DFW airport
Joined Jan 2009
If I could see better and if the problem was worse I'd swap motors to see if the trim leaned the other direction over time. If the problem was worse, it wouldn't fit within trim range and that would be kinda annoying. And a little dangerous cuz when I get more than 90 deg off axis I tend to get disoriented ahd hit things.
Today, thought 3mph wind was low enough to go outside. Hey, they told me this was NOT a 3-D heli, but there it was upside down. Drat. VERY seldom calm here. Nothing broke, took back inside and finished the charge, at work now. |
DFW airport
Joined Jan 2009
Late-night flight, 2 bat cycles. Yaw trim kinda wandering but within a narrow range, not like it was going from 1/3 right to 2/3 left. No 'crash' crashes. Flybar came loose once, but seems it shouldn't have at the time.
Doing precision maneuvering within a T-shaped 5x7 airspace surrounded with rigid objects. +/- 90 degree nose orientation. I'm still lost if it goes beyond that. Still dodging the heli's own turbulence and characteristic tendency to suck itself toward fixed objects. Wasn't it Bernoulli who figured out that moving fluids exert less pressure than static ones? I'd have to google it to be sure. But the closer you get to a solid object like a wall, the more the V4 seems to want to hit it. Whereas it's relatively stable in the middle of the room. Meanwhile I'm drooling over Belt CP. It's a leap from V4, but geez, it's like real only smaller. |
I just got a 450 size cp heli and I love it...definitely a leap from coax but you seem like a smart guy.....you'll do fine ![]() Btw...kept my coax too....love it too much to get rid of it....flying that thing is a piece of cake compared to the cp. Almost relaxing lol. |
DFW airport
Joined Jan 2009
Yes, quite, I want a bird with enough range to cope with a light breeze in the park. Does seem the only way to get that range is take away the lag and stability inherent in coaxes. But correct me if I'm Chinese (Wong)--Belt CP would be futile to operate in a 5x7 airspace.
I think before I buy (and risk destroying) something that elegant, I'd better get to where nose in the rear hemisphere doesn't = loss of orientation/control. |
| Thread Tools | |
| The end of the world as we know it? | Tony Oliver | Fuel Plane Talk | 36 | Apr 01, 2004 01:22 AM |
| Some ?'s on end point, dual rate, and exponential | newracer | Hitec/Multiplex USA | 1 | Jan 22, 2004 01:51 PM |
| It's sure a friendly cyber world out there ... | Mitch G | Life, The Universe, and Politics | 2 | Sep 17, 2003 05:06 PM |
| What's wrong in electric flight world? | JP | Power Systems | 10 | Jun 07, 2001 01:35 AM |
