Old Nov 25, 2011, 03:03 AM
linw is offline
Find More Posts by linw
Wellington, NZ
Joined Aug 2006
Nice work, Cougar Zeke.
linw is offline Find More Posts by linw
Old Nov 25, 2011, 10:16 AM
boticeli is offline
Find More Posts by boticeli
Joined Nov 2011
Hello to all,
I just tried this with my supplay DPS-800GB and a got it voltage output on 2 seconds.
31 and 34 has been connected, turn on ac power, connect 30 to +12v
Did I missed something here, please advice
boticeli is offline Find More Posts by boticeli
Old Nov 25, 2011, 10:22 AM
boticeli is offline
Joined Nov 2011
Originally Posted by whitedg View Post
Just checking, we connect as per the attached picture?
whitedg
Hello to all,
Old Nov 25, 2011, 01:31 PM
whitedg is offline
Find More Posts by whitedg
Australia, NSW, Rydalmere
Joined Feb 2010
That is all I did for mine and it works fine.
Maybe check your connections, and check that you have a good solder joint to the blades.
There is the possibility that you have a dud supply. That prospect is not too uncommon for these supplies.
Cheers
whitedg
whitedg is offline Find More Posts by whitedg
Old Nov 25, 2011, 04:54 PM
boticeli is offline
Joined Nov 2011
Just one more thing.
This was done without any 'load' on output.
Shoud I need to connect something on output?
Also, output voltage is present only 2 seconds, each time when I connect AC power
Old Nov 25, 2011, 08:38 PM
376782 is offline
Find More Posts by 376782
Near Kingston, Ontario, Canada
Joined Dec 2004
It should work but you could try to put a small load on it to be sure it will regulate and not shut down on over voltage. Some switching supplies rely on a small load and the cooling fan is usually enough of a load. Perhaps your fan is open circuit. Try a small load resistor ( 50 ohm) and let me know how you make out. Mine works fine without a load.
376782 is offline Find More Posts by 376782
Old Nov 26, 2011, 06:08 AM
pgleesonuk is offline
Find More Posts by pgleesonuk
United Kingdom
Joined Nov 2001
Hp dps-600pb
Yes, 12K-15K to Ground to slow down the fan speed.
Here is the rest of the pin mappings (Using Xandrios's image from post 586):
Outside Back Pin-- Wire Number
1----------------- +5VSB, not on ribbon wire
2----------------- +5VSB, not on ribbon wire
3----------------- +5VSB, not on ribbon wire
4----------------- 3 (Controls fan speed)
5----------------- -12V, not on ribbon wire
6----------------- 5 (PsKill)
7----------------- 6 (not sure what this one does)
8----------------- Ground, not on ribbon wire
9----------------- 8 (Voltage Adjust)
10---------------- 4 (PsOn)
11---------------- 9 (Current Share)
12---------------- 7 (not sure what this one does)
I have wired this up accorded to TjinTech's recommendation
10 + 6 + 9 shorted together. I get 12.64v
What is the "correct" way to connect the pins to get variable voltage (up to 13.6v)
thanks, Paul
pgleesonuk is offline Find More Posts by pgleesonuk
Old Nov 26, 2011, 06:18 AM
boticeli is offline
Joined Nov 2011
I tried with load, same issue
What about coolin fan inside, are they running by default or not
In my case, never started
Old Nov 26, 2011, 09:01 AM
xandrios is offline
Find More Posts by xandrios
Steven
xandrios's Avatar
United States, CT, East Hartford
Joined May 2010
Hey pgleesonuk,
pins 6,8 and 10 are the correct ones.
Then use a 1k ohm pot in series with a 330 ohm resistor
between pins 3 and 9 for voltage adjustment up to 13.6v.
xandrios is offline Find More Posts by xandrios
Old Nov 26, 2011, 10:58 AM
United Kingdom
Joined Nov 2001
Originally Posted by xandrios View Post
Hey pgleesonuk,
Old Nov 27, 2011, 09:46 AM
wbefield is offline
Find More Posts by wbefield
United States, GA, Lilburn
Joined Jun 2011
DPS-600 via Ribbon Cable
Mapping it for the ribbon wire:
1---------------- Gnd
2---------------- Gnd
3---------------- Pin 4 (Fan speed)
4---------------- Pin 10 (PsOn)
5---------------- Pin 6 (Ps Kill)
6---------------- Pin 7 (???)
7---------------- Pin 12 (???)
8---------------- Pin 9 (Voltage adjust)
9---------------- Pin 11 (Current share)
10--------------- Gnd (but so far I have not connected this and all seems to be OK).
First of all, I am a newb at this, and this is my first attempt to convert a server power supply.
Anyways, I have got it running via the hotswap board with no problems, but when I try to bypass the hotswap board and wire straight into the ribbon cable, The power supply will not switch on the the power output. Fan is spinning on low speed. I just hear a clicking sound coming out of the ps unit like something may be trying to switch on.
Any ideas as what this sound really is?
Am I missing something such as a resistor or capacitor(see one on the hotswap board)? could I be getting the pinouts on the ribbon cable mixed up? From what I could tell, Pin 1 is on the end of the connector where the red wire goes in on the side that's keyed...
Anyone have photos of this wired through the ribbon cable?
wbefield is offline Find More Posts by wbefield
Old Nov 27, 2011, 02:23 PM
whitedg is offline
Joined Feb 2010
From memory, on the ribbon cable, ensure that you have 1, 4 & 5 wired together (1 being the cable with the red stripe) and it should power up. Once you have that tested and confimred working, then you can work on the voltage adjustment and fan speed mods.
There is not much play with the ribbon wire, so you have to be careful with your soldering. I soldered some wire to the pins I removed from the daughter board to test this out, before removing the black connector from the ribbon cable.
Unfortunately I do not have any photo's of this as my camera was dead when I set mine up and they are now very well insulated.
Cheers
whitedg
Old Nov 28, 2011, 05:51 AM
pete236 is offline
Find More Posts by pete236
Joe from New England
pete236's Avatar
United States, MA, Beverly
Joined Apr 2011
Dell Z930P-00
Does anybody know the jumper settings for this PS?
I've searched this thread to no avail.
Thanks in advance.
Joe
pete236 is offline Find More Posts by pete236
Old Nov 28, 2011, 06:26 AM
United Kingdom
Joined Nov 2001
Cheers
whitedg
I saw another post that shorting pin 12 to 9 (on the hot swap connector) took the voltage to 13.6v
Anyone know if this is OK?
Old Nov 28, 2011, 07:52 AM
xandrios is offline
Steven
xandrios's Avatar
Joined May 2010
Hey pete236,
try pins A1 and B6 to ground combo as shown in the pic.
It seems to be a very common one for dell.
Also, use around a 500Ω resistor from each pin to ground to be safe.
Alert Need advice on high grade power supply for ISL-8 Byron Betterly Batteries and Chargers 7 Dec 07, 2003 08:31 PM
12volt, 9amp power supply for sale Paul Susbauer Aircraft - Electric - Airplanes (FS/W) 1 Dec 03, 2003 12:44 PM
12volt wallwart power supply reading 14.6 ? (help) power Batteries and Chargers 4 Sep 09, 2003 04:21 PM
Where to Get A Quality Power Supply? Joe Elston Batteries and Chargers 4 Apr 29, 2003 02:09 PM
High end charger and power supply for sale! Very new. ted616 Aircraft - Electric - Airplanes (FS/W) 6 Dec 02, 2002 11:31 PM
