Old Mar 22, 2011, 03:56 AM
outlawrc is offline
Find More Posts by outlawrc
outlawrc's Avatar
Deutschland, Schleswig-Holstein, Halstenbek
Joined Jan 2011
Originally Posted by xandrios View Post
To anyone interested, I Have included the full pinout for the 1300w DL580 G3 PSU that started this thread. I found it on the internet and hope that it's correct. Important!! Pin A1 starts at the bottom left in this pin matrix. Hopefully this will spark a firestorm of new mods.
Where did you find this ?
outlawrc is offline Find More Posts by outlawrc
Old Mar 22, 2011, 04:43 AM
flarssen is online now
Find More Posts by flarssen
Son, Norway
Joined Sep 2004
Originally Posted by KiloOne View Post
Make a plastic washer to go under the head of the two screws and put them back into the enlarged pcb holes (better yet use some 'hat' shaped isolating washers).
I think I will use nylon bolts for my mod. Will a plastic washer underneath the PCB at the screw area be enough, or is there really a need to isolate along the whole PCB edge?
Next question is whether to let both units float or not?
Fred
flarssen is online now Find More Posts by flarssen
Old Mar 22, 2011, 08:05 AM
xandrios is offline
Find More Posts by xandrios
Steven
xandrios's Avatar
United States, CT, East Hartford
Joined May 2010
Full Pinout for these pin compatible Power Supplies.
Astec/Emerson DS450-3/DS550-3, Sun Fire X4100/X4100 M2, X4200/X4200 M2, Dell Poweredge 1850, 2800, 2850, 2950, AA23290, AA23300, 7000814-0000, NPS700AB, N750P-S0, AHF-650-12-Y Full Pinout Assignment.
Astec manufactures the DS450-3/DS550-3.
The Sun Fire X4100/X4100 M2, X4200/X4200 M2 servers use the DS550-3 PSU.
The Dell 1850 AA23300 PSU is really a DS550-3 in disguise.
Dell 1850 AA23300 PSU and Astec DS550-3 voltage control modification 12V-14.2V.
http://www.rcgroups.com/forums/showp...postcount=1592
Connect PS On and PS Kill to ground to power up.
Pin B2 may be the analog fan control voltage input or may be left spare.
Connecting B2 to ground may slow fan speed and/or connecting to 3.3v may increase fan speed.
The accompanying Pinout from the Sun Fire™ X4100/X4100 M2 and X4200/X4200 M2 Servers Service Manual is for verification purposes.
xandrios is offline Find More Posts by xandrios
Old Mar 23, 2011, 12:38 PM
rjpmodel is offline
Find More Posts by rjpmodel
United States, TX, Cedar Park
Joined Dec 2002
"This is a simple way to measure the current draw from a DL580 G3 PSU. The voltage output is directly proportional to the current where 1v = 10 amps. So when your pulling 100 amps out of this supply you will get a reading of 10v. It comes in handy when you don't have a large external shunt resistor on hand. Original pic by jj604."
??? I measure 2.17V on this pin with no load ???
Xandrios. Have you figured out which pin was giving you 1V for each 10A yet?
Thank you. Bob.
rjpmodel is offline Find More Posts by rjpmodel
Old Mar 23, 2011, 01:49 PM
xandrios is offline
Steven
xandrios's Avatar
Joined May 2010
Sorry Bob. The pin I was using only became accurate after 35-40 amps draw. Only then did 1v = 10A. So its only good from 35a-100a. I didn't test below 35a. An oversight on my part.
Old Mar 23, 2011, 04:08 PM
rjpmodel is offline
Joined Dec 2002
Xandrios. Thank you for the reply. I will try the higher currents.
Bob
Old Mar 23, 2011, 11:17 PM
KiloOne is offline
Find More Posts by KiloOne
Dale Kramer
KiloOne's Avatar
United States, NY, Hammondsport
Joined Jul 2004
Fred,
I had the board completely removed when I decided to isolate both edges of the board. There must have been a reason. Take the board out and look for yourself, sorry I can't do that right now.
Dale
KiloOne is offline Find More Posts by KiloOne
Old Mar 27, 2011, 11:49 AM
outlawrc is offline
outlawrc's Avatar
Joined Jan 2011
For anyone interested this should be the pinout for the Poweredge 2800 and 2850 series PS units. The ps-kill and pson match up. As do all ground and +3v pins. This is a compatible model PSU.
Thank You so much for that !
Lets see what we can do with all this
Strange is, that my way to turn it on works via D6 and C5
Old Mar 27, 2011, 05:32 PM
xandrios is offline
Steven
xandrios's Avatar
Joined May 2010
Pinout
Outlawrc. I think your talking about the Poweredge 2600 series PSU which uses the D6 and C5 pins. Both the 2800 and 2850 use the A1, B6 and Ground.
