Old Feb 24, 2009, 02:39 PM
John Kim is offline
Find More Posts by John Kim
Panorama City, CA
Joined Sep 2004
Difference between FHSS and DSSS
The following explanation was picked up from internet. Posted here because it is easy to understand.
"In theory, FHSS is a bit more reliable (less prone to "jamming"), but slower (and I mean in theory). FHSS was a military development, as it was more difficult to eavesdrop a transmission changing frequencies all the time, but it was not designed with very high bandwith, transmitting speed or model aiplanes in mind. DSSS is faster as there is no timeloss for frequency changing, but easier to "jam" for the same reason (in theory) "
John Kim is offline Find More Posts by John Kim
Reply With Quote  (Disabled)
Old Feb 24, 2009, 03:08 PM
Daemon is online now
Find More Posts by Daemon
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
There's only one problem with that simplistic explanation. It's completely
irrelevant to R/C SS systems. FHSS systems are no slower than DSSS
at getting relevant control inputs from the Tx to the Rx, and in fact
are faster than the average in actual measured latency.
http://runryder.com/helicopter/galle...y_24GHz_18.gif
Notice that all Futaba FASST and Airtronics FHSS gear are faster than the median.
ian
Daemon is online now Find More Posts by Daemon
Old Feb 24, 2009, 03:11 PM
ebill3 is offline
Find More Posts by ebill3
ebill3's Avatar
United States, WA, Puyallup
But gee whiz, since it was on the internet, it must be accurate (in theory).
Bill
ebill3 is offline Find More Posts by ebill3
Old Feb 24, 2009, 03:18 PM
AndyOne is offline
Find More Posts by AndyOne
Oxford Panic
AndyOne's Avatar
United Kingdom, Oxford
Joined Feb 2003
That explanation sounds a bit over-simplified. The bandwidth needed for model control is well within the capabilities of FHSS after all Futaba use it in their system successfully enough.
The explanation I prefer for the difference between FHSS and DSSS is...
FH means Frequency Hopping which is a fairly easy concept but DS, Direct Sequence is actually means switching the phase of the carrier RF by 180° in time with the code.
These may seem like completely different techniques but I'm informed by the theoreticians that mathematically the results aren't that different. In both systems the RF is spread over a large bandwidth in a defined pattern that to the casual observer will look like slightly more noise in that part of the spectrum.
Applied to model control there is plenty capability in either technique to make a perfectly usable system. What really matters is the resources put into the design and the quality of the components as this has a far greater effect on the reliability of the system.
Andy.
AndyOne is offline Find More Posts by AndyOne
Old Feb 24, 2009, 04:29 PM
tune by tito is offline
Find More Posts by tune by tito
Inventor&Genius Extraordinary
tune by tito's Avatar
USA, CA, Riverside
Joined May 2006
WirelessUSB™ LS Theory of Operation
read this PDF file...........
best regard tito
tune by tito is offline Find More Posts by tune by tito
Old Feb 24, 2009, 04:37 PM
richard hanson is online now
Find More Posts by richard hanson
richard hanson's Avatar
United States, UT, Salt Lake City
Joined Oct 2007
The theory stuff is really much ado about nothing -a far as the current 2.4 systems are concerned
the fastest SYSTEM is the setup such as the new DX7SE uses
can YOU tell the difference in this and the fastest system by anyone else?
Show me
then show me what systems are used by the heli flyers who really do the wild on the deck constant flight changing sequences
The DSM2 systems I have seen are the most commonly chosen for this stuff.
Why?
take a guess.
richard hanson is online now Find More Posts by richard hanson
Old Feb 24, 2009, 06:45 PM
coro is offline
Find More Posts by coro
Slovakia
Joined Apr 2005
in fact, standard SERVO understand the signal consisting of one pulse, 1 to 2 miliseconds wide (1.5ms means center position), which repeats every 20 miliseconds.
Some systems are repeating this pulse a bit faster, for example FASST uses 16ms..
Some systems are configurable, but the best is if they are direct copying the TX.
Some servos fail if pulse is repeated too fast, for example HS-81 stop working at 14ms.
Ordinary receivers in MHz band, those without any internal processing of signal, were passing the incoming signal out to servos directly with zero delay.
My 2.4 GHz system has 2.5ms delay between input to system in tx, and output to servo in rx, specified in parameters.
