Old Dec 20, 2009, 09:12 PM
sr71fan is offline
Find More Posts by sr71fan
Flying...Pushing Air Down
sr71fan's Avatar
Clovis, NM, USA
Joined Nov 2000
Mansoor,
Glad you got it sorted out.
Now, let's see some videos!
Gary
sr71fan is offline Find More Posts by sr71fan
Old Dec 20, 2009, 10:01 PM
tymbrewolf is offline
Find More Posts by tymbrewolf
Joined Feb 2007
I have had a brass tube, cf, three 5g servos, 10A esc and a turnigy 2730 1300 earmarked for this. Maybe it is finally time to do one over the holiday.
Skysailor, Gary, might I interject an idea as to the right tilt. Since this is still a tractor type aircraft, the angle (thrust) of your motor might be causing your issues. You might need to adjust right thrust 2 or three degrees. From your picture it is hard to tell if you have any right thrust...
Gary is that plausible?
tymbrewolf is offline Find More Posts by tymbrewolf
Old Dec 21, 2009, 11:29 AM
sr71fan is offline
sr71fan's Avatar
Clovis, NM, USA
Joined Nov 2000
Tymbrewolf,
While right thrust would affect primarily the yaw axis, it might also help the roll due to coupling.
I have as near to zero right thrust on mine as I could determine, and the AG requires only very slight right tilt.
Only one way to find out!
Gary
Old Dec 21, 2009, 04:46 PM
dz1sfb is offline
Find More Posts by dz1sfb
Ken's CAD Models
dz1sfb's Avatar
Attica, MI
Joined Dec 2006
Beautiful work SR71! How about a cooperative effort for a proper set of plans?
I would like to build one and would develop the plans anyhow.
Ken
dz1sfb is offline Find More Posts by dz1sfb
Latest blog entry: Mini H Quad Project
Old Dec 21, 2009, 07:16 PM
Joined Feb 2007
I vote yes... Gary, look at this fuse design... Looks like the perfect marriage, part oldtimer, part autogyro, all foamie!
http://www.rcgroups.com/forums/showthread.php?t=1151461
Old Dec 21, 2009, 07:42 PM
sr71fan is offline
sr71fan's Avatar
Clovis, NM, USA
Joined Nov 2000
Wow! That Old-Timer looks pretty good! But, I think you'd have to make the mast taller and the vertical stabilizer shorter (or split into two), so you might as well just draw one from scratch!
I don't have any plans. Never had any plans, and never will have any plans. So, be sure and post them for me when you draw them, OK?
Gary
Old Dec 21, 2009, 11:15 PM
Joined Feb 2007
Made two sketchup file from your photos. I guess I didn't realize how big this is...
Auto gyro side printed pages 9,10, 15,16,17
Autogyro top printed 5,14,22,23,24
Measured my printed paper. Appears to be within 1/16" in correct size.
Old Dec 22, 2009, 01:07 AM
sr71fan is offline
sr71fan's Avatar
Clovis, NM, USA
Joined Nov 2000
Cool!
Old Dec 30, 2009, 11:55 PM
Joined Feb 2007
Gary, do your blades butt up against each other on your two blade rotor or is there some (hub) material between them. Your photo in post 68 shows 12" but it doesn't go to the centerline, but instead to the outside of the ply top support. I am hoping to finally get started on mine over the holiday (six months after buying my CF, motor, and brass tube).
Also from the top does the right blade le tip up or the left blade of the rotor's LE tip up?
Old Dec 31, 2009, 06:39 AM
sr71fan is offline
sr71fan's Avatar
Clovis, NM, USA
Joined Nov 2000
The blades do not meet at the center. They stop about where the line is in the photo in post 68, near the edge of the ply. The carbon LEs extend to the adjacent blade, so I have more gluing area. There is a piece of scrap blade material between the blades. The LEs of both blades are angled down a few degrees so the air coming up from the bottom will rotate them. The rotor rotates clockwise when viewed from above because I'm right-handed, and it's easier for me to spin it that way. Clear as mud?
Old Jan 01, 2010, 01:21 AM
Joined Feb 2007
Thanks got it.
Old Jan 17, 2010, 10:07 PM
tashley is offline
Find More Posts by tashley
Aerial Images of Texas
tashley's Avatar
The Texas Gulf Coast where hurricanes come to play
Joined Aug 2003
Ken
Yes, please!
tashley is offline Find More Posts by tashley
Old Feb 15, 2010, 06:51 PM
bashmi is offline
Find More Posts by bashmi
I AM gonna do it.
Vanderbijlpark. South Africa
Joined Jul 2009
Plans ready.
Ok Gary,
I have decided.!!!!
I have made DXF plans from your photos.
They are almost to scale (warping from the camera).
I do waterjet, laser and router cutting for a living.
So here is what I decided..
I am not going to build it.
I am going to buy yours.
Quote me with shipping to South Africa please.
Peter.
My grandson is driving me crazy!!!
bashmi is offline Find More Posts by bashmi
Old Mar 14, 2010, 07:30 PM
WillemII is offline
Find More Posts by WillemII
Joined Mar 2005
Hi all,
While reading through this thread I became very impressed with Gary's wonderful autogyro design. Needless to say, I just had to build one.
Since I like building along some form of plan, I got in contact with Gary and we decided I'd try and do some drawings. So, here they are. I've printed them into PDF, and there are tiled versions for different paper formats. All in one zipped package.
Have fun and happy flying!
Willem
(in the mean time my gyro is waiting for the maiden flight, a little too windy for it right now, here in Holland ).
WillemII is offline Find More Posts by WillemII
Old Mar 14, 2010, 08:29 PM
sr71fan is offline
sr71fan's Avatar
Clovis, NM, USA
Joined Nov 2000
Drawings
Willem,
Fantastic drawings!! I hope everyone enjoys them. Many thanks to you. Here's hoping you get some calm air!
Peter,
My AG3 is getting rather beat-up, so I suggest you build your own using the wonderful drawings Willem has posted.
Happy flying to all!
Gary
Looking for TurboCAD 2D 6.5 Zoom The Builders Workshop 22 Dec 01, 2006 01:04 PM
Yippee! My wife got me a digital postal scale today. My moth is 6.5 oz w/ no battery! The Other Dave Parkflyers 1 Feb 08, 2002 11:37 PM
Aeronaut 6.5x4 or 6.5 prop for Zagi 450T ? freq Foamies (Kits) 3 Oct 25, 2001 07:36 PM
Will a 6.5-4 prop work with a direct drive Permax 480? Ryan Nau Power Systems 2 Apr 29, 2001 12:43 PM
