| RCCars | Crack Roll | Flying Giants | RC Power | The E Zone | Lift Zone | Our Sponsors | |||||||||||||
GREAT PLANES PERFORMANCE SERIES® EXTRA 300 SP ARF Review
Great Planes’ new line of Performance Series® ARFs have really taken the RC community by storm over the past couple of years. With the immense popularity of their Reactor, Cap (232 & 580), Ultimate, Edge 540, and, SU-31, and now a couple versions of the Extra, Great Planes has just about any kind of RC airplane for the sport/aerobatic pilot. The new GP Performance Series Extra 300 SP ARF is a next generation redesigned airplane that offers large scale performance in a .40 sized package. The Great Planes Performance Series® Extra 300 SP ARF gives the builder the option to fly it either with electric or glow power, and both setups are covered quite extensively in the included detailed manual. The Extra 300 SP ARF comes with a very complete and high quality hardware package that allows you to have this plane from box to the flight line in 6-8 hours. Let’s go through the building and flying of this awesome new addition to the growing line of Great Planes Performance Series® ARFs.
My Great Planes Performance Series® Extra 300 SP ARF arrived in a highly detailed box with an excellent boxtop picture of the finished airplane. I was immediately impressed by how well the Extra 300 SP parts were packed and protected from damage. I was thrilled to see that the monokote was nearly wrinkle-free. I gave the covering a quick once-over with the heat gun after letting the parts adjust to the Ohio temperatures. The Great Planes Extra 300 SP kit contains:
The Great Planes Extra 300 SP kit requires:
Items used to complete the Great Planes Performance Series® Extra 300 SP:
Here is the product video that is posted on the Great Planes website. Just something to tide you over till the end of the review!!
Futaba 9650 Mini Digital Servo
The Manual
Great Planes has always been a leader in providing product manuals that are extremely detailed and leave the builder with little doubt on how a step is to be completed, and the manual for the Extra 300 SP is no exception. I found it very helpful during the build. It provides clear photo-illustrations for each step of the assembly. The manual clearly lays out the starting CG location and gives the builder safe forward and aft CG locations depending on how one would like to fly the plane. The manual goes into full details on how to set up the Extra as electric or gas, and the required hardware is included in the kit for either configuration. It's fantastic to see Great Planes’ commitment to quality in providing a manual that is as clear, concise and detailed as the one provided in the Extra 300 SP kit. KUDOS!
Wings
The Great Planes Extra 300 SP has very distinctive covering on the top and bottom of the wings to help with orientation. I found the blue and yellow covering scheme presented very effectively in most all sky conditions and the chord length strips on the bottom of the wings showed up quite easily even during cloudy/overcast sky conditions. The aileron setup for the Extra 300 SP begins with removing the hatch covers from the bottom of the wings and gluing in some hardwood blocks. To handle the work load of the ailerons I selected a couple of Futaba 9650 digital servos. These mini digital servos fit great on the servo hatch covers, and I was also able to use the long servo arms that came with these servos to get full bevel-to-bevel 3D throws on the ailerons. I really liked the short direct push rod linkage setup on the Extra 300 SP. It allows for a slop-free setup, and with the hatch covers in place allows for a very clean finished look.
Tail & Fuselage
One look inside the Extra 300 SP and you will automatically see that this is just not some typical ARF Extra. The fuselage is very light weight, constructed entirely of light weight balsa and plywood. The fuselage from the radio tray back is really nothing more than formers and stringers with a sheeted balsa turtle deck. The battery tray in the Extra 300 SP allows for both mini and standard sized servos. Each servo bay is laser etched so that pretty much any mini servo will just slide right in. However, if you want to use standard sized servos you can do so simply buy cutting along the laser etching and removing a small piece of plywood. I really like this idea; it gives the pilot the option to use either size servo.
