Old Feb 23, 2009, 09:34 PM
kkant is offline
Find More Posts by kkant
Joined Aug 2007
Question
Simultaneously charging series packs with two chargers
I have two lipo packs hooked up in series, and I'd like to avoid having to disconnect them from each other when charging. Can I charge them separately with two lipo chargers, when both chargers are using the same power source? How about if the 12V sources are isolated? My chargers are Hyperion EOS610i's. Here is a pic to describe what I am trying to do:
kkant is offline Find More Posts by kkant
Old Feb 23, 2009, 10:59 PM
rebell is offline
Find More Posts by rebell
JustFlying
rebell's Avatar
Joined Dec 2005
Yes, you indicate the problem yourself.
Lots of info on series and parallel charing here: http://www.rcgroups.com/forums/showthread.php?t=932319
rebell is offline Find More Posts by rebell
Old Feb 24, 2009, 08:26 AM
kkant is offline
Joined Aug 2007
Will it work if I isolate the 12V power supplies, i.e. have two separate 12V batteries with isolated grounds?
BTW I did look at that thread in my searches, very informative. But in this case, simultaneous parallel charging won't work, since I'd have to disconnect the series connection anyway. Simultaneous series charging might work, if I made adapter cables for the taps (no big deal) and could find a 10A charger with a true 300W output (seems unlikely).
Old Feb 24, 2009, 09:13 AM
coro is offline
Find More Posts by coro
Slovakia
Joined Apr 2005
Yes isolated power supplies will work, e.g. two lead acid batteries.. Be careful before trying two mains power supplies, first check whether they are not connecting output to mains ground or induce some voltage against ground. It may act as a common ground of them, killing the charger(s).
It would be much easier, if You split the pack into two separate 6s parts.
coro is offline Find More Posts by coro
Old Feb 25, 2009, 11:01 AM
kkant is offline
Joined Aug 2007
Sounds good. Thanks for the info.
Discussion Charging TP lipos with other chargers besides TP. modfly Coaxial Helicopters 0 Jun 21, 2008 10:53 PM
Help! Charging NiMH packs with Swallow EQ Charger lobel Batteries and Chargers 1 Feb 17, 2008 01:50 PM
Discussion Charging Multiple Packs with CellPro or BalancePro Charge Protection Modules green66 Batteries and Chargers 0 Aug 04, 2007 09:04 PM
Charging multiple packs with Triton?? Astro30 Batteries and Chargers 5 Sep 23, 2004 06:56 AM
Schulze chargers eliminate the need for slow-charging new packs? (B. Cawley's review) Balin Batteries and Chargers 14 Jul 18, 2002 06:28 PM
