Old Feb 25, 2009, 09:54 PM
P. Tritle is offline
Find More Posts by P. Tritle
P. Tritle's Avatar
Albuquerque NM
Joined Oct 2003
Mini-Review
Dumas 1964 Chris-Craft Super Sport
At last, the Dumas 1964 20' Super Sport is available. The 1:8 scale kit was released last week and is shipping now.
I happened to be in Tucson last weekend and stopped in to see the good folks at Dumas while we were there and picked up the long awaited kit for review. Have been looking forward to this one since I saw the p-type the last time I was in town.
The model is 30" long with a 10" beam, and is built up using a nice mix of wood and plastic. The only vac-formed part in this kit is the windsheild. This time, the seat cushions made from balsa. As with all of the recent Chris-Craft offerings, the sub-planking is done with Sintra sheets, so it should build reasonably light.
The kit is complete with all the running gear, less motor, ESC and radio components. The fitting package is mostly cast metal, and includes the flag and burgee, plus a sheet of self adhesive aluminum for the bright trim and a nice set of vinyl decals.
The hull frame is of light ply, spruce, and some balsa. The ply is dye cut, plus one sheet of laser cut balsa parts and one dye cut mahogany sheet. Also included are several dye cut styrene and Syntra sheets along with the spruce, balsa, and mahogany strip wood. In all, it's an impressive box full of parts.
And finally, a general arrangement drawing, a 47 page instruction booklet, and a 19 page supplimental packet containing 84 detail drawings round out the very nice package.
After spending a couple hours reviewing the detail drawings and instructions, it's time to start gluing parts together.
P. Tritle is offline Find More Posts by P. Tritle
Old Feb 25, 2009, 09:57 PM
LONGBIKE is offline
Find More Posts by LONGBIKE
If you cant find it Build it!
LONGBIKE's Avatar
NEAR ST. LOUIS ILL. SIDE
Joined Jan 2006
Pat ,
Are you going to let us watch you build this boat?
LONGBIKE is offline Find More Posts by LONGBIKE
Old Feb 25, 2009, 10:03 PM
P. Tritle's Avatar
Albuquerque NM
Joined Oct 2003
Staring on the Hull
The hull frame sub-assemblies are where it all begins. Several detail drawings are provided, and along with the step-by-step instructions, the assemblies go together quickly and easily.
Old Feb 25, 2009, 10:06 PM
P. Tritle's Avatar
Albuquerque NM
Joined Oct 2003
Getting Started on the Hull Frame Assembly
Hull framing begins with laminating the forward keel section, and gluing the deck sheer halves together. The instructions suggest gluing the parts together with epoxy, but I opted to go with Cya. So far, so good.
Old Feb 25, 2009, 10:09 PM
P. Tritle's Avatar
Albuquerque NM
Joined Oct 2003
Setting the Front Frames and Forward Keel.
The deck sheer is pinned to the building board and the front 4 frames glued in place. A jig is provided to set up the proper angle of the frames in relation to the deck.
Old Feb 25, 2009, 10:13 PM
P. Tritle's Avatar
Albuquerque NM
Joined Oct 2003
Fitting the Remaining Formers and Butterfly Keel
The remaining formers are glued in place, again using the jig to set the angles. Once al the frames are set, the bass wood butterfly keel is fitted and glued in place.
Old Feb 25, 2009, 10:18 PM
P. Tritle's Avatar
Albuquerque NM
Joined Oct 2003
Almost Finishing the Basic Hull Frame Assembly
The bass wood battons are fitted glued in place next. From here, the only thing left to complete the frame is to add the Chines, which are laser cut from lite ply, and at first inspection look like they're going to fit nicely. But, that's a job for tomorrow. More then.
PAT
Old Feb 25, 2009, 10:22 PM
P. Tritle's Avatar
Albuquerque NM
Joined Oct 2003
Long, I'll definitely share the details of the build with lots of photos and details.
My first impression upon inspecting the kit and looking over the instructions was that this might be a bit of a tricky one to build, but after getting a good start, I think it's going to be a typical build with a few "extras" over the last two -- the 19' Racer and the Hydro. At this point I can better understand how things are done, and now it looks like it'll be a relatively easy boat to build.
PAT
Old Feb 26, 2009, 10:47 PM
Tollytime is offline
Find More Posts by Tollytime
Tollytime's Avatar
United States, MI, Macomb
Joined Nov 2006
I tack everything together with Cya. Just little dabs here and there. Then I mix up the epoxy with adhesive filler (powdered limestone), and weld it all together using a 412 syringe. Sometimes I nail everything with a penetratring epoxy, then I weld it.