I decided to use a single Futaba 9650 digital servo for the elevator. This little servo packs plenty of torque (50 oz.-in. on 4.8V / 63 oz.-in. on 6.0V) and I knew it would work great in the Extra 300 SP. For the rudder I opted to use a Futaba 9252 digital servo. This did require me to remove a small portion of the servo bay in the radio tray to allow this standard size servo to fit properly. This only took a few minutes to do thanks to the laser cut etch marks in the radio tray (see picture above). The Extra 300 SP has pre-installed rudder and elevator pushrod guides that make it easy to run the pushrods back to the tail of the plane and exit out the correct locations. Just like on the ailerons I was able to use the stock long servo arms that came with both the rudder and elevator servo to obtain full 3D throws on both control surfaces. I really like the fact that Great Planes incorporated airfoiled tail surfaces into the Extra 300 SP. Both the elevator and rudder on the Extra 300 SP are airfoiled which even on this size of model definately improves both tracking performance as well as pitch authority. It's not often you see an airplane of this size have airfoiled tail surfaces. I really applaud Great Planes for including this feature on the Extra 300 SP as it's just one more feature that gives this airplane that "larger" more solid feel in the air.
Motor and ESC Installation
Power By Rimfire
To handle the power up front I went with the recommended GP Rimfire .80 brushless motor. This motor can really haul the mail in the Extra 300 SP, and I'm completely happy with how it has performed with well over 40 + flights on the Extra 300 SP. The Rimfire .80 brushless motor was bolted on to a GP brushless motor mount which did require some dremeling to get the correct distance for the cowl/spinner back plate spacing. The whole process took maybe 10-15 mins. before I was ready to mount the Rimfire motor to the motor mount. The motor mount lined up beautifully with the pre-installed blind nuts in the motor box. I mounted the GP Silver Series 60A High Voltage ESC directly under the motor box to provide sufficient air flow for cooling. This setup has worked flawlessly, and the ESC stays right around ambient temperature even during high throttle application flights. Because the GP Silver Series 60A High Voltage ESC is an opto speed controller I did solder a Castle Creations 10A BEC on the ESC to eliminate the need for a separate receiver battery pack. This little gem has a selectable output voltage from 4.8-9.0V, and with my Castle Link I was able to program a 6.0V output voltage. This setup has been bulletproof, and I would highly recommend it to anyone with an opto speed controller.
Canopy Hatch and Radio Installation
The Great Planes Extra 300 SP utilizes a very unique hatch locking setup. The canopy system uses a set of powerful magnets and plywood slats that lock the canopy in place. This system works great, and I have really pushed the plane to see if I could get the canopy to eject in flight but the setup has held up perfectly. It allows quick access to the radio compartment, and there are absolutely no worries of the canopy coming off when it is properly locked in place. The canopy on the Extra 300 SP needs to be screwed onto the hatch assembly. While this method works fine I have found that over time the canopy will start to warp (buckle) when the plane is left outside especially on hot summer days. I think a better alternative would be just to use a canopy glue such as Pacers 560. This glue dries clear and holds up great. I have used it on many canopy applications in the past with excellent results. The radio compartment in the Extra 300 SP is very spacious for this size airplane and there is plenty of room on the radio tray for the elevator, rudder and rx.
I was completely thrilled with how my Great Planes Extra 300 SP ARF looked once I had it finished!! The color scheme shows up very nicely, and the finished lines of the Extra were definitely very pleasing. I opted to spray the canopy silver to give it a very distinctive appearance. The kit does come with a cockpit instrument panel decal that can be applied that gives the plane a more scale look inside the cockpit. My finished Extra 300 SP ARF came in at an AUW of 6.5 lbs, right at the high end of the manufacturer’s specs. While I was hoping for a little lighter finished product I was sure that with the power setup on board the plane would have more than enough mojo for pretty much anything I commanded it to do. My CG was initially set to the recommended 3.75" from the leading edge measured at the wing root but after a few flights I was able to move it back to close to 4" by sliding my battery packs aft on the battery tray. This slightly rearward CG definitely better suited my flying style.
