Old Aug 15, 2009, 09:35 AM
fats_nz is offline
Find More Posts by fats_nz
fats_nz's Avatar
Nelson, New Zealand
Joined Jun 2008
Thickness cord ratio
The last two nights I have been shaping the keel. I spent far to much time at work doing it, I know this due to the dirty look my boss gave me when he saw me at my tool box knee high in wood shavings.
anyway it is now shaped and im happy with it I think.
The thickness of the keel is 12 mm and the cord length varies between 72 mm and 145 mm. as you can see by the photos it tapers up at the top. I cant help but think I have made it too thick, does anyone have any suggestions. I cant go any thinner due to the design so if it is too thick I may be starting again. remembering that the bulb is 4 kg.
another thought I had regarding the rudder was to copy the design off the ETNZ. it is a nice looking piece of kit. now the etnz is 30% smaller in waterline than the IONA. If I wanted to scale up the rudder for IONA do i scale length and width evenly?
fats_nz is offline Find More Posts by fats_nz
Old Aug 15, 2009, 01:16 PM
Aerominded is offline
Find More Posts by Aerominded
Monterey Bay California
Joined Feb 2004
Originally Posted by fats_nz
Its hard work living in paradise!
Nice view from the shop!
Keel is looking really nice! Re: the rudder, I've not looked closely at an ETNZ, but if you like the looks of the rudder, could be worth a try... it probably will work fine but if not, rudders are easy to replace!
Aerominded is offline Find More Posts by Aerominded
Old Aug 15, 2009, 06:03 PM
fats_nz is offline
fats_nz's Avatar
Nelson, New Zealand
Joined Jun 2008
thanks, I think you are right- just do it and see what happens.- what could possibly go wrong!
Old Aug 15, 2009, 06:31 PM
Vince Hoffmann is offline
Find More Posts by Vince Hoffmann
Vince Hoffmann's Avatar
Hayward, CA
Joined Jan 2009
Nice work on your boat! Your rudder looks a lot like the one I made for my Newport 12M. Mine is Oak and Mahogony...
Vince Hoffmann is offline Find More Posts by Vince Hoffmann
Old Aug 15, 2009, 07:06 PM
fats_nz is offline
fats_nz's Avatar
Nelson, New Zealand
Joined Jun 2008
hi, that looks great. This is the keel, i havnt started the rudder yet.
Old Aug 15, 2009, 09:14 PM
ooby is offline
Find More Posts by ooby
ooby's Avatar
Joined Jan 2006
ooby is offline Find More Posts by ooby
Old Aug 15, 2009, 09:15 PM
ooby is offline
ooby's Avatar
Joined Jan 2006
Last edited by ooby; Aug 15, 2009 at 09:18 PM. Reason: sorry, misread the question
Old Aug 19, 2009, 08:09 AM
fats_nz is offline
fats_nz's Avatar
Nelson, New Zealand
Joined Jun 2008
Mock Up
Here is a rough mock up of the boat in the cradle with the keel sitting behind the boat. It certainly demonstrates its size.
on the desk to the right you can just make out the keel, rudder and bulb of my new micro magic.
Old Jan 21, 2010, 12:27 AM
fats_nz is offline
fats_nz's Avatar
Nelson, New Zealand
Joined Jun 2008
The keel box
Once again its been along time since i have had the time to get into the workshop. Im on 2 weeks annual leave so the goal is to finish the keel box.
The keel box I want has to do several things.
#1 watertight
#2 have the facility to move the keel foward and aft to assist tuning.
#3 be easy to install or adjust keel.
What i have done is built a wooden box. it is 30mm longer than the keel to facilitate moving it forward or aft for tuning. The keel now has three positions center, 15mm fwd or 15mm aft. i have inserted brass bushes into the keel box, keel, and two spacers. Closly matched pins slip through the bushes and hold everything in place ( in the photos im using drill bits ) to move the keel you simply pull out the pins and move it into the desired position. the two bushes are used to fill the gap that the keel does not occupy. i.e 1 fwd 1 aft. 2 fwd or 2 aft. It is a lotter simpler than it sounds! the bushes and the pins are closely machined to stop water ingress.
This is something a bit different the the normal thread sticking through the top with a nut to retain the keel- this should be bullrt proof! the idea of having an adjustable keel is copied from the micro magic.
Enjoy
Old Jul 28, 2011, 04:53 AM
fats_nz is offline
fats_nz's Avatar
Nelson, New Zealand
Joined Jun 2008
well its been 18 months since I have done anything to the boat but Iv had a moment of inspiration.
I have started shaping the bow from cedar. This is made by laminating two piece together between some thin ply. The photos are only very rough but im getting there. Its a process of shaping it slowly with a knife.
The rudder has been laminated together and now needs shaping. Its the same process as the keel. Laminated cedar and walnut between ply.
Its been very cold here in Nelson NZ recently. The last picture is taken across the bay from our house towards the Able Tasman National Park. Its very rare to get snow so close to the ocean.
Old Jul 28, 2011, 11:40 PM
fats_nz is offline
fats_nz's Avatar
Nelson, New Zealand
Joined Jun 2008
Rudder shaped today and rudder post hole drilled. The rudder shape is similar to the Americas cup boats, i don't think it looks out of place.
photos taken of mock up
Old Jul 28, 2011, 11:53 PM
8387mike is offline
Find More Posts by 8387mike
8387mike's Avatar
Perth Western Australia
Joined Jul 2009
Hi Fatz,
Where was the photo of the snow of? being from Nelson love seeing the photos of my old home town.
Regards
8387mike is offline Find More Posts by 8387mike
Old Jul 29, 2011, 12:14 AM
fats_nz is offline
fats_nz's Avatar
Nelson, New Zealand
Joined Jun 2008
Hi Mike,
It is taken from my house in Atawhai across the bay to the Able Tasman National Park.
Cheers
Hamish
Old Jul 29, 2011, 12:54 AM
8387mike is offline
8387mike's Avatar
Joined Jul 2009
I used to live in Atawhai, we lived on Atawhai cres and my father renovated the house and built 2 units on the section next to the creek. I went to Clifton hts primary school before we moved to Australia.
Old Jul 29, 2011, 01:18 AM
fats_nz is offline
fats_nz's Avatar
Nelson, New Zealand
Joined Jun 2008
its a small world, we live on Allisdair Street. I can see Clifton Tce primary from my house.
U2 Glider Conversion Scratch Build Questions cactus Electric Sailplanes 6 Feb 14, 2002 07:10 AM
Scratch build question Steph280 Beginner Training Area (Aircraft-Electric) 7 Nov 02, 2001 04:30 PM
Scratch build - kit build - or ARF? hardlock Foamies (Kits) 16 Oct 12, 2001 04:05 AM
Want to scratch build a fun fly plane. Cay you recommend plans? WilliamSettle Sport Planes 4 Oct 04, 2001 11:29 PM
My first Design Scratch Build Project Heather Electric Plane Talk 20 Jul 22, 2001 11:03 AM