Some transmitters are spending quite a lot of time by oversampling an filtering measured values of stick positions, and perhaps also by computing various mixes. There is the most of delay.. Another tx is wasting almost no time, and sends information out with extremely low delay. It is funny that both slowest and fastest TX measured in test mentioned above, are the same brand..
Of course, the pure analog ancient tx was not tested at all, as there is almost zero delay. Same as it was in pure analog MHz rx.
http://www.runryder.com/helicopter/t172571p1
Funny point for today: DX7SE seem like it was tested without receiver...?
Well.. except a case of extremely slow tx, there is no system that could improve latency in noticeable amount, using ordinary (as for signal rate) servos. You need special digital servos such as those heli tail servos directly driven by gyro, using much faster frame rate, to start even talking about TX latency.
All the hype concerning speed of 2.4 systems, come from the fact that servos are not driven at the same time, but they are driven one by one, which casuse problems in CCPM of extreme 3d heli.. most of 2.4 systems are faster than PCM was..
There are receivers which are designed specificaly for CCPM, they sends out commands for 3 servos at the almost same moment (but still not exactly at the same moment, as it causes troubles with way too high momentary load current in helis, and consequent voltage drop at receiver)..
coro is offline Find More Posts by coro
Old Feb 25, 2009, 03:45 AM
vintage1 is offline
Find More Posts by vintage1
vintage1's Avatar
East Anglia, UK
Joined Sep 2002
Futaba isn't FHSS. Its a multi channel frequency agile DHSS schema..
FHSS was the early way to do spread spectrum..it was easy to shift (narrow) channels and use a lot of narrow band channels. In a wide band of narrow channels..so to speak.
DHSS spreads the spectrum by modulating with a very high subcarrier frequency driven by a particular spreading code. That smears the data across about a 5Mhz band (generally referred to as a channel!!), and AFAIK all 2.4Ghz sets use this technology. The differences are that Spectrum uses twin transmitters on two 'channels', and Futaba uses all 'channels' sequentially. Most of the rest simply use a single channel, and rely on the different spreading codes, and digital codes in the data frames, to sort the tangle out ..
There are only half a dozen or so channels on 2.4Ghz. Not sure, so dont take my word for it.
The 'specifications' say nothing beyond the fact that any given transmitter shouldn't transmit more than a certain amount of average power per channel.
Old Feb 26, 2009, 03:09 PM
Julez is offline
Find More Posts by Julez
Proud to eat Kraut ;-)
Julez's Avatar
Germany
Joined Dec 2003
It is of no concern for our RC systems whether they are FHSS or DSSS latency-wise.
What counts, is the internal processing speed of the TX and RX electronics and the frametime.
The TX samples the stick positions, encodes them, sends a packet, the RX decodes it, and gives the pulses to the servos.
Whether the next packet is on the same frequency (DSSS) or on a different frequency (FHSS) does not really matter.
The electronics will work just at the same speed, regardless of the frequency in use.
The time required to switch frequencies is absolutely negligible, and as it can happen in the pauses between the bursts, it does not count one bit.
Besides, I don't know of any RC system being a pure FHSS system. They are all DSSS systems, which hop on top of that, and thus combine the advantages of both methods.
Julez is offline Find More Posts by Julez
Old Feb 27, 2009, 01:02 AM
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
Airtronics claims they're pure FHSS. Anyone have any solid info
that would prove otherwise?
I can say this. The Airtronics FHSS signal *looks* very different when
stepping on top of an analog 2.4Ghz video channel. Attached are a couple
images showing the difference. This represents interference to the video
transmission in the time domain (each frame takes 33ms to transmit
including the blanking interval), so what you see with FASST is two
short DSSS packets transmitted inside of 20ms or so. If it's hopping
channels between the packets, it's doing so on two channels close
enough that they're both overlapped by the fatter video channel
(which spans about 1/8th of the whole 2.4Ghz band)
With Airtronics FHSS, you can see one much longer diffuse packet.
The odd thing I noticed is that FHSS steps on the video channel
almost constantly. I see its two packets in almost every frame
of the video, while Airtronics FHSS seems to spend more time
hopping on non-overlapping channels and only comes back to
step on the video's channel every couple seconds.
