Old Dec 04, 2011, 11:07 PM
TheWoodCrafter is offline
Find More Posts by TheWoodCrafter
RC Helicopter Pilot
TheWoodCrafter's Avatar
United States, CA, Westminster
Joined Mar 2010
Originally Posted by feathermerchant View Post
I think he's building a setup for his club.
That would explain it.
I still think a 24V buss would be an advantage for the guys with the higher output chargers.
TheWoodCrafter is offline Find More Posts by TheWoodCrafter
Old Dec 05, 2011, 05:22 AM
SkyRaptor is offline
Find More Posts by SkyRaptor
Brazil, São Paulo, Campinas
Joined Apr 2010
Feathermercant is right - we have exchanged some emails.
Nowadays we have a 110V power rail in our club, so everybody needs his own PS and charger.
The idea is to build a 12V and 24V power rail, each one with at least 2000W.
The 24V power rail is intended for electric helis and the 12V for other guys who just charge Rx packs and small airplanes packs. Their chargers just works in 11V-18V input range.
So wiring those PSs in parallel is supposed to work?
Thanks.
SkyRaptor is offline Find More Posts by SkyRaptor
Old Dec 05, 2011, 09:18 AM
xandrios is offline
Find More Posts by xandrios
Steven
xandrios's Avatar
United States, CT, East Hartford
Joined May 2010
Quick question for the group.
I personally don't own a LiPo charger.
What is the highest voltage most chargers accept?
xandrios is offline Find More Posts by xandrios
Old Dec 05, 2011, 09:48 AM
ReddiK is offline
Find More Posts by ReddiK
Joined Nov 2011
I think 30 volts, for FMA PL-8 and an Icharger or two, but others will know.
ReddiK is offline Find More Posts by ReddiK
Reply With Quote  (Disabled)
Old Dec 05, 2011, 09:51 AM
Joined Apr 2010
It depends on the charger.
My Hyperion 720 SDuo3 accepts up to 29V.
My iCharger 208B up to 32V.
I know that iCharger 3010 handle up to 38V and the Thunder Power 1430 up to 36V.
Usually high power chargers can handle at least 28V and low power chargers at least 18V.
Best Regards.
Old Dec 05, 2011, 03:11 PM
xandrios is offline
Steven
xandrios's Avatar
Joined May 2010
Thanks..
Old Dec 05, 2011, 05:31 PM
Joined Apr 2010
What is the difference of these PSs??
-> Hp 337867-501 Hp 900w
-> Hp 364360-001 Hp 1300w
-> Hp 406421-001 Hp 900w
They are all 900W (110V) / 1300W (220V) for Proliant Dl580 and Ml570.
Can I easily power them up for standalone use???
Thanks.
Old Dec 06, 2011, 06:43 PM
feathermerchant is offline
Find More Posts by feathermerchant
Use the 4S Luke
feathermerchant's Avatar
USA, TX, Euless
Joined Aug 2003
I need to sell one of my 180W Hyperion Duos......
feathermerchant is offline Find More Posts by feathermerchant
Old Dec 06, 2011, 10:52 PM View Post
rismuer988
A moderator felt this post violated the following rule: Off Topic Advertisement. Show it to me anyway.
Old Dec 07, 2011, 12:40 AM
jj604 is online now
Find More Posts by jj604
ancora imparo
jj604's Avatar
Melbourne, Australia
Joined Jul 2005
Reported
jj604 is online now Find More Posts by jj604
Last edited by jj604; Dec 09, 2011 at 07:06 PM. Reason: Post was reported and removed
Old Dec 07, 2011, 01:23 AM
mrforsyth is online now
Find More Posts by mrforsyth
So. Cal.
Thanks.
They're all the same supply, just with different part numbers / spare numbers. This supply is capable of being powered up for standalone use and is the primary subject of this thread.
See post #2 for detailed instructions on how to make it work.
Noteworthy about this particular power supply is the fact that it requires a unique power cord (or soldering skills) and is extremely loud (to my ears at least).
Mark
mrforsyth is online now Find More Posts by mrforsyth
Old Dec 09, 2011, 04:49 PM
ciesin is offline
Find More Posts by ciesin
Polska, Zachodniopomorskie, Stargard Szczeciński
Joined Aug 2011
Originally Posted by 376782 View Post
Finally after several attempts to get the supply to hold voltage with load I believe I have the answer. Instead of jumpering pins 30, 31 and 34 together just jumper 34 to 31 and tie pin 30 to +12V. So far I can now load up to 45 amps and the output drops just 100mv (12.9V to 12.8V). I do believe I will have a double gin and tonic to celebrate. I had almost given up and tossed the supply. Now I hope I can get more as I believe this is one nice compact supply capable of delivering 65 amps. I plan to series up a couple for 24V which be a piece of cake seeing as the negative is not tied to chassis ground.
