Old Mar 28, 2010, 02:03 PM
sandist is offline
Find More Posts by sandist
Scotland UK
Joined Jan 2005
hi Tuomo,
my Aspire is about 2 years old so maybe I should measure from the L.E. to ensure accuracy.
I have ail/flap mix and whilst adequate it is not too responsive, at my age slow is OK
Ian
sandist is offline Find More Posts by sandist
Old Mar 28, 2010, 04:17 PM
Tuomo is offline
Find More Posts by Tuomo
Tuomo's Avatar
Jyvaskyla, Finland
Joined Aug 2003
Originally Posted by sandist View Post
hi Tuomo,
The position of tow hook is changed sometimes year 2008. My 2007 Aspires have forward position, while the both 2009 Aspires have towhook moved.
Anyway, not a big issue. The original position is ok for anybody for those flying with normal CG, me 115mm.
Tuomo is offline Find More Posts by Tuomo
Old Apr 11, 2010, 08:10 PM
baum58 is online now
Find More Posts by baum58
baum58's Avatar
traverse city mi
Joined Mar 2004
Hello gang...
Well I am "Piked Out" and I did get my Aspire at Toledo show. I will have it flying by the weekend. Thanks for all the info. I will let you guys know how I am doing. I am sorry I was not able to get a green one do......
Peter
baum58 is online now Find More Posts by baum58
Old Apr 11, 2010, 10:40 PM
FLY F3B is offline
Find More Posts by FLY F3B
or F, J, K, or even TD
FLY F3B's Avatar
Joined Jun 2007
Hey Peter, say hello to Leanne for Jeannie and I. You will love you Aspire. I have one, and it is just brilliant!
Take care.
FLY F3B is offline Find More Posts by FLY F3B
Old Apr 12, 2010, 10:44 AM
Keith Kindrick is offline
Find More Posts by Keith Kindrick
Joined Feb 2007
Wind
I’ve been watching this thread for a while. At Fresno this weekend we had the worst conditions imaginable. Launching with a minimum of 10 mph (4.7 m/s) down wind for both days for all weekend proved to be an exceptional opportunity to see in the real world what did happen. While several post on the Aspire’s ability to manage the wind better than other design’s have not gone without notice. Supra’s flown by McGowan and Zucker, Browning’s Zenith 3.7 with full reflex, and my Perfect ET did just fine as did. There was no advantage to flying an Aspire in the same conditions.
My best to all the Aspire owners. I just want to share real data in a real world setting.
Keith
Keith Kindrick is offline Find More Posts by Keith Kindrick
Old Apr 17, 2010, 11:00 AM
baum58's Avatar
traverse city mi
Joined Mar 2004
Toumo and Pat,
I noticed you both have Aspires and Satoris. Can you compare, build, setup, flight performance....?
Peter
Old Apr 17, 2010, 11:20 AM
baum58's Avatar
traverse city mi
Joined Mar 2004
My Aspire is done, yipeeee, most completed "kit". All harnesses in, also with the ballast, good strong finish. However the servo-covers are unusable, too small, too thin, bad fit. I had to use and fit my own.....
Peter
Old Apr 17, 2010, 04:30 PM
Skysailer is offline
Find More Posts by Skysailer
Canada, AB, St. Albert
I have almost finished my servo installation for my Aspire. I think that the servo frames are OK - a little small for the servo opening but it's going to be covered with tape so it should be fine. I had to grind the flap and aileron clevis down quite a lot to fit under the fairings.
Skysailer is offline Find More Posts by Skysailer
Old Apr 18, 2010, 02:56 AM
Tuomo is offline
Tuomo's Avatar
Jyvaskyla, Finland
Joined Aug 2003
Originally Posted by baum58 View Post
Toumo and Pat,
Peter
I dio not fly Satori, I have one Orca. Aspire and Orca are very different planes. Orca is fun to fly, but I use Aspire in competitions. Differences in flight performance are marginal. Aspire maybe floats better but Orca launches faster/higher.
Small performance differences are not significant in F3J. Try to concentrate on knowing the plane you fly. Trim it well, use right camber setting, ballast right, and learn to know what your plane is capable to do.
To me Aspire is the best allround F3J design, because it is very easy to fly and uncritical to trim. I can consentrate on the important things, like thermal tactics.
PS For those building Aspires, I suggest laminating some extra carbon to wing top skin under flap servo. Aspire has large flaps, and the top skin is flexing somewhat. All my Aspires show clear footprints of flap servo. Also ribs both sides of flap servo are good idea.