Videos and images of all the 2.4Ghz systems I've tested this way here:
http://www.thud.us/videos/rc/2.4/
Stepping through the vids a frame at a time with something like
VirtualDub is intesting (at least to me).
ian
Old Feb 27, 2009, 12:02 PM
Danal Estes is offline
Find More Posts by Danal Estes
Flys with Thumbs
Danal Estes's Avatar
Frisco, TX, USA
Joined Sep 2001
No such thing as a pre-defined channel on the 2.4 band.
Think otherwise? Then show me where it is defined.
Meanwhile, look at 802.11 and their "channel" layout (not pre-defined by the band, THEIRS). It is very different from Spektrum's definition of a "channel", which is different from Futaba's, etc.
Each is free to define their own... not pre-defined... which makes the use of the word "channel" in 99.99 percent of these forum posts very misleading.
You are right about the smearing, it called "spreading" and is REQUIRED to be on 2.4 band. However, when coupled with each tech defining their own "channels" it means the smear is across a different width...
Danal Estes is offline Find More Posts by Danal Estes
Old Feb 27, 2009, 01:20 PM
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
Actually the smearing is not required to operate on the 2.4Ghz band.
There's a lot of narrow band analog 2.4Ghz equipment, but it must operate
at lower power levels to be Part 15 compliant. And true FHSS doesn't
have to transmit any single packet over a fat DSSS style channel. It could
transmit a very narrow band signal, as long as it then hops away
somewhere else quickly. The net effect is that the accumulated
transmission over time is spread over the whole band, but at
any given moment it might be both narrow band and high power
output.
As for channels.. yes, each application and each chipset defines
the size, shape and distribution of channels across the 2.4Ghz band.
XPS/Jeti has 16 channels (The fewer the channels, the fatter they are)
Spektrum has 80 channels
FASST has 31-32 channels (dunno about Airtronics FHSS)
analog 2.4Ghz video uses about 8, but each manufacturer often uses
different non-standard (as in there is no standard) center frequencies.
ian
Old Feb 27, 2009, 02:23 PM
John Kim is offline
Panorama City, CA
Joined Sep 2004
Price will be a determining factor
All technical discussions above sound like mantra to horse's ear.
Pros and cons arguments will continue forever.
I tested both FHSS and DSSS systems. They all worked well.
The final factor in selecting the brand is the price, especially receivers.
If you need several extra receivers, $100 a piece is too expensive.
And here come Chinese-made receivers costing $20 each, either FHSS or DSSS.
There are several brands already on the market; Corona, Assan (both marketed by Hobby City), iMax, etc.
There is now a 9 ch. 2.4G radio priced $100 entering market soon. One brand is already being sold at $180.
http://www.bidproduct.com/part/Produ...YSTAL_174.html
That will force the price of competing established brands down.
Old Mar 10, 2009, 06:43 AM
AlexinOz is offline
Find More Posts by AlexinOz
Australia, VIC, Melbourne
Joined Jan 2009
Hi all,
Very interesting dialogue taking place. I'm interested in reading the contents of my DX7 frames (I'm a network specialist in the day so love this stuff).
Any suggestions on software / hardware that is required? Ideally I'd like to use my 2.4Ghz wifi card on my computer to do the scan if possible. I saw a brilliant post a while back at this below URL and essentially want to capture something similar.
http://www.rcgroups.com/forums/showp...33&postcount=8
Thanks in advance and keep up the great discussion!
Cheers
Alex
AlexinOz is offline Find More Posts by AlexinOz
Old Sep 01, 2013, 12:15 AM
loserdave is offline
Find More Posts by loserdave
Registered Loser
loserdave's Avatar
Joined Feb 2008
humm.. i always thought my 72mhz was pretty fast ) never noticed any lagg in it.
loserdave is offline Find More Posts by loserdave
Difference between 6v and 7.2v speed 400 engines??? soholingo Beginner Training Area (Aircraft-Electric) 13 Jul 20, 2001 10:50 PM
Is there a difference between the CP1700 and 1700AE cells? razzor7 Electric Plane Talk 23 Jun 28, 2001 06:38 PM
What is the difference between JR and Hitec servos foam_man Beginner Training Area (Aircraft-Electric) 1 Jun 25, 2001 07:38 AM
What is the difference between the Jarma480 & the Multiplex480? Scott C Electric Plane Talk 1 Jun 20, 2001 07:32 AM
Difference between gws s and dx boxes geebee Parkflyers 0 May 10, 2001 07:52 AM