Dave
Hi all, a few months ago I was struggling to keep steady 12V output under heavy load on my DPS800GB. I tried many ideas but with no success. Then I gave up and put the supply on the attic. Yesterday I came back on this thread and saw solution presented by 376782. Now all I can do is to confirm that it works for my supply as well Many thanks for all who showed interest in my problem and of course for 376782 who shared his discovery
ciesin is offline Find More Posts by ciesin
Old Dec 09, 2011, 06:57 PM
xandrios is offline
Steven
xandrios's Avatar
Joined May 2010
Thanks feathermerchant,
but I was just thinking that if I could lower the UVP
of a cheap 48v server PS to around 28V, then running
it in series wouldn't be necessary.
Just a thought.
Old Dec 09, 2011, 08:48 PM
376782 is offline
Find More Posts by 376782
Near Kingston, Ontario, Canada
Joined Dec 2004
Originally Posted by extreme heli View Post
First I would like to thank all those in this and other similar threads for the invaluable info regarding these sweet little units!
Second I would like to share for those interested in perhaps tinkering a wee bit that I have found the voltage threshold for the HP turbine cooling fans by lots of experimenting with various resistors to turn the fans as slow as possible without triping an error.
Using a 2 Watt 10 Ohm resistor spliced into the positive leads of each fan yeilds 5.55V to the fans and with pins jumped for a solid green and ready supply, produces about 1/2 the RPM at full speed as the stock unit is just in standby mode.
The trick I have found though is to leave the pins tripped in the ON position otherwise it will trip an error if just left to sit in standby, as it spins too slow in this mode and sees it as an error.
I have overloaded the unit to 1000W fed by only 120V without issue on my load rail...and a big smile Temps remained very reasonable, only really warming up when fully loaded. I only plan to use the unit mostly for light/med duty in the shop for now, so listeningn to tunes, phone, and hearing myself think is more priority. Next step up in airflow would be 2W 6.2Ohm resistor giving 6.25V to fans still a solid step down from even stock standby mode, might be considered if constantly running at max and in hotter climates.
I wanted quiet, thats what i got, take from it what you will.
Darren
Can you please tell me what you mean by "The trick I have found though is to leave the pins tripped in the ON position otherwise it will trip an error if just left to sit in standby, as it spins too slow in this mode and sees it as an error."
I have several of these supplies and really need to slow down the fans before I can use them. I have tried resistors but do trip out on low fan speed.
Dave
376782 is offline Find More Posts by 376782
Old Dec 10, 2011, 12:43 AM
wojtek is offline
Find More Posts by wojtek
never fast enough !!!
wojtek's Avatar
old bridge, nj
Joined Nov 2004
Originally Posted by Wayne Giles View Post
I have just bought and converted an HP Power Supply DPS-600PB and it works fine. As it is difficult/impossible/expensive to obtain the mating rear connector, I have soldered a couple of 4mm test sockets between the blades of the existing connector which makes a convenient termination.
The extra low Z capacitor is only to reduce pk - pk ripple to about 60mV at full load and not strictly necessary.
BTW I think the only real ground pin is pin 8 which pins 6 and 10 should be commoned to in order to enable the main 12V output. Full Load regulation is only 0.11V and the overload characteristic is trip off at about 56A, break input to reset.
So as I paid £9.50, I now have a good 12V, 50A psu for just over a tenner!, ($16)
Wayne
im glad i found this post .. thank you!! .. I have a few of these power supplies and could never figure out how to get the 12v out ..
Voy
wojtek is offline Find More Posts by wojtek
Alert Need advice on high grade power supply for ISL-8 Byron Betterly Batteries and Chargers 7 Dec 07, 2003 09:31 PM
12volt, 9amp power supply for sale Paul Susbauer Aircraft - Electric - Airplanes (FS/W) 1 Dec 03, 2003 01:44 PM
12volt wallwart power supply reading 14.6 ? (help) power Batteries and Chargers 4 Sep 09, 2003 05:21 PM
Where to Get A Quality Power Supply? Joe Elston Batteries and Chargers 4 Apr 29, 2003 03:09 PM
High end charger and power supply for sale! Very new. ted616 Aircraft - Electric - Airplanes (FS/W) 6 Dec 03, 2002 12:31 AM
