Old Feb 24, 2009, 11:26 PM
rLu is offline
rLu
Find More Posts by rLu
rLu
Los Angeles
My first EDF Mig15 Look alike
Just want to share my first EDF.
CDROM Motor:
19.5mm dia. x 5mm thick
10 Pole, 9 teeth
did not record the windings
Fan: GWS 55
ESC: Phoenix 25
Receiver: AR6100E
Servos: BA3.4 elevator, ??? Airleron
Battery: Rhino 3s 1350
Fuselage: FFF,
Wings: Hot Wire cut Pink Foam,
Tail: Dolar Store foam
Wing span: 23"
Fuselage Length: 20" Fuselage only, 24" with tail
Weight: w/o battery: 230 (30g came from paint possible?)
AUW: 356g
Covering: DocuLam
Paint: Acrylic Paint (water thinned Delta Ceramcoat)
She fly very quick (but not fast). I like the sound, almost like a jet zooming by quietly. I don't know the speed. Thru, one gentlemen was flying the HP F16 with 3 cell and my MIG is somewhat the same speed. I need someone to take video for me (I don't have a video cam) before I crash and total this airplane!
So far, it has about 20 flight without me crashing.
And..thanks to adreher for posting the thread on painting with airbrush. This is my first airbursh!
rLu is offline Find More Posts by rLu
Last edited by rLu; Feb 26, 2009 at 12:39 PM. Reason: Dimensions, Covering, and Painted info. added.
Old Feb 25, 2009, 05:03 AM
Azarr is offline
Find More Posts by Azarr
RIP Azarr - "Old age is not for sissies"
Azarr's Avatar
Dayton Intl, Ohio, United States
Joined Jan 2000
Very nice!! How did you form the fuselage?
Azarr
Azarr is offline Find More Posts by Azarr
Old Feb 25, 2009, 10:53 AM
rLu is offline
rLu
rLu
Los Angeles
I taped the long edge of the foam to an aluminum tube and use a heat gun to heat the foam closest to the tube, roll the tube forward a little, and apply more heat, and roll..etc until the foam tube is formed.
Old Feb 25, 2009, 12:42 PM
rLu is offline
rLu
rLu
Los Angeles
Here is an illustration for bending a foam tube
Old Feb 25, 2009, 01:22 PM
Rusty-Gunn is offline
Find More Posts by Rusty-Gunn
My plans are in my blog
Rusty-Gunn's Avatar
Kotzebue, Alaska
Joined May 2006
This is a very nice plane.
Rusty-Gunn is offline Find More Posts by Rusty-Gunn
Old Feb 26, 2009, 10:23 AM
rLu is offline
rLu
rLu
Los Angeles
Thanks Rusty, it is a lot of fun to fly.
If I were to remake this airplane, I would reduce both the width and length of the aileron a bit. Right now, it has too much control and I already reduced the travel both mechanically and electronically. Still a little sensitive on the aileron control.
Old Feb 26, 2009, 01:02 PM
specr is offline
Find More Posts by specr
specr's Avatar
Bay Area, CA
Joined Jan 2009
Nice build. How did you get the tubes to taper at the ends?
specr is offline Find More Posts by specr
Old Feb 26, 2009, 08:12 PM
rLu is offline
rLu
rLu
Los Angeles
Specr,
The back end is easy, just cut straight cutout, 4 places. The nose cut is curved as exaggerated in the illustration. I made 4 cuts for front and back. You can do more cuts then it comes out more round. After I applied the PU glue, I used tape to warp around the tube to bring the pieces together and let it cure. After curing, with gloves, I squeezed the part to make it round and apply heat with heat gun. Let is cool and let go of the part. Finally, I sanded the tube to bring it even closer to round.
Old Mar 05, 2009, 03:42 PM
specr is offline
specr's Avatar
Bay Area, CA
Joined Jan 2009
Nice. I guess the heat does help to smooth things out. I need to try!
Old Mar 05, 2009, 04:28 PM
totalywicked is offline
Find More Posts by totalywicked
Insert comment here:
totalywicked's Avatar
Placentia, CA
Joined Feb 2006
Sweet bird did you designed it by hand or did you use some software?
Were about in LA are you? I have a video camera if you close by we can go and fly and I’ll film it for you…
totalywicked is offline Find More Posts by totalywicked
Old Mar 05, 2009, 05:07 PM
Luis_Claudio is offline
Find More Posts by Luis_Claudio
Luis Claudio - Rio - Brazil
Luis_Claudio's Avatar
Brasil, RJ, Rio de Janeiro
Joined Apr 2005
Video pleaseeeeeeeee!!!
Luis_Claudio is offline Find More Posts by Luis_Claudio
Old Mar 08, 2009, 09:14 PM
rLu is offline
rLu
rLu
Los Angeles
Totalywicked,
I'm in the San Fernando Valley area, Los Angeles. I go to the Apollo field regularly. Still have not got a video. PM me if you have time helping with the video. Thanks in advance.
rLu
Old Mar 08, 2009, 09:16 PM
rLu is offline
rLu
rLu
Los Angeles
I designed by hand and what looks good, no software.
Old Mar 08, 2009, 10:48 PM
Placentia, CA
Joined Feb 2006
RLu
am all the way down in Anaheim so it would be about an 1 hour ride for me down there....
i might be able to pull that off in a summer time, right now i am pretty busy with school and work
Old Apr 03, 2009, 06:44 PM
rLu is offline
rLu
rLu
Los Angeles
Video
Here is a video a friend of my took with his digital camera:
R/C EDF Mig15 Look Alike (2 min 2 sec)
Alfa Mig 15, My First EDF stuka Electric Ducted Fan Jet Talk 2 Aug 12, 2004 08:47 AM
Pics of my first EDF F5 Tiger 11 RCKing Electric Ducted Fan Jet Talk 5 Dec 30, 2003 12:57 PM
Pibros Twinn EDF-50 "My first EDF project" Appie Electric Ducted Fan Jet Talk 13 Oct 25, 2002 04:57 PM
Got my first EDF - T33 Wantab Electric Ducted Fan Jet Talk 8 Feb 02, 2002 10:15 PM
My First EDF Which one... kepople Electric Ducted Fan Jet Talk 8 Jun 30, 2001 01:43 AM
