Old Nov 29, 2011, 06:34 AM
pete236 is offline
Find More Posts by pete236
Joe from New England
pete236's Avatar
United States, MA, Beverly
Joined Apr 2011
I tried that.
Originally Posted by Sandro's View Post
Hey pete236,
try pins A and B to ground combo as shown in the pic.
It seems to be a very common one for dell.
Also, use around a 500Ω resistor from each pin to ground to be safe.
Steve,
I tried that and it ran for a bit then would not restart. I'm going to check the internal fuse(s).
There is a dell 730 power supply out there with a different pin settings, so I'm sure I'm missing something, but thanks for the suggestion.
Oh, BTW, what do the resistor do?
Joe
pete236 is offline Find More Posts by pete236
Old Nov 29, 2011, 08:36 AM
xandrios is offline
Find More Posts by xandrios
Steven
xandrios's Avatar
United States, CT, East Hartford
Joined May 2010
The resistors were used just in case we were trying to use the wrong pins to start the power supply.
How long did the supply run for?
xandrios is offline Find More Posts by xandrios
Old Nov 30, 2011, 07:46 AM
pete236 is offline
pete236's Avatar
Joined Apr 2011
Run time
Just long enough to get excited about it, maybe 3 minutes or so.
Long enough to get the multi-meter leads on it along with a 12 volt prop spinner to see how it would react with a load.
BTW, nice steady 12 volts.
The surprising thing is it stopped with no load! It stopped about a minute after my load test.
I checked all the connections (good) but, no restarting?
I haven't check the fuses yet. I'll probably do that later today.
Old Nov 30, 2011, 08:50 AM
xandrios is offline
Steven
xandrios's Avatar
Joined May 2010
Those must have been the correct pins needed to start the PS.
Any other combination wouldn't start it.
Did you try directly connecting A1 and B6 to ground?
Old Dec 01, 2011, 07:12 AM
pete236 is offline
pete236's Avatar
Joined Apr 2011
Later
I had a root canal yesterday.
I'll poke around with the PS over the weekend and update this thread later.
Old Dec 01, 2011, 08:26 AM
Trev300 is offline
Find More Posts by Trev300
Joined Jan 2009
Hi I just wantd to post and say a big thank you to Xandrios for the IBM xseries 366 server power supply advice it worked great.
Trev
Trev300 is offline Find More Posts by Trev300
Old Dec 01, 2011, 03:00 PM
xandrios is offline
Steven
xandrios's Avatar
Joined May 2010
Thanks...
Old Dec 01, 2011, 04:05 PM
Cougar Zeke is offline
Find More Posts by Cougar Zeke
Ennnnncommmming!!!!!
Cougar Zeke's Avatar
Bellevue, WA
Joined Sep 2008
Xandios/jj604/anyone,
How loud are the fans in the Poweredge 6800?
As you might have seen from my recent posts I finished up a DL580 Proliant server PS. I love the power supply and its ability to run all eight of my lipo chargers simultaneously, but it does sound like a 747 taking off.
If the Poweredge was much quieter, i might be interested in making a Poweredge my house charger and the Proliant my field charger.
Thanks!
Andy
Cougar Zeke is offline Find More Posts by Cougar Zeke
Old Dec 01, 2011, 04:39 PM
ReddiK is offline
Find More Posts by ReddiK
Joined Nov 2011
Thanks!
Andy
It should be a simple matter to substitute quieter fans-you don't need nearly so much CFM for simple charging.
ReddiK is offline Find More Posts by ReddiK
Reply With Quote  (Disabled)
Old Dec 01, 2011, 08:48 PM
jj604 is online now
Find More Posts by jj604
ancora imparo
jj604's Avatar
Melbourne, Australia
Joined Jul 2005
You shouldn't need to substitute fans. Xandrios is the Poweredge expert, not me, but he has posted details on how to slow several Poweredge 68000's around about here. There are several different model 6800 supplies.
http://www.rcgroups.com/forums/showp...&postcount=610
Thanks!
Andy
jj604 is online now Find More Posts by jj604
Old Dec 02, 2011, 09:37 AM
xandrios is offline
Steven
xandrios's Avatar
Joined May 2010
Hey Cougar Zeke,
the PE 6800 PSU would make a great home charger.
It's a big PS at around 3 times the volume of the DL580 that you have.
Dimensions are 15" x 3.5" x 7.5".
It has a ton of room inside to install banana jacks, binding posts and Amperage meter.
It comes in two variants. The JD200 and the KD175.
I've been able to increase the Over Voltage Protection (OVP) to above 15v on both
models.
And also have been able to slow the fans down to almost being off on both models.
The KD175 will do 140A at 15v(2100W) while pulling 2400w(20A) from a 120v outlet with mod.
The JD200 will do 130A at 15v(1950W) while pulling 2200w(18.3A) from a 120v outlet with mod.
Thats around an efficiency of 87.5% at full power for both. Both are powerhouses!!
The KD175 is the easier to modify of the two because the JD200 incorporates newer technology.
It's just harder to solder inside the JD200 because of the extensive use of surface mount
components.
This post will give you the low down. Post 548 in this thread.
http://www.rcgroups.com/forums/showp...&postcount=548
Old Dec 02, 2011, 11:04 AM
Bellevue, WA
Joined Sep 2008
Big thanks Xandrios, jj and ReddiK!!!!
I'm on the hunt for one on fleabay right now. I'll fill you guys in as to my progress!
Cheers!
Andy
Old Dec 04, 2011, 06:57 PM
SkyRaptor is offline
Find More Posts by SkyRaptor
Brazil, São Paulo, Campinas
Joined Apr 2010
Parallel power supply
Hi guys..
I've been reading all this thread for some days.. learned a lot of info!!!
But I've a silly question.. Is it possible to wire two 12V server power supply to sum their current??
I'm planning to get 2x 12V 47A PS from feathermercant to build a 12V 80A PS. Will it work??
Thanks.
Alex.
SkyRaptor is offline Find More Posts by SkyRaptor
Old Dec 04, 2011, 08:19 PM
TheWoodCrafter is offline
Find More Posts by TheWoodCrafter
RC Helicopter Pilot
TheWoodCrafter's Avatar
United States, CA, Westminster
Joined Mar 2010
Thanks.
Alex.
It would work but why?
Wire is parallel to double the current, series to double the volts.
ALL high output chargers require 24V to get max output from.
What are you going to do with 80A of 12V?
TheWoodCrafter is offline Find More Posts by TheWoodCrafter
Old Dec 04, 2011, 11:01 PM
feathermerchant is offline
Find More Posts by feathermerchant
Use the 4S Luke
feathermerchant's Avatar
USA, TX, Euless
Joined Aug 2003
I think he's building a setup for his club.
feathermerchant is offline Find More Posts by feathermerchant
Alert Need advice on high grade power supply for ISL-8 Byron Betterly Batteries and Chargers 7 Dec 07, 2003 09:31 PM
12volt, 9amp power supply for sale Paul Susbauer Aircraft - Electric - Airplanes (FS/W) 1 Dec 03, 2003 01:44 PM
12volt wallwart power supply reading 14.6 ? (help) power Batteries and Chargers 4 Sep 09, 2003 05:21 PM
Where to Get A Quality Power Supply? Joe Elston Batteries and Chargers 4 Apr 29, 2003 03:09 PM
High end charger and power supply for sale! Very new. ted616 Aircraft - Electric - Airplanes (FS/W) 6 Dec 03, 2002 12:31 AM