Tollytime is offline Find More Posts by Tollytime
Old Mar 06, 2009, 09:09 PM
P. Tritle's Avatar
Albuquerque NM
Joined Oct 2003
Continuing with the Basic Hull Frame Construction
The Chines are dye cut light ply, and fit nearly perfectly onto the hull assembly. A bit of trimming and beveling at the front was all that was needed as the parts are a bit oversized to allow for the bevel. The side batons are 1/8 X 1/4 spruce, and were glued in after the chines were in place.
Old Mar 06, 2009, 09:14 PM
P. Tritle's Avatar
Albuquerque NM
Joined Oct 2003
Adding the Sintra Sub-Planking
Have I ever mentioned that I really like this Sintra sub-planking? Between the Sintra and the light ply frames, these more recent Dumas offerings build much easier and lighter then the earlier stuff.
Anyhow, the bottom skins are just slightly over-size so alignment and gluing is easy. A small amount of trimming was required at the keel, but it was nothing that a couple of passes with a sanding block wouldn't take care of. Once the skins were trimmed, they were glued in place with Cya.
Old Mar 06, 2009, 09:20 PM
P. Tritle's Avatar
Albuquerque NM
Joined Oct 2003
Finnishing Up the Sub-Planking
The bottom skins were trimmed into the chines and then the side skins and transom were added. Once again, the fit was excellant, with no trimming required. After the skins were glued in place, a bead of Cya was run along the edge of each frame to secure it to the frames.
Finally, all the minor little gaps and irregularities were filled with Bondo. This part really isn't all that necessary, but this way, the sub-planking is sealed to the outside, just in case water does find a way into the hull through the outer planking.
Next step is the mahogany planking.
PAT
Old Mar 16, 2009, 11:15 AM
P. Tritle's Avatar
Albuquerque NM
Joined Oct 2003
Planking the Hull
Got started adding the mahogany planking on the hull. It starts at the bottom on the chine, adding planks inward toward the keel. Medium Cya is used to glue the planks in place.
From there, the planks are added working up the side, also starting at the chine. Up to this point, everything has gone together nicely, but here's where I ran into the first problem with the kit.
It turns out that only 40 planks were supplied, but it will take 52 to finish the planking with the 6 longest cut-off's used to add the center deck planking. If you have one of the first run kits, drop Dumas a line and they'll provide the extra wood.
PAT
Old Mar 16, 2009, 11:28 AM
Kmot is offline
Find More Posts by Kmot
Grumpa Tom
Kmot's Avatar
Joined Sep 2003
I have a question for you, Pat.
Whenever I use CA glue on any kind of wood, it soaks into the wood. As it should. But it creates a problem for me, when I want the wood to look nice on the outside. Because the CA has hardened, nothing else will penetrate the wood. Stain, varnish, etc will not go into the CA soaked spots. That leaves blemishes in the wood, especially when trying to stain it and varnish it.
How do you get around this? I can see the CA soaked spots on your planks right now. What is your method to recover from this and get a uniform color and finish on the wood?
Thanks!
-Tom
Kmot is offline Find More Posts by Kmot
Old Mar 16, 2009, 11:51 AM
patmat2350 is offline
Find More Posts by patmat2350
Vita ex Machinis
patmat2350's Avatar
Motor City
Joined Dec 2004
Can't speak for Pat T, but Pat M sez:
Try not to be messy!
But also, use medium or thick CA, it won't penetrate so far, and kick it when needed, as it won't self-kick like thin CA on porous wood.
I found that the hardest place to NOT be messy was the curvy area under the flare of the bow... and luckily, this was the area where the most wood was sanded off in fairing the planking (I always get the dreaded stair-step effect there). After sanding, I had "clean" wood to stain, worked fine.
patmat2350 is offline Find More Posts by patmat2350
Discussion Dumas 1940 Chris craft 19' barrelback riggerman Scale Boats 16 Oct 16, 2007 02:01 AM
Question Dumas 19' Chris Craft racer - Hull Painting Anton70 Scale Boats 10 Mar 29, 2006 07:25 PM
Dumas 1940 Chris-Craft Barrel Back Tom73 Scale Boats 10 Dec 18, 2005 04:28 PM
Wanted Dumas 1940 Chris Craft Barrel Back kit Airnut 2 Boats (FS/W) 0 Dec 15, 2005 04:15 AM
Dumas 1940 Chris Craft Barrel back kit richphoto Boats (FS/W) 2 May 12, 2003 09:29 PM
