Old Jan 08, 2012, 03:09 PM
xandrios is offline
Find More Posts by xandrios
Steven
xandrios's Avatar
United States, CT, East Hartford
Joined May 2010
Hey Bubba Gump,
What's the maximum voltage that you are looking for?
It's even possible to run 3 powers supplies from this forum in series to reach 30V - 36v.
Also,
http://www.rcgroups.com/forums/showp...postcount=1031
xandrios is offline Find More Posts by xandrios
Old Jan 08, 2012, 04:12 PM
everydayflyer is offline
Southern Pride
everydayflyer's Avatar
Haralson County GA. USA
He mentioned Power Lab so max. is 32V but unless he really needs every single watt available 24-25V should be fine.
FMA online power calculators.
http://api.viglink.com/api/click?for...13260608675701
Snip
Question 3
What are the minimum power supply specifications that will enable me to take full advantage of PowerLab 8 v2's full power capabilities?
Answer:
Power Supply Voltage (V) 26.35 (PowerLab 8 v2 will accept up to 32V input, but power is not improved above 30V input)
Power Supply Current (A) 60 (Power supply output current capability can exceed 40A, but power will not be improved)
Charles
Old Jan 08, 2012, 04:23 PM
TheWoodCrafter is offline
Find More Posts by TheWoodCrafter
RC Helicopter Pilot
TheWoodCrafter's Avatar
United States, CA, Westminster
Joined Mar 2010
Actually the PL6 is a different beast than the PL8.
It requires 30V for max output.
And maximum input is 32V.
TheWoodCrafter is offline Find More Posts by TheWoodCrafter
Old Jan 08, 2012, 04:34 PM
Bubba Gump is offline
Find More Posts by Bubba Gump
F3P, Slap, IMAC, Helis
Joined Jun 2007
Yea thats what i was looking at was the powerlabs problem is running 3 in series is that 35v max for the powerlabs is 32 so you would have to use a voltage step down. whats the best way to do that.
Bubba Gump is offline Find More Posts by Bubba Gump
Old Jan 08, 2012, 06:02 PM
Southern Pride
PL6 calculator here
http://www.revolectrix.com/pl6_calcu...PL6_Calc_1.htm
Yes 30V for max. of 40A output into a 6S however with only 24V input output is still 32.4 Amps.
32.4 / 40 = 81% of max. output available.
Charging a 5S output would be 38.9Amps.
Which is why I posted
In most real world applications there will be very little difference in charging times.
I have often posted that what a charger can output with voltages other than 12,24 or 36V does not really concern me as those are the more common voltages available from 12V Pb batteries in series.
I got into to rather heated debates on another user's forum over the output from the FMA CP10 as on 12V it was well below it's rated max. which required 16V which to me is really not common at all.
Charles
Old Jan 08, 2012, 06:12 PM
Joined Jun 2007
yea i know that but would rather use its full power. FLying 12s electric helis is were you need the max charge rating. so i need to get the full 40a output. I have a super dou but its so big i hate it thats why i like the pl6 casue its small.
Old Jan 08, 2012, 07:24 PM
xandrios is offline
Steven
xandrios's Avatar
Joined May 2010
Hey Bubba,
Usually any power supply with an internal trim pot that adjusts output voltage can easily be modded to drop the voltage to below 10v if the UVP allows it.
Also, any voltage greater than the +V DC output applied to the 12V RMT SENSE line will allow the output DC voltage to be reduced to under 10v. This just fools the PS into thinking the output voltage is higher than it is, so in return it will drop the output voltage. This can be accomplished when running power supplies in series.
From what I gather, any PS with more than around 50A is not needed when running them in series for charging. The PE 6800 PS would be overkill.
The Delta DPS-700EB or IBM xSeries x336 585w power supplies may be good for what you need.
I'll do some testing tonight and post results tomorrow.
