Old Dec 22, 2011, 10:38 PM
shalom72c is offline
Find More Posts by shalom72c
Joined Dec 2011
Help ! Need power supply : questions
Hi Everyone ! Happy Holidays !! I need to find a reasonable cost server power supply to mod that can put out 13-13.8VDC (max) with a min of 20-30amps . It is for using with a ham radio transceiver. Could some one please point me in the right direction to find a power supply and help to get the needed mods done. I have been in RC off and on over the last 10 years .
Thanks !
Bill C.
shalom72c is offline Find More Posts by shalom72c
Old Dec 22, 2011, 11:08 PM
Cougar Zeke is offline
Find More Posts by Cougar Zeke
Ennnnncommmming!!!!!
Cougar Zeke's Avatar
Bellevue, WA
Joined Sep 2008
shalom- I'm no expert, but I think you would be better off with a regular computer power supply. A cheaper, easier solution IMO
Cougar Zeke is offline Find More Posts by Cougar Zeke
Old Dec 22, 2011, 11:35 PM
mrforsyth is offline
Find More Posts by mrforsyth
So. Cal.
Server supplies are superior to standard ATX computer supplies in nearly every way. They're more robust, easier to convert, have more stable power output, and are dramatically cheaper.
That said, ALL server supplies (as well as all ATX supplies) are switchers and may introduce undesirable noise when used to power amateur radio equipment. Since they're cheap, you have little to use in trying though.
Go to the following thread and do a little searching. You should quickly find a suitable supply that is capable of adjusting voltage above 13 volts (most are 12.0-12.5V standard).
http://www.rcgroups.com/forums/showthread.php?t=1292514
Welcome to RCGroups, Bill!
Mark
mrforsyth is offline Find More Posts by mrforsyth
Old Dec 23, 2011, 06:02 AM
jj604 is online now
Find More Posts by jj604
ancora imparo
jj604's Avatar
Melbourne, Australia
Joined Jul 2005
Just don't post any questions on that thread. It's a reference thread and the moderator is a grumpy old bastard.
Post any questions on this thread where all the nice experts hang out.
John
Mark
jj604 is online now Find More Posts by jj604
Old Dec 24, 2011, 01:49 PM
KiloOne is offline
Find More Posts by KiloOne
Dale Kramer
KiloOne's Avatar
United States, NY, Hammondsport
Joined Jul 2004
Just a thought
I've contributed to both threads and think they are a great resource.
However, I've been searching for a couple hours now and haven't had any luck trying to find out if there is a supply that suits my current need.
Is there any web service that hosts spreadsheets that multiple users can update?
It would be great to have sortable columns like part#,dimensions,weight,watts,amps,voltage adjust(Y/N),low V limit,High V limit,floating outputs(Y/N),floating outputs possible (Easy,Med,Hard),fan speed notes,link to build thread etc.
Dale
P.S. Does anyone know of a supply that can give around 60 amps, floating outputs and a voltage adjustable down to 11.2V?
KiloOne is offline Find More Posts by KiloOne
Old Dec 24, 2011, 02:47 PM
So. Cal.
Google docs!
Yes, it would be great. As of right now, the best resource that I am aware of is the (other) excellent thread that John (JJ604) started: http://www.rcgroups.com/forums/showthread.php?t=1292514
Mark
Old Dec 24, 2011, 06:38 PM
DigitalDream is offline
Find More Posts by DigitalDream
Joined Sep 2010
Hi,
No, I just can't remember what frequency I chose that would fool the power supply into thinking the fan was running. When I first tried it, I chose a ridiculously high frequency which the supply figured was a problem with the fan and it would shut down. Any frequency that the supply accepts is the right one.
That said, be sure to cool it properly, as it now has no way (short of onboard temp sensors if equiped) to know if there is a cooling problem.
Originally Posted by 376782 View Post
Hi Keith;
Not clear whether you are looking for a slower fan that would output the same frequency feedback pulses or plan to use your 555 IC to emulate the feedback signal. If you do find slower fans that output the same frequency (approx. 330 HZ) let me know. At the present I have disconnected the feedback and replaced it with the 555 CCT as in post #1071. The fans are connected in series to run much slower and can be selected to high speed with a DPDT switch.
