Old Feb 22, 2009, 08:21 PM
ant141110 is offline
Find More Posts by ant141110
Fly, crash, spend, Fly...?
ant141110's Avatar
reno
Joined Feb 2009
Help!
insulfoam from home depot
I was at home depot last week and saw some white foam with a skin on both sides about 9mm thick (insulfoam). A sheet of it 2' by 4' was only $2.33 so I bought a sheet and made the extra 300 from rc powers. Im wondering if anyone has used this stuff and how it compares in weight to epp (9mm). I put a 28 26 1000kv bl outrunner with 10x5 sf (only prop I have at the moment) and a 3s 800mah. It wont go vertical and run times are about two min?! what is wrong? I will switch to a 9x3.8 when I get one but is this foam a lot heavier than epp? If I use a bigger battery than I still won't be able to go vert.. this motor should be strong enough right? nothing is even warm when im done (motor esc or bat)
ant141110 is offline Find More Posts by ant141110
Old Feb 22, 2009, 08:28 PM
noobee is offline
Find More Posts by noobee
Joined Dec 2006
this foam works well with larger planes. this one in the video is made from multiple sheets of 2in home depot foam stucked together and then hotwire shaped into a plane. remove the plastic skin and cover it with 0.75oz/ft2 FG + minwax.
Twelve Feet of Flying Foam (4 min 15 sec)
noobee is offline Find More Posts by noobee
Discussion Question about Pink foam sheets from Home Depot SteveC68 The Builders Workshop 17 Nov 27, 2011 08:54 AM
Discussion Lithium Battery Packs For Ryobi From Home Depot Rickochet Batteries and Chargers 3 Dec 06, 2008 05:15 AM
Discussion next noob ? - which foam to buy from lowes/home depot pairadocs Foamies (Scratchbuilt) 11 Sep 12, 2007 07:28 AM
Spray foam filler at Home Depot erashby Foamies (Kits) 2 Jan 27, 2002 12:22 AM