Old Jan 08, 2012, 07:37 PM
xandrios is offline
Steven
xandrios's Avatar
Joined May 2010
IBM xSeries x336, AcBel API3FS25 585w (48A 12.2V) PS enable
IBM xSeries x336, AcBel API3FS25 585w PS enable.
Connect A8 and A10 to power up.
Connect (B4 to +12v) or (B7 to ground) with potentiometer
to adjust output voltage up to around 14v. Use the set that works best.
Best to set internal trimpot to highest output voltage when using external voltage adjustment pot.
Connect B7 directly to +12v to stabilize output voltage if needed.
OCP (Overcurrent Protection) can be adjusted with trim pot from the original 50A up to 70A. Use with caution!!
A1 = Current Share
B4 = 12v remote sense return
B7 = 12v remote sense
Old Jan 09, 2012, 11:02 AM
Joined Jun 2007
see you cant get 15v out of it you need 15v then put them in series to get the max wattage on the charger 40amps. Is the there a pot on the dl580s the smaller ones, 74 amp ones.
Old Jan 09, 2012, 11:51 AM
Joined Jun 2007
so your saying i can put three power supplies in series that have a voltage pot to adjust the voltage. and then turn one of them down so get the 30-32v i would need to max out the the charger capablity.
Old Jan 09, 2012, 05:24 PM
xandrios is offline
Steven
xandrios's Avatar
Joined May 2010
Hey Bubba Gump,
you can use this mod to allow running 3 IBM
xSeries x336 585w PSs in series for the 30v - 32v you need.
After adding the resistor, the adjustable voltage range will be from 8.5v to 12.5v.
Set the voltage to around 10.5v
for each power supply using the voltage control pot.
That should give around 31.5v in total.
Voltage drop with a 60A load will yield 31.2v.
Be sure to tie the 12v remote sense to the +V and the 12v remote sense return to ground on each power supply.
You can turn the OCP adjustment pot a quarter clockwise to increase OCP to 60A since we are running at a lower voltage.
While I was in there, I also found that a 33k resistor between the green points increases the voltage range up to 14.5v for the internal voltage trim pot.
Be sure to use one of the methods in this forum to decouple the DC from the case when running them in series.
Old Jan 09, 2012, 05:48 PM
Joined Jun 2007
ok thanks heres a question what would the 3 power supplys in series be pulling off a 120 maxed out.
Old Jan 09, 2012, 06:12 PM
xandrios is offline
Steven
xandrios's Avatar
Joined May 2010
They would probably max out at about the same time as a 120v outlet.
Max would be around 20A or 2250w from a single 120v outlet.
But you will only be using 40A from each so that would be around 13.3A or 1500w off a single 120v line.
Old Jan 09, 2012, 06:46 PM
Joined Jun 2007
yea see thats the problem cause we all use 2000w generators in the heli world like the honda 2000w. I think im just gonna go with 2 306bs and use my current set 2ML580s the 910w ones at 120v.
Old Jan 11, 2012, 06:06 PM
Joined Jun 2007
Did nyone ever figure the pin out for this one. http://www.rcgroups.com/forums/showp...&postcount=883
with 2 of these in series would be perfect cause it doesnt draw much off a 120 line compared to the dl580s which would draw 22amps maxed out vs these would be 18.8amps. fully loaded.
Alert Need advice on high grade power supply for ISL-8 Byron Betterly Batteries and Chargers 7 Dec 07, 2003 08:31 PM
12volt, 9amp power supply for sale Paul Susbauer Aircraft - Electric - Airplanes (FS/W) 1 Dec 03, 2003 12:44 PM
12volt wallwart power supply reading 14.6 ? (help) power Batteries and Chargers 4 Sep 09, 2003 04:21 PM
Where to Get A Quality Power Supply? Joe Elston Batteries and Chargers 4 Apr 29, 2003 02:09 PM
High end charger and power supply for sale! Very new. ted616 Aircraft - Electric - Airplanes (FS/W) 6 Dec 02, 2002 11:31 PM
