have no experience with the DC head, so you're on your own in that regard.
Gary
Errrrr Sure you do. Your model has DC head, just not a 2 axis DC head.
PeterO_UK
PeterO_UK is offline Find More Posts by PeterO_UK
Old Mar 26, 2009, 12:45 PM
sr71fan is offline
Find More Posts by sr71fan
Flying...Pushing Air Down
sr71fan's Avatar
Clovis, NM, USA
Joined Nov 2000
OOps!
Thanks Peter!
Gary
sr71fan is offline Find More Posts by sr71fan
Old Apr 05, 2009, 09:34 PM
grant31781 is offline
Find More Posts by grant31781
Joined Jun 2003
Gary,
I really like your gyroplane!
Can you tell me a little about your 3 blade rotor? Are the blades reinforced? Are you using any type of hinging? How much negative incidence is in the blades?
What size are the blades chord and span?
grant31781 is offline Find More Posts by grant31781
Old Apr 05, 2009, 11:27 PM
sr71fan is offline
sr71fan's Avatar
Clovis, NM, USA
Joined Nov 2000
Grant,
Glad you like it. The blades are 2 inch by 12 inch (25 inch rotor) made from 3mm Depron, and have 2mm carbon rods (that's all I had) taped to the leading edge. The pitch (don't know how much) is the result of overlapping the leading and trailing edges of adjacent blades. The trailing edge is placed on top of the leading edge of the following blade. The blades are then sandwiched between two circular discs, and everything is held together with hot glue. Any "hinge" is coincidental with the flexing of the Depron discs. Oh, and I added a 1 inch square (should be round) of 1/64 ply above and below the hub to prevent the shaft bearing from pulling through the foam.
I hope this makes sense... I sorta copied Michael Connally's hubs from his giant Twirl modification which he derived somewhat from Al Foot's Twirl design (I think). I can't remember half of what I did; I usually take the simplest and quickest route (yes, you can call me lazy).
Hope this helps. Take a look at what I did at work today while I was waiting for some customers...
Gary
Autogyro Fun Indoors (1 min 38 sec)
Old Apr 06, 2009, 10:05 AM
Joined Jun 2003
Cool video! How did you get the baldes set/ aligned at 120o apart?
Old Apr 06, 2009, 11:01 AM
sr71fan is offline
sr71fan's Avatar
Clovis, NM, USA
Joined Nov 2000
Grant,
I drew a circle on a piece of cardboard for use as a template. Guessed at the three points; then kept changing them until they were all the same distance apart. Assembled the rotor over the template.
Gary
Old Apr 07, 2009, 06:54 AM
dlazarus6660 is offline
Find More Posts by dlazarus6660
If it flies, I crash it!
dlazarus6660's Avatar
United States, FL, Mary Esther
Joined Nov 2006
Awsome!
Hey Gary,
Awsome video!
I'm still in awe over your Cessna 402!
Still fly it?
BTW, can you take some detailed pic's of the Cessna 402 so I can "borrow" your ideas to build one?
Keep up the good work!
Daniel
dlazarus6660 is offline Find More Posts by dlazarus6660
Old Apr 07, 2009, 11:46 AM
sr71fan is offline
sr71fan's Avatar
Clovis, NM, USA
Joined Nov 2000
Daniel,
Yes, I still fly the 402; it goes with me to every event. PM me your e-mail address, and I'll send pics.
Glad you like the video.
Gary
Old Apr 14, 2009, 12:45 AM
sr71fan is offline
sr71fan's Avatar
Clovis, NM, USA
Joined Nov 2000
Made a new ship yesterday, and test-flew it today. Basically the same as the second one, and used the 3-blade rotor from it. This one has a taller mast and more tilt back, to get it spinning up faster on takeoff. Here are some pictures I took while flying it:
Gary
Old Apr 14, 2009, 05:38 AM
JochenK is offline
Find More Posts by JochenK
JochenK's Avatar
Joined Jan 2005
Grant,
well done. Congratulations.
Jochen
JochenK is offline Find More Posts by JochenK
Old Apr 15, 2009, 03:03 PM
heli_ebook is offline
Find More Posts by heli_ebook
heli_ebook's Avatar
Joined Apr 2006
Could this be built with just foamboard, instead of 2-3 different materials? The blades being the most delicate I would think.
heli_ebook is offline Find More Posts by heli_ebook
Old Apr 19, 2009, 11:17 PM
heli_ebook's Avatar
Joined Apr 2006
Great answer, keep up the good work!
Old Apr 22, 2009, 01:44 AM
sr71fan is offline
sr71fan's Avatar
Clovis, NM, USA
Joined Nov 2000
I guess you could make it out of whatever you want. I used what I had on-hand.
More video...
Gary
Autogyro Fun Outdoors (2 min 1 sec)
Old Apr 22, 2009, 02:47 AM
Norfolk Flyer is offline
Find More Posts by Norfolk Flyer
Suck it and see
Norfolk Flyer's Avatar
Cromer, North Norfolk Coast, UK
Joined Aug 2008
Nice one Gary,
For such a lightly loaded model, it (and you) handles the wind very well.
I calculate you have just 2 ounces per square foot. I'm working on a variation right now. Hope to have results soon.
John
Norfolk Flyer is offline Find More Posts by Norfolk Flyer
Old Apr 22, 2009, 06:28 AM
Suck it and see
Joined Aug 2008
Gary,
When building this, I wanted a similar model to yours, but with folding blades, which probably meant a flex plate type head. I used polypropylene to make the plate, cut from a clear plastic stacking storage crate. (don't tell the wife).
The actual blades are made as your design, 3mm depron with a 2mm CF rod on the LE, which I fixed in place with clear packing tape.
I knew I could never keep the weight down to under 7 ounces, so I made 14 inch rotor blades to achieve the 2 ounces per sq. foot that you have. My model is 10 ounces AUW.
Tail wheel and "finlets" complete the build. Sorry but no colour yet!
see pics
Video soon, I hope.
John
Looking for TurboCAD 2D 6.5 Zoom The Builders Workshop 22 Dec 01, 2006 12:04 PM
Yippee! My wife got me a digital postal scale today. My moth is 6.5 oz w/ no battery! The Other Dave Parkflyers 1 Feb 08, 2002 10:37 PM
Aeronaut 6.5x4 or 6.5 prop for Zagi 450T ? freq Foamies (Kits) 3 Oct 25, 2001 06:36 PM
Will a 6.5-4 prop work with a direct drive Permax 480? Ryan Nau Power Systems 2 Apr 29, 2001 11:43 AM
