Go Back   RC Groups > Aircraft - Sailplanes > Slope
Old Feb 27, 2009, 11:26 AM   #1
Just fly it!
wyowindworks's Avatar
Stinger 45v2 Progress Thread (Starting to ship! Finally!)
Well, gang, I'm gearing up for the next run of Stinger 45's. The version 2 will use a tapered boom in a new configuration. You won't have to use the time consuming alignment blocks anymore. The new boom will basically just plug on. The riser for the stab. (previousely balsa and ply) will be carbon and molded right onto the boom. It will also have ballast accommodations.
The tail shapes in the new version also get slightly modified.
I'm hoping that the new fuse will be painted in the mold (white, maybe red). I'm still using the wet seam, but the mold will use an inflatable bladder to press the seam. The fuse will be offered in a glass or carbon version.
I'm going to post the construction for all the new molds (fuse, canopy, stab. riser, servo covers) as well as all the production jigs.
On every new model that I do, I like to add one or two personal molding advancements. I've never used bladders before or done a full painted in the mold fuse, so, this will be a learning experience.
I'll also be doing the kit in Full, Builder's, of Short kit variations.
Here is more info on the Stinger 45.
More to come!
Adam
wyowindworks is offline Find More Posts by wyowindworks   Reply With Quote
Old Feb 27, 2009, 01:27 PM   #2
Registered Abuser
fooesboy's Avatar
Great news Adam!
I can't wait for my new v2 Stinger,I have pretty much flown my Stinger 45 into the ground...... well I HAVE flown it into the ground bit it's still flying!
The changes you are making should really enhance this great little glider.
Chris
(reaching for a beer and picking the best seat in the peanut gallery )
fooesboy is offline Find More Posts by fooesboy   Reply With Quote
Old Feb 27, 2009, 01:41 PM   #3
Just fly it!
I just broke my bandsaw blade.....and no one in Cody, WY sells 82" blades. I can't cut the fuse profiles until the new blades come. Living in a small town has it's moments.
Adam
Old Feb 27, 2009, 02:52 PM   #4
Registered Abuser
fooesboy's Avatar
I get the feeling that you were not a boy scout.........
Old Feb 27, 2009, 03:19 PM   #5
Just fly it!
No. I dropped out of the boy scouts after my pine wood derby car was disqualified because they said Dad my built it rather than me. I was a shaping fool at age 13.
I guess I shaped that car without a band saw...I must be getting soft.
Today, I'm making the tooling for the Orangutan instead.
Right now I'm spending 2-3 days a week finishing up the Stingerons and 2-3 days working on new stuff.
Adam
Old Feb 27, 2009, 04:37 PM   #6
gleaning info from the experts
I can't wait to get it .................. oh I am waiting
Datman is offline Find More Posts by Datman   Reply With Quote
Old Mar 03, 2009, 06:34 AM   #7
Registered Abuser
fooesboy's Avatar
Hey Adam,
It's been 5 days...... where is the progress? The peanut gallery is getting restless!
Chris
Old Mar 03, 2009, 10:31 AM   #8
Just fly it!
Still waiting for the stupid band saw blades...
Old Mar 03, 2009, 10:39 AM   #9
Firecracker!
BillO's Avatar
Go Adam! I'll be very interested to see how you do the bladder thing. I've heard about it, but never seen any details...
BillO is offline Find More Posts by BillO   Reply With Quote
Old Mar 03, 2009, 10:48 AM   #10
Just fly it!
Same here.....heard about it, but never seen any details .
Adam
Old Mar 03, 2009, 10:56 AM   #11
Registered Abuser
fooesboy's Avatar
Bladder control
I've played with bladders before......... can't say that I want to again!
Chris
Old Mar 03, 2009, 11:00 AM   #12
Adam,
I am anxiously awaiting my new Stinger 45 V2 kit, but more importantly
I want to see your build thread. We all learn so much from your work.
Thanks for sharing with us.
TIM
A6INTRUDER is offline Find More Posts by A6INTRUDER   Reply With Quote
Old Mar 03, 2009, 12:34 PM   #13
Just fly it!
Prepping the Plug Blank
Here is what I have done so far.
I'll be shaping the plug from maple because its hard (not easily over-shaped), tight grained, and stable.