Old Mar 27, 2011, 08:25 PM
Elyranger is offline
Find More Posts by Elyranger
North Country Flyer
Elyranger's Avatar
Minnesota
Joined Mar 2008
Shorting to ground will achieve the lowest speed possible. The second 1k or R2 is between red and ground. You can adjust the value of the second 1k to meet your needs. Making it less than 1k will make it speed up less to somewhere between med and max. Just give it enough to cool the PSU down...
Does anyone have a photo of the finished product? I would like to see how the resistors have been hooked up
Elyranger is offline Find More Posts by Elyranger
Old Mar 28, 2011, 05:55 AM
xandrios is offline
Steven
xandrios's Avatar
Joined May 2010
Outlawrc. Just saw your question about where I found the DL580 G3 psu pinout. Sun Microsystems used a compatible PSU in several of their systems. Check out the Sun Storage 7210 Unified Storage pdf or the Sun Virtual Tape Library pdf online. A couple other systems also used the same PSU. They even have a 1500w variant.
Old Mar 28, 2011, 08:43 AM
outlawrc is offline
outlawrc's Avatar
Joined Jan 2011
Xandrios, sorry for mixing up 2600 and 2800...
I will have a look to Sun *RIP*
Old Mar 28, 2011, 09:09 AM
extreme heli is offline
Find More Posts by extreme heli
Joined Jan 2011
HP 1300W Proliant ML570 DL580
For those who may have an interest to my original post 2 pages back on getting the fan speed reduced to human levels, I bring to you this follow up with performance results and hard data. Yay data!
Short 10Awg wire this time to eliminate my weak link of smoking wires. Only ran max rated 900W @ 120V this time as well for first duration test. Hottest points on indicated areas recorded. Temps were actually cooler than antisipated as I expected a more prominant runaway over time. Again pleasantly surprised
----Fans Modified with 2W 10Ohm Resistors - Temps in F*
---500W@15min---900W@5min---10min----15min----20min
Case-----90.7*---------96.4*--------101.1*----101.2*----100.8*
Exhaust-110.4*--------118.9*--------121.6*----123.6*----125.4*
Wires---110.4*--------169.7*--------183.4*----189.5*----189.1*
Worth noting is exhaust temps were on average 5-10*Deg cooler on average, peaks seemed to be seen on large red coil near center rear which were recorded.
Also out of intrest i loaded a well reviewed Db levelmeter app for my iphone to put in numbers the sound level changes.
Sound Levels in Db
Static Room - 53
Bath Room Fan @ 10" - 73
-----------------Modified fan------Stock Standby------Stock Full
10" to side------------64----------------75----------------79
10" from intake--------73----------------81----------------86
10" from exhaust------70----------------76----------------84
Numbers denote a dramatic improvement yes, but personally feel they don't do the reality of the human factor being surrounded by such noise pollution justice.
Anywho, just thought I'd share again my findings to follow up my previous posts.
Darren
extreme heli is offline Find More Posts by extreme heli
Old Mar 28, 2011, 05:05 PM
xandrios is offline
Steven
xandrios's Avatar
Joined May 2010
Nice job with those temperature readings Frank. In a worse case scenario, the supply would probably shut down due to thermal overload.
The daughterboard to the right of that large red coil houses four 20N60C3 mosfets (TO-3P package). This seems to be the only part of this supply that gets warm.
This supply uses the ADM1041A IC. Its a Secondary-Side Controller with Current Share and Housekeeping. Basically it controls all the output current and voltage parameters. It sits underneath the two internal fans. The OVP and UVP threshold settings are digitally programmable through registers via the SMBus at register addresses 0Ah and 09h. Pin 20 (Vs+) is part of the differential remote sense amplifier. It connects externally to pin C5 which is why we are able to control the voltage settings.
Old Mar 29, 2011, 09:13 AM
Joined Jan 2011
Thanks xandros. Yes i saw that bank of mosfets guess they heat soak that half. Speaking of on my initial rigging intended for 24V series using only half the output blades, I did note the linked mosfets kicked out a fair bit more heat as they handled all the work. No data, just observation since utilizing all output blades as design intended unit seemed to be happier.
Lots of good info there, almost cresting my comprehension, after all I do have corks in my neck. so I assume that secondary side controller board is the one that fries itself, judging by the view window under the unit?
Alert Need advice on high grade power supply for ISL-8 Byron Betterly Batteries and Chargers 7 Dec 07, 2003 08:31 PM
12volt, 9amp power supply for sale Paul Susbauer Aircraft - Electric - Airplanes (FS/W) 1 Dec 03, 2003 12:44 PM
12volt wallwart power supply reading 14.6 ? (help) power Batteries and Chargers 4 Sep 09, 2003 04:21 PM
Where to Get A Quality Power Supply? Joe Elston Batteries and Chargers 4 Apr 29, 2003 02:09 PM
High end charger and power supply for sale! Very new. ted616 Aircraft - Electric - Airplanes (FS/W) 6 Dec 02, 2002 11:31 PM
