In my mind, hooking up the +12v remote sense to +12v at the load would be good. (Actually, I hooked up the +12v and sense, and left everything else alone, no 1.5k resistor, no 6.8k resistor). Supply would just shut down under varying load, with a static load, it would exhibit drop and not shut down. The current share pin goes UP in voltage with load (as I believe you stated before, Xvolts =~ 10X amps). I don't understand why the 12v return line is getting fed this, but it makes sense that we're varying the output voltage by feeding the sense pin with a varying voltage that changes by the load (the current share pin) That by itself would seem to be enough to regulate the loss in the wire fairly well (By using a pot in place of the 6.8k resistor and adjusting it to dial it in) My question is: am I adding an unnecessary step by tying the +12v sense to the load via a jumper wire? Should varying values of the resistor where the 6.8k is be enough to offer 'good enough' regulation, or does the +12v sense wire always need to be used to have regulation? |
The +12 remote sense wire to the load is a good idea. Don't get rid of it!!
I was just saying that by combining both voltage sense methods. 1) The remote voltage sense method (the +12v jumper wire to load) and 2) The local voltage sense method (the one I used) we should be able to tweak the regulation to 0.00%. I've been using 4 AWG wire on my DL580 G3 PS. I get more of a voltage increase at the load with the +12v remote sense jumper wire when I combine it with the local voltage sense method. I would have to increase that 6.8k resistor to around 12k to compensate. I'm guessing that you are using smaller gauge wires for the load. You could probably use a slightly higher value than 6.8k. Maybe 7.2k or 7.5k. A tweak-able local voltage sense should be able to compensate for load wire sizes. Using a pot in place of the 6.8k resistor should do the trick... |
Got it. You're tied into the current share in lieu of a sense jumper wire to the load. (although the two arent mutually exclusive)
Just another case of working smarter not harder! Its very clever. Since im doing several for friends, i think ill just add a pot to theirs rather than risk jumper wires coming loose and starting fires. Looks like a good place for audio taper pots or some 10 turns. |
You got it.
It seems that a value of 20k in lieu ![]() of the 6.8k does the trick for me.I get 13.00v with no load and 13.00V at full load. I think that if you omit the 6.8k altogether for your setup, u will get a voltage drop of .02v while still using the +12v sense jumper. Still not bad. I only use 10 turns. ![]() ![]() And 2 heads are better than one. Nice!!! |
Polska, Zachodniopomorskie, Stargard Szczeciński
Joined Aug 2011
Hi jj604,
I have problem with Delta DPS800GB-A. I am not very familiar with forums of any kind. I have created a post #894 but it got completely "lost" among other posts on totally different topic. Could you please help me and give advice what should I do in order to get a little bit more interest of other users on my problem? Thanks in advance. Regards. ciesin |
Can anyone help with a DPS800GB?
See ciesin's question below.
Anyone got any experience with this particular PS? I have added it to the "seeking help" post on the sticky as well. Quote:
Near Kingston, Ontario, Canada
Joined Dec 2004
Thanks, Dave |
Joined Mar 2008
By the way, is this noise normal on a Dell 7000814? It doesn't come from the fan. It comes from the area next to the AC inlet.
http://jotto.livedrive.com/item/ceab...63a32bd5ec5941 Note: the sound is more pronounced in this video than in real. It is not so loud. If I touch the heat sink to the right, the noise is reduced. |
Joined May 2011
I managed to get the HP 406421-001 337867-501 PS, like the one stated in the first post that started this thread. I bought the PS from US and I live in Malaysia. Unfortunately, I couldn't find any plug/wire that can fit the PS. I am referring to the wire that goes from the PS to the wall AC socket..any help would be much appreciated...
| Thread Tools | |
| Alert Need advice on high grade power supply for ISL-8 | Byron Betterly | Batteries and Chargers | 7 | Dec 07, 2003 08:31 PM |
| 12volt, 9amp power supply for sale | Paul Susbauer | Aircraft - Electric - Airplanes (FS/W) | 1 | Dec 03, 2003 12:44 PM |
| 12volt wallwart power supply reading 14.6 ? (help) | power | Batteries and Chargers | 4 | Sep 09, 2003 04:21 PM |
| Where to Get A Quality Power Supply? | Joe Elston | Batteries and Chargers | 4 | Apr 29, 2003 02:09 PM |
| High end charger and power supply for sale! Very new. | ted616 | Aircraft - Electric - Airplanes (FS/W) | 6 | Dec 02, 2002 11:31 PM |
