Old Feb 26, 2009, 04:18 PM
f4addict is offline
Find More Posts by f4addict
Fly, Crash, Burn,
f4addict's Avatar
United States, CT, Danbury
Joined Jul 2008
Build Log
HET Mig 21 is finally here!
I just got it in mail today., looks amazing. looks like the fuse is all ready to go, only needs little work. Anyone else got theirs?, classic tailerons only. fuse has nice details, double packing on box. thanks to ejf. The setup i have in mind puts out 1100 watts. battery compartment is narrow and can fix 4 cells nicely but would be hard getting higher, also the intake ducts go from both sides of battery compartment. no bays for retracts but there is a manual on how to make them with the wood supplied., but can be installed with some work ofcourse. i'm starting to build it today.,
Here are the first pics.
f4addict is offline Find More Posts by f4addict
Old Feb 26, 2009, 04:28 PM
shock-wave is offline
Find More Posts by shock-wave
Joined Feb 2009
HET-RC Mig 21 grey:
Specifications:
Length : 1180mm
Span : 590mm
Weight : 810 grams
Motors : HET 2W-20 or 2W-23 brushless motor
EDF fan unit : HET 6904 or minifan
is that 810 grams the weight of airframe only?
or AUW?
shock-wave is offline Find More Posts by shock-wave
Old Feb 26, 2009, 04:32 PM
f4addict is offline
Fly, Crash, Burn,
f4addict's Avatar
Joined Jul 2008
i havent weighed the airframe, but feels pretty light., and for the first time there are no wrinkles like in traditional het.
Old Feb 26, 2009, 04:35 PM
f4addict is offline
Fly, Crash, Burn,
f4addict's Avatar
Joined Jul 2008
some more pics.
Old Feb 26, 2009, 05:20 PM
Joined Feb 2009
what motor + fan are you going to use on the Mig-21?
It is Hard to get 1100 watts out of 4 cells though.
I have an Unused 16/20/2. That should be fine with Minifan
on the 4/5S lipo for 800/1000 watts, respectively.
Give us the airframe weight please. I want to keep
this Mig 21 as light as possible.
Thanks.
Old Feb 26, 2009, 05:42 PM
tow is offline
tow
Find More Posts by tow
tow
tow's Avatar
Norway, Nord-Trondelag, Namsos
Joined Dec 2003
Ordered mine today red/white-cheme to aid my feeble eyesight
tow is offline Find More Posts by tow
Old Feb 26, 2009, 05:46 PM
f4addict is offline
Fly, Crash, Burn,
f4addict's Avatar
Joined Jul 2008
i tried to weigh it, it's around 900 gms
setup, is already tested and it does provide me 1100 watts.
arc 24-47-1
100amp esc pulls around 84-86amps
4 cell 3850 lipo.,
Old Feb 26, 2009, 06:25 PM
monkamarm2000 is offline
Find More Posts by monkamarm2000
smug in granny panties
monkamarm2000's Avatar
NorCal Silicon Valley
Joined Aug 2002
the trick will be how much of the 1100 will be left after that long blunt walled inlet.
Barry
monkamarm2000 is offline Find More Posts by monkamarm2000
Old Feb 26, 2009, 06:29 PM
f4addict is offline
Fly, Crash, Burn,
f4addict's Avatar
Joined Jul 2008
hopefully atleast a nice hefty 800-900.
Barry
Old Feb 26, 2009, 06:31 PM
Joined Aug 2002
the trick will be how much of the 1100 will be left after that long inlet with blunt walls and a cone.
Barry
Old Feb 26, 2009, 06:33 PM
Joined Aug 2002
whoa! dont know why that doubled the post on me after edit! lol But figure about 15 percent for just a plain old inlet, so after about 935 you'll know right away how the inlet is working. Keep in mind thats un-shrouded, so you'll also know what kinda FSA they have given it all the way down. Plane looks awesome.
Barry
Old Feb 26, 2009, 07:08 PM
lavochkin is offline
Find More Posts by lavochkin
lavochkin's Avatar
Mokena,Illinois -United States
Joined Oct 2006
Mine will be here any day now. Ill go with the crazy high 1700-2000 watts. Im looking for a speed demon out of this one. It has the aerodynamics for it. Never seen how the intake looks til just now. Might need to adjust that a bit.
F4 is the nose cone permanently fixed to the intake or do you assemble it? The cone should be double shaped. Meaning a cone in the back also for streamlining. Plus the cross braces shouldnt be so blunt and should be smooth for less turbulence. Hopefully I can fix this. This jet should rock.
lavochkin is offline Find More Posts by lavochkin
Old Feb 26, 2009, 07:19 PM
f4addict is offline
Fly, Crash, Burn,
f4addict's Avatar
Joined Jul 2008
from the last time i saw, the cone and the fiberglass battery tray are the same., i mean the cone goes inside the fuze i sketched a small thing to show you how it is.
Lavochkin, what's the setup you are intending to use?
Old Feb 26, 2009, 07:28 PM
lavochkin's Avatar
Joined Oct 2006
Thanks. It does answer my questions too. That is a strange design. Oh well Ill make it work.Post some vids when your done.
Old Feb 26, 2009, 07:47 PM
f4addict is offline
Fly, Crash, Burn,
f4addict's Avatar
Joined Jul 2008
i need to make it first before flying it., i'm thinking hand launching or a fixed landing gear for first couple of flights. but i have a question i was reading the manual, and it says
"First Flight.
Use a bungee to start the plane. Before start is good to use some up trim. After start level the
plane donít attempt to turn, climb and trim the plane. The mig 21 can be flown very slow with
a high AOT But never make turns with a high angle of attack (nose high position) You risk to
drop a wing."
What is AOT, and this plane is small in wing span, hence hard to see when going or coming., if you dont turn you're done, it can disappear without even noticing.
one thing i feel with het planes, wings need reinforcement. spar is not that great, i have a f4 phantom, the spar gave up and wings clapped after 138mph flight. on approach right 6-7 ft above runway.
Discussion HET MiG 21... Tram Electric Ducted Fan Jet Talk 7 Feb 23, 2009 02:44 PM
Cool Finally Mig 21!!! Andrew Jesky Electric Ducted Fan Jet Talk 3 Jan 20, 2009 01:49 PM
New Product HET Mig 21 F-86FLIER4LIFE Electric Ducted Fan Jet Talk 0 Jan 18, 2009 12:40 PM
New Product HET Mig-21 Fishbed F-86FLIER4LIFE Foamy EDFs 2 Jan 18, 2009 12:39 PM
Question HET 70mm MIG 21 FNFAL Electric Ducted Fan Jet Talk 14 Jan 12, 2009 12:38 PM