I set up the control surfaces per the manufacturer’s recommendations. On this particular plane though I have not changed my settings from what the manual has indicated. For me they were spot on!!!! Control throws setup on my GP Extra 300 SP
FlyingBasics Including Takeoffs and Landings
Power Setup Number
The Extra 300 SP is super easy to transport to the field thanks in part to its two piece wing design. Once at the field the Extra's wings ride on a very light weight yet robust carbon fiber wing tube, and the wings are held in place by just two thumb screws. This makes the Extra flight-ready in only minutes which means more flight time... and we could all use more flight time!!!! After installing both of the (2) GP Electrifly 3s 3200mah (20C) lipo packs I connected them to a series harness and slid the canopy in place. In no time, my GP Extra 300 SP was ready to take to the skies. The Extra taxis effortlessly thanks to a solid tail wheel setup and more than ample rudder authority. This makes the Extra feel right at home on either grass or paved runways. The power setup in my Extra 300 SP provides TONS of power, and this can definitely be seen during the short takeoff runs made at full power. The Extra 300 SP accelerates very quickly at full power which leads to very steep (make that vertical) climb outs. You can actually perform very scale takeoffs with the Extra at around half throttle which provides more scalelike climb outs as well. On low rates the Extra 300 SP is very stable and provides positive response in all axes. I found the ailerons to be very effective, and they provided near axial rolls in both directions. The Extra 300 SP tracks extremely well, and while using the low rate elevator settings, I found there was no need to chase the nose of the plane because it went exactly were I told it to go. The large rudder on the Extra does an AWESOME job of keeping the Extra 300 SP tracking straight lines during windy conditions which is great for those of us who love flying precision aerobatics. The Extra 300 SP has a very clean look, and it shows in the air. The thin aspect ratio airfoils really allow the plane to penetrate the wind and also allow the Extra to carry some energy into aerobatic tumbling maneuvers. Landing the Extra 300 SP takes a little planning due to its clean design. I have found that a longer, shallower approach works very well with this airplane. The Extra 300 SP control surfaces stay very effective even at very slow speeds so there really is no fear of premature tip stalling as long as the plane is flown all the way down until the flare. When setup properly for landing, it will reward you with a nice 3-point landing nearly every time.
The Great Planes Extra 300 SP is fully capable of both precision and 3D aerobatics. This is the best of both worlds for me as I enjoy flying an airplane that is capable of flying IMAC style precision aerobatics and at the flip a switch is able to fly DOD (down on the deck) style of 3D flying. If this is your flying style as well then you will be very pleased with the performance of the Extra 300 SP. I was initially concerned with the finished weight of the Extra and the somewhat higher cubic wing loading on the plane but to my surprise, the Extra 300 SP carries the slightly higher weight just fine. It allows for some CRAZY tumbling maneuvers and very clean and sharp high speed snaps. I've put together a list of some of the many aerobatic and 3D maneuvers that I've flown with my Great Planes Extra 300 SP and my thoughts on how I thought the airplane performed flying each of them. Many of these maneuvers are featured in the video listed below.
No. While the Great Planes Extra 300 SP can be set up on low rates to fly in a pretty docile way it does not possess the self leveling characteristics found in most of today's trainers. The Extra 300 SP is better suited for intermediate to advanced pilots who are looking to refine their skills with a highly aerobatic/3D sport airplane.
Photo Gallery
Flight Video
The Great Planes Performance Series® Extra 300 SP is a really terrific looking and even better flying precision/3D aerobatic airplane. With its ease of assembly and detailed manual, most any experienced builder/flyer will be able to assemble this airplane in only a few hours. The Extra 300 SP's performance on the recommended power setup will definitely please even the most power hungry pilots: The unlimited vertical climb outs can be very breathtaking to say the least. I have really been enjoying taking my Extra 300 SP out to the flying field. It seems to get a lot of attention from the other members, and I've even let a few of them fly it as well. The guest pilots always comment on how solid the plane feels in the air and how quickly they became comfortable flying it. If you’re looking for an Extra 300 that can provide it all - portability, flyability, stability, and is just plain fun to fly you owe it to yourself to take a good look at the Great Planes Performance Series® Extra 300 SP.
