Espritmodel.com Heli Air
Old Jan 29, 2012, 12:04 PM
Use the 4S Luke
feathermerchant's Avatar
USA, TX, Euless
Joined Aug 2003
I think that the limit has been reached (~1,000W) because of the voltage and current available in household circuits. You can build a 2,000W or 4,000W charger but how is the ordinary going to power it? I can easily charge packs for my 50cc planes now. The market for planes >50cc is pretty limited compared to 50cc and below.
feathermerchant is offline Find More Posts by feathermerchant
Old Jan 29, 2012, 07:25 PM
Power! Power! Power!
HaxNobody's Avatar
Joined Jan 2012
Originally Posted by earlwb View Post
Wow that is a really cool power supply, 48v at 2300 watts or thereabouts. Awesome.
Right now I do not think that anyone has manufactured a 48 volt input Lipo charger yet. But at the rate things are progressing, a charger like that is just around the corner, so to speak. There are some Lipo chargers that are setup to handle 36v input for up to 14 lipo cells.
There might be some LiFe chargers that can use that, like for the car battery packs and maybe some old style lead acid PB chargers like used in golf carts, etc. I see the Chinese on Alibaba show a lot of 48v chargers for things like electric bicycles and such too.
Some guys are now running 15 cell Lipo packs for really big airplanes and such too. So there is a really small market for it at this time.
Some one was discussing it here at one time http://endless-sphere.com/forums/vie...p?f=14&t=22881 it looks like they applied 48v in to a array of single cell Lipo or LiFe charge modules built onto a set of PCBs.
Ah, interesting info and link, thanks earlwb. BTW, this PSU is 18,000 watts.
2 banks of isolated 9,000 watts each, fed by 3x 3,000 PSUs per bank!
Since computer power supplies are designed with primarily resistive loads, it probably wouldn't run any motors or such directly - however it might be good to use for a home-made uninterruptible power supply with forklift batteries!
Someone here mentioned the possibility of opening them up and "underclocking" them to a lower voltage instead of pushing them up higher. Wonder If I could get them down to 36v...
HaxNobody is offline Find More Posts by HaxNobody
Old Jan 29, 2012, 07:39 PM
earlwb's Avatar
USA, TX, Grapevine
Joined Dec 2008
My mistake I missed the 9000 w statement further on. That does put your PSU in the over the top category for power supplies.
When I ride my bicycle to work and back, I used to pass a business that had a old electric forklift in the back. It had something that looked like six banks of lead acid batteries in trays mounted in it. So I guess that monster PSU would work for something like that.
I guess you could go for a full size electric airplane, but I don't know about the flight time though.
earlwb is offline Find More Posts by earlwb
Latest blog entry: My Low Wing plane
Old Jan 30, 2012, 03:01 PM
s.nase's Avatar
Bundesrepublik Deutschland, Berlin, Berlin
Joined Feb 2011
DPS-700eb
I turned off the OVP in my DPS-700EB Power Supply. (post844, xandrios). This works well so far (14 to 14.8 V). But the output voltage varies depending on load very much. That's why I wanted to "return sens" pin8 with the link to the output voltage. Now I'm not sure I've found the right pin. The output voltage should fluctuate less load dependent.
What do the five sliders on the daughter board? I guess three pots to take control of three output voltages (5Vsb, 15Vcc, +12 V). The other two pots are probably responsible for the OCP (5Vsb, +12 V). The one has ever tested exactly?
s.nase is offline Find More Posts by s.nase
Old Jan 30, 2012, 03:26 PM
Steven
xandrios's Avatar
United States, CT, East Hartford
Joined May 2010
Hello s.nase,
I've fully tested this mod at 15.0v with a 65A load.
The output voltage did not drop even at full load.
Did you test the output voltage at the PSU??
And how is your potentiometer wired?
Make sure that the two main ground outputs are connected together. Top and bottom.
And make sure the two main +V outputs are connected together. Top and bottom.
This might make the difference.
Also, potentiometer(slider) #5 adjusts voltage. Counterclockwise to increase.
xandrios is offline Find More Posts by xandrios
Old Jan 30, 2012, 06:14 PM
s.nase's Avatar
Joined Feb 2011
I measure my output voltage directly at the power supply.
My cabling makes no difference on the low side of the potentiometer (1k/2W).
Without a load at the output, I can adjust stable voltages from 14V to 14.8V. At higher voltages the power supply comes out of the stroke. Exactly at 15.5V it works stable again. When I load the power supply with 20A, the voltage drops by 0.2V.
You are changing the voltage of the internal potentiometer on the daughter board, or on the external potentiometer at PIN63?