Dave
DigitalDream is offline Find More Posts by DigitalDream
Old Dec 28, 2011, 09:19 PM
nitris223 is offline
Find More Posts by nitris223
Saskatchewan, Canada
Joined Jan 2011
I can pick one of these up in Canada and save a good bit on shipping. Would either work for my GT power A6-10 200watt 10amp charger. I don't plan on ever having any more then 2 chargers at some point in time. I have 14 batteries so I will have flying time while waiting for them to charge.
Are they quiet or loud. I plan on putting them in a Plano aluminum case .
HP DL380 G4 / DL385 G1 Server Power Supply 575W S/P 406393-001 / 321632-501
HP DL380 G3 Server Power Supply 313299-001 / 313054-001
or I can get 2 of these off Ebay
nitris223 is offline Find More Posts by nitris223
Old Dec 29, 2011, 05:26 AM
jj604 is online now
ancora imparo
jj604's Avatar
Joined Jul 2005
nitris, according to your picture of the label, the Lucent supplies only do 10A at 12V. that's 120 Watts. Pretty useless. Their big rails are the 3.3 and 5V ones. No use to us.
Old Dec 29, 2011, 12:56 PM
Joined Jan 2011
So what about the other 2 DL 340's . I think the G3 is 350 to 400 watts and the G4 is 575 watts and this was some of the specs were model DSP-600 PBB Esp-135. Would those work. I can also get my hands on a IBM eServer 345x345 350 watt. I can't tell how big or small these thing are from the picture. Are they quiet or loud.
Old Dec 29, 2011, 03:36 PM
jj604 is online now
ancora imparo
jj604's Avatar
Joined Jul 2005
The G4 you list looks like the EP600 supply. Plenty of info on that in this thread.
It's powerful enough and fairly quiet. You can control the fan speed if it is the same as the ones in this thread.
http://www.rcgroups.com/forums/showt...369612&page=39
Old Dec 29, 2011, 04:52 PM
Joined Jan 2011
Thanks jj604. I think I will snag a couple of them. They look pretty simple to wire up and there is lots of post about that model.
Old Jan 01, 2012, 04:04 PM
jarconman is offline
Find More Posts by jarconman
jarconman's Avatar
Lijnden, the Netherlands
Joined Oct 2007
adjust voltage model 7000814-0000
Hi guys,
don't know if I missed it somewhere but how can I adjust the voltage of a dell model 7000814-0000 power supply. I have got it running with a voltage of 11.94V.
Somewhere I read to attach b4 to positive, and that should raise the output voltage to 12.5 volts. Looking at the overview of the pin connections I see b4 is a + 3v3 standby. To which connector do I connect it and will it work or does the power supply go up in smoke?
Regards,
Jarco
jarconman is offline Find More Posts by jarconman
Old Jan 01, 2012, 07:02 PM
xandrios is offline
Find More Posts by xandrios
Steven
xandrios's Avatar
United States, CT, East Hartford
Joined May 2010
Hey jarconman,
there seems to be only one way to increase output voltage for the 7000814-0000 PS.
Using a 470 ohm resistor between pin A2 (+12V Current share) and +V out will increase voltage from 11.94v to 12.5v.
http://www.rcgroups.com/forums/showp...&postcount=724
xandrios is offline Find More Posts by xandrios
Old Jan 08, 2012, 01:37 PM
Bubba Gump is offline
Find More Posts by Bubba Gump
F3P, Slap, IMAC, Helis
Joined Jun 2007
http://www.rcgroups.com/forums/showp...&postcount=939
Can you put two of these in series. Im running 2 dl580s in series the 100 amp ones. but those are only putting out 25 volts in series. With the powerlab chargers they require 30 volts or more to get the max wattage capability of the charger. So with these power supplys you can run them at 15 volts just fine so in series they would work. Another question does anyone know how many amps these pull off a 120v line.
Bubba Gump is offline Find More Posts by Bubba Gump
Alert Need advice on high grade power supply for ISL-8 Byron Betterly Batteries and Chargers 7 Dec 07, 2003 08:31 PM
12volt, 9amp power supply for sale Paul Susbauer Aircraft - Electric - Airplanes (FS/W) 1 Dec 03, 2003 12:44 PM
12volt wallwart power supply reading 14.6 ? (help) power Batteries and Chargers 4 Sep 09, 2003 04:21 PM
Where to Get A Quality Power Supply? Joe Elston Batteries and Chargers 4 Apr 29, 2003 02:09 PM
High end charger and power supply for sale! Very new. ted616 Aircraft - Electric - Airplanes (FS/W) 6 Dec 02, 2002 11:31 PM