Pluses:
Minuses:
Thread Tools |
#2 |
great looking great flying plane but i want to point something out
recently a guy at our field and his son built one of these.. the young man was flying it and all at once on a fast pass the ailerons started to flutter badly ... broke the control rods we narrowed it down to the gap between the aileron and the wing... it was built as per instructions using all the stock parts the fix was of course simple ... put some covering over the gap so air can't go through stopped the flutter and the control rods are made of some very soft material other than those 2 issues "which are easily remedied" this is an amazing plane |
#3 |
Balsa just crashes better
Great review Tim- The color scheme really pops and she looks great in the air.
looks like a very solid airframe Cub Fan |
#4 |
I got one of these 3-4 months ago, I was very pleased at the quality of the plane and materials, and the decals were pre cut which is pretty rare these days. Mine flies very nicely on a OS Max 46AX, has plenty of power, and has done any maneuver I have asked of it. I have not experienced any flutter at all, even on wide open throttle dives, so the flutter mentioned by a previous poster can likely be connected to the builder rather than the plane. The yellow really pops and makes the plane easy to see.
The plane is pretty rugged, I did an outside snap too low and the plane smacked the ground pretty hard, it bent the wing tube and badly bent the aluminum landing gear, but there was essentially no other damage, and I was able to straighten the wing tube and gear and the plane was good as new. A lot of the newer planes are built so light that they are easily damaged, I've seen a lot of planes rip their landing gear out very easily, but this plane took that smack, bent the gear way back, but it didn't damage the gear mounting at all. Its a very sturdy plane! The plane in the photos has a silver canopy, but the canopy furnished with the plane is clear, and the cockpit area is finished, a control panel decal is included with the plane, and it would look really nice with a pilot figure which you could purchase separately. |
#5 |
Wow 3" more wingspan then the Eagle 580/Edge 540t and the weight more then doubles...I'd probably run it on a Saito .82 before going electric.
#6 | |
God is my co-pilot.
Thanks!! ![]() Tim |
#7 | |
God is my co-pilot.
The Extra 300 SP is not part of Great Planes/Electrifly's Extreme Light Concept (XLC) series of airplanes. http://www.electrifly.com/pflyerindex.html The Extra 300 SP was built for both glow and electric power setups. The XLC series of airplanes are built purely for electric setups hence the lighter construction. Tim |
#8 |
Who turned out the lights?
Great job Tim!
#9 | |
God is my co-pilot.
Thanks Kevin!! ![]() Tim |
#10 |
USAF Retired
Way to WRING it out!
Great job Tim! I hate it when reviewers don't put these 3D planes through their paces. You certainly left nothing in the box! Thanks!
Troy |
#11 | ||
God is my co-pilot.
Ha, thanks Troy!! 3D planes are ment to 3D. The Extra 300 SP is a very capable 3D/precision performer which definately makes my job a little easier. ![]() Quote:
Tim |
#12 |
Great job Tim!
#13 | |
God is my co-pilot.
Thanks George!! Thanks to you and GP for producing yet another outstanding product. ![]() Tim |
#14 |
You'll shoot your eye out!
Nice flying Tim. I don't usually think of Great Planes when I think of 3d....but it looked like it did well....even if it is a smidge on the heavy side.
#15 |
War Eagle!
Wonderful review, Tim —*very nicely done! You definitely have a God-given talent when it comes to flying 3D. Well done on all counts!
And you're right — this Extra 300 is one lean, mean, tumbling machine!
| Thread Tools | |
| Article Electrifly Ultimate Bipe EP 3D ARF Review | dawnron1 | Parkflyers | 275 | Today 12:07 AM |
| Article Great Planes ElectriFly Yak 55 EP Nearly Indestructible FlightFlex Foamie ARF Review | Jim Young | Ezonemag Archive | 33 | Sep 14, 2009 08:39 AM |
| For Sale Simprop Sukhoi SU 31 (NIB) Aerobatic ARF RC Park Flyer *NEW* | Martevuo | Aircraft - Electric - Airplanes (FS/W) | 0 | Oct 04, 2005 09:53 AM |
| FS Simprop Sukhoi SU 31 (NIB) Aerobatic ARF RC Park Flyer | dougpong1 | Aircraft - Electric - Airplanes (FS/W) | 3 | Aug 25, 2003 09:48 PM |
| Wattage SU-31 Sukhoi | eBird | Parkflyers | 5 | Jul 29, 2002 10:14 PM |