I first printed the top and side fuse profiles from Rhino 4.0. I like to CAD the whole design first. Many designs problems can be remedied in CAD before the actual parts are made. It also makes templates and jigs much easier to produce.
I then calculated the wood stack. The thin center slab thickness is equal to the distance the bottom of the canopy is above the center line (see photos).
All the slabs were milled with a table saw and thickness planer.
The bottom and middle slabs were glued together using 5 minute epoxy.
Once the glue had cured I marked the location of the bottom of the canopy onto the top of the middle slab. I then made another set of lines outside of the canopy lines to mark where the glue should go. These outside lines accommodate for the glue movement when the pieces are glued to together. I then spread epoxy onto the center slab (NO GLUE UNDER CANOPY) and bonded the top slab to the middle/bottom slabs.
No I'm waited for saw blades .
Adam
  • Name: smallPrepping the Blank 001.jpg
Description: Printed the side and top view from Rhino 4.0 Printed the side and top view from Rhino 4.0 94.7 KB · Views: 354
  • Name: smallPrepping the Blank 003.jpg
Description: Calculating the wood stack.  The bottom line is the center line, the top line in the bottom of the canopy. Calculating the wood stack. The bottom line is the center line, the top line in the bottom of the canopy. 93.4 KB · Views: 275
  • Name: smallPrepping the Blank 006.jpg
Description: After milling the slabs of maple to the appropriate thickness, I glued the bottom and middle stack together.  Then on the top of the middle slab, I marked the location of the bottom of the canopy. After milling the slabs of maple to the appropriate thickness, I glued the bottom and middle stack together. Then on the top of the middle slab, I marked the location of the bottom of the canopy. 82.5 KB · Views: 285
  • Name: smallPrepping the Blank 007.jpg
Description: The center lines are the actual location of the canopy bottom.  The outside lines mark the location of the glue to accommodate for squeeze out. The center lines are the actual location of the canopy bottom. The outside lines mark the location of the glue to accommodate for squeeze out. 40.1 KB · Views: 269
  • Name: smallPrepping the Blank 008.jpg
Description: Then I glued the remaining top slab to the bottom two slabs. Then I glued the remaining top slab to the bottom two slabs. 32.3 KB · Views: 301
  • Name: smallPrepping the Blank 009.jpg
Description: I then cut out the top and bottom profiles just outside the lines. I then cut out the top and bottom profiles just outside the lines. 39.3 KB · Views: 310
  • Name: Prepping the Blank 001.jpg
Description: I then planed the sides of the stack flush with a thickness planer. I then planed the sides of the stack flush with a thickness planer. 70.4 KB · Views: 373
Old Mar 03, 2009, 02:13 PM   #14
Surf's up!!
sixty9mustang's Avatar
Great news Adam!
Chris
Hey!! I am already sitting here, find your own seat bub!! Sheeeeesh, the nerve of some people. Oh and that's my beer also!!
JUST KIDDING, com'on go ahead and sit down, I'll share, just don't drink my beer.
Adam,
I have been waiting to hear about this. Watching intently. All the new mods sound great. I hope you don't vary too much though with the tail, I really liked the old shape. If the wing had round tips lile the stab, that would be cool.
Now for some enjoyment, (reaching for Popcorn), HEy wait a minute, who the', !&(*#%@&*%, where is my popcorn!!! Hey Fooes, you take my popcorn?!?!?
All right go ahead its just popcorn.
Chip
sixty9mustang is offline Find More Posts by sixty9mustang   Reply With Quote
Old Mar 03, 2009, 02:29 PM   #15
Registered Abuser
fooesboy's Avatar
Chip
Who me? Nah, I'm into the M&M's!
Build Log Talon Experimental EDF plane building in progress thread ISNJH Foamies (Scratchbuilt) 4 Dec 03, 2006 02:12 PM
Cool SMS's Dragonhummhawk Progress Thread! (pics) smste2 Micro Helis 7 Sep 05, 2004 03:20 AM
Eco 8 progress thread ashdec87 Electric Heli Talk 22 Jul 31, 2004 10:14 PM
Newbie Progress Thread. OzzieFlyer Micro Helis 180 Jul 20, 2004 03:55 AM
11