Old Apr 22, 2010, 08:53 PM
baum58's Avatar
traverse city mi
Joined Mar 2004
First flight today. New winch, new lines, new plane. I was a bit on the nose heavy side. Broke the line six times. I never had a glider go straight up and pull this hard. Adjusted CG and tow-hook with great results. Great floater at 82 oz. I was able to slow the Aspire for landing.. Tomorrow I will work on optimise handling....
Peter
Old Apr 22, 2010, 09:41 PM
Larry Jolly is offline
Find More Posts by Larry Jolly
Larry Jolly's Avatar
Joined Oct 2003
Peter,
What was wrong with the servo covers? Are you sure that these were stock items? Lubos ends 2 sets of covers one with a bump and one flat both trimmed to shape.
Keith,
I am sorry that the Aspire didn't stand up to your test. I have untold hours on both Perfects and Aspires and IMHO the Aspire covers ground much better than the Perfect. The Aspire also handles and circles better than a Perfect. I am with the other guys here I beleive that the Aspire is the best all rounder.
LJ
Larry Jolly is offline Find More Posts by Larry Jolly
Old Apr 23, 2010, 08:12 AM
baum58's Avatar
traverse city mi
Joined Mar 2004
Hi Larry, good to have you back in the US of A.
I got all four servo covers. The covers where to small in W and L. Also I had to shim the servo cover opening to make the covers flush without creating a dip or bump. I used JR378 servos on aileron 368 on flaps. So the ailerons covers are flush and the flaps with the usual hump.
I also had to turn down the last of the wing bolts. It would not fit the last wing hole. I did not whanted to crush the aluminum inserts of the center panel. Small problems for the great plane you get. I still have to sell my Pike LT before in get the next Aspire.... looking for one of the light ones......
Peter
Old Apr 23, 2010, 08:28 AM
Tuomo is offline
Tuomo's Avatar
Jyvaskyla, Finland
Joined Aug 2003
Sometimes the wing bolts are a little tight. However, it is not illegal to open the insert a little with a round file
Servo covers a little small side, and not perfectly flush, but they are anyway fixed with tape.
Old Apr 23, 2010, 10:07 AM
Joined Feb 2007
Handling
Larry,
I accept your opinion. I just do not see what you mention when they fly against me in competition. As you know I have countless hours on the Perfect as well with documented results. I've yet to see this with an Aspire.
Best to you,
Keith
Old Apr 23, 2010, 10:30 AM
Silent-AV8R is offline
Find More Posts by Silent-AV8R
Team Futaba
Silent-AV8R's Avatar
Orange County, CA
Joined Aug 2004
Mike Smith won the F3J contest before the SWC with an Aspire.
We need to understand that there is no one prefect design, not even a Pike Perfect This is not directed at the top level pilots reading this, but to the rest of us.
As Keith notes, he often whips up bad on people with his Pike. Mike Smith does the same with his Aspire. Daryl Perkins seems to be able to do well with his Icon2. Joe Wurts beat everyone up at a contest with an EPP 2-meter Beater. And so on. Point being that after a certain point it is pilot skill and not aircraft design that makes the important difference.
As a guy who has honed his skills to be able to stay just outside the upper ranks of soaring talent I look for a plane that I can fly with confidence. I have sadly finally realized that it is my talent, or lack there of, with a transmitter and not the excellence of the aircraft design that has the greatest impact on my placement in contests.
So talk to the top guys, get their feedback on what they like about the plane they are flying and then decide what you think will work best for you in your price range. Then build it and fly the crap out of it. The constant search for the plane du jour is not going to get you into the winner's circle as much as having a solid design, that matches your skills by maximizing your strengths and minimizing your weaknesses.
Then go fly it. A lot.
Silent-AV8R is offline Find More Posts by Silent-AV8R
Wanted X Tail for F3J composit Seiler`n Aircraft - Sailplanes (FS/W) 0 Aug 20, 2006 05:53 AM
For Sale Pike Superior X-Tail Carbon 68 F3J ssallenbach Aircraft - Sailplanes (FS/W) 9 Jan 27, 2006 02:24 AM
FS: New Pike Superior X-tail (F3J Version) Sled Driver Aircraft - Sailplanes (FS/W) 6 Jun 20, 2004 05:09 PM
F3J Pike Plus X tail models. F3X Aircraft - Sailplanes (FS/W) 1 Nov 15, 2002 10:58 PM
