I used my PE6850 for the first time in anger over the weekend
http://www.rcgroups.com/forums/showp...postcount=1238 I charged 2 x 6s 5000mAH @ 6.5 amps and 3 x 3s 2200mAH @ 3.0 amps all at the same time. The peak temperature was a respectable 49c (120F) - monitored at the air flow from the vent at the back. I intend to order two more 5000mAH 6s batteries along with two more chargers so I'll have to increase the 3 output wire to 6 to take the full current that will be required. All in all this was a very cheap way of providing all my 12v needs. Thanks for all you help. Kev |
Touching them is not a problem. The voltage is only 12V and not dangerous.
Shorting them (ie bridging the positive and ground) would be an issue but the supply will shut down automatically. Your call - but I wouldn't be concerned on safety grounds. I made a small cover from a plastic box that happened to be the right size and glued it on just 'cos it looked neater. Anything that is an insulator can be used - liquid tape, silicone sealant, I would think even hot glue would be fine. Be aware that if you ever have to repair the connection, tenacious gunk all over it makes it harder. ![]() John |
USA, CA, Los Angeles
Joined Jun 2010
| Thread Tools | |
| Alert Need advice on high grade power supply for ISL-8 | Byron Betterly | Batteries and Chargers | 7 | Dec 07, 2003 08:31 PM |
| 12volt, 9amp power supply for sale | Paul Susbauer | Aircraft - Electric - Airplanes (FS/W) | 1 | Dec 03, 2003 12:44 PM |
| 12volt wallwart power supply reading 14.6 ? (help) | power | Batteries and Chargers | 4 | Sep 09, 2003 04:21 PM |
| Where to Get A Quality Power Supply? | Joe Elston | Batteries and Chargers | 4 | Apr 29, 2003 02:09 PM |
| High end charger and power supply for sale! Very new. | ted616 | Aircraft - Electric - Airplanes (FS/W) | 6 | Dec 02, 2002 11:31 PM |