Which function has and PIN1 PIN8?
Have you found a way to control the fan speed depending on load? I would also replace the four small fans (two PSUs in series) against a large 80mm fan. The tachometer signal is to be distributed via a opto-couplers.
I like the DPS-700EB extremely well especially because you have to get disabled the OVP. Is there a trick to bridge the OVP in other power supplies?
Old Jan 31, 2012, 07:42 AM
Steven
xandrios's Avatar
Joined May 2010
Hey s.nase,
I think that I have a solution for you. I will post later today.
Old Jan 31, 2012, 02:28 PM
s.nase's Avatar
Joined Feb 2011
I was not careful enough, I toasted the PIC in one of my DPS 700EB. But I'm still enough other 700EB. Maybe I can copy the software to a new PIC. I have the wrong contact in the picture in my last message already corrected.
Before my misfortune I've played a bit with the pot5. I've found a setting in which the output voltage remained stable. But once I've set more than 14.8V, the PSU came back out of the stroke.
Let's see what my other 700EB.
Old Jan 31, 2012, 04:02 PM
Steven
xandrios's Avatar
Joined May 2010
Hello s.nase,
sorry you fried the PIC.
It can easily happen with a slip of the fingers.
I've discovered that the OVP mod for the DPS-700EB seems
to work slightly different on each unit.
On some you can reach 15.2v. On others you can only reach around 14.8v with full regulation.
The one I have works up to 15.1v.
It's something other than the LM339 OVP circuit.
Just put a 680 ohm resistor in line with the pot to stay below 14.8v.
Also, pins 3 and 4 from top left on the large PIC are tach outputs from the fans.
Old Feb 03, 2012, 10:35 AM
HaxNobody's Avatar
Joined Jan 2012
How about 2100 watts at 12.1 VDC? Dell NC003 blade server PSU.
Linky: http://www.serversupply.com/POWER%20...DELL/NC003.htm
Wonder If I should procure one and try to get it working.
Old Feb 03, 2012, 12:54 PM
Steven
xandrios's Avatar
Joined May 2010
Hey HaxNobody ,
Or here for 1/4 the price:
http://www.ebay.com/itm/Dell-Powered...item53eb3f76c7
Why do they always have to raise the price when you start buying them??
Old Feb 04, 2012, 12:14 PM
HaxNobody's Avatar
Joined Jan 2012
Originally Posted by xandrios View Post
Hey HaxNobody ,
Score! I bought one, as well as a newer current-generation model: http://www.ebay.com/itm/320841281011
The second one is a 2360 watt 12VDC
Also, after hours and hours of googling, I finally found the spec sheet - with pinouts! - of the 48 volt PSU: http://www.powerconversion.com/suppo...cef3be3a5422a2
Old Feb 04, 2012, 01:53 PM
ndamico's Avatar
United States, CA, Sacramento
Joined Jan 2012
hi,
just bought two of these to run in series. what is the current share pin used for? i thought it was something to do with parallel operation as they would be when installed in the server.
thank you
Hey 376782,
The Dell 7000245(Poweredge 6650) PS is an oddball PS where you have to ground bias the voltage control pin.
This may also be why the manufacturer selected to keep the DC ground floating on this model.
Pin A1 controls voltage. Connect to ground via pot or resistor. Use only up to 13v max.
1.3k ohm ≈ 13v. Any higher than 13v will cause the PS to shut down even with a slight current draw. This is common with most PS as you near OVP.
Tested at 13v for 72A.
Pin D1 is the current share pin.
ndamico is offline Find More Posts by ndamico
Old Feb 04, 2012, 04:25 PM
Steven
xandrios's Avatar
Joined May 2010
The current share pins are connected together when running them in parallel to balance the current draw between power supplies.
Old Feb 04, 2012, 04:36 PM
ndamico's Avatar
Joined Jan 2012
great, thanks a million!
Alert Need advice on high grade power supply for ISL-8 Byron Betterly Batteries and Chargers 7 Dec 07, 2003 08:31 PM
12volt, 9amp power supply for sale Paul Susbauer Aircraft - Electric - Airplanes (FS/W) 1 Dec 03, 2003 12:44 PM
12volt wallwart power supply reading 14.6 ? (help) power Batteries and Chargers 4 Sep 09, 2003 04:21 PM
Where to Get A Quality Power Supply? Joe Elston Batteries and Chargers 4 Apr 29, 2003 02:09 PM
High end charger and power supply for sale! Very new. ted616 Aircraft - Electric - Airplanes (FS/W) 6 Dec 02, 2002 11:31 PM
