Old Mar 20, 2011, 04:38 PM
ancora imparo
jj604's Avatar
Melbourne, Australia
Joined Jul 2005
Great find xandrios. You have no idea how much time I spent looking for this and how much time it would have saved me.
At least now we know why the mod works.
Ironically the logic I used that the short pin was somehow critical was correct but I got the wrong short pin. A3 not B4 is the PS_Present pin. Be interested to see what folks come up with playing around with these. I have added a reference to your diagram to the original post.
John
Originally Posted by xandrios View Post
To anyone interested, I Have included the full pinout for the 1300w DL580 G3 PSU that started this thread. I found it on the internet and hope its correct. Hopefully this will spark a firestorm of new mods.
jj604 is offline Find More Posts by jj604
Old Mar 20, 2011, 04:40 PM
Maryborough Qld
Joined Oct 2006
Excellent thread fellas.
I'm now wondering if the voltage regulation can be raised to 13.5-13.8 volt using xandrios's great find/mod along with the internal trimmer i think was mentioned earlier.
Craig 01 is offline Find More Posts by Craig 01
Old Mar 20, 2011, 05:33 PM
Steven
xandrios's Avatar
United States, CT, East Hartford
Joined May 2010
Yeah. It now seems that there are a couple of other pin combinations that will get this PSU up and running. I've found 2 others already. It's gonna be a fun week....
xandrios is offline Find More Posts by xandrios
Old Mar 20, 2011, 06:42 PM
ancora imparo
jj604's Avatar
Joined Jul 2005
If you are really keen, pins B5 and B6 are I2C data signals. You could probably get this thing displaying its status on a computer screen.
John
Old Mar 20, 2011, 07:04 PM
Steven
xandrios's Avatar
Joined May 2010
Revision for DL580 G3 current measurement.
I'll have to revise the current measurement post. I used between 35 amps and 100 for testing. I'll be back with the correct pinout soon.
Old Mar 20, 2011, 07:14 PM
Steven
xandrios's Avatar
Joined May 2010
Yeah. Servers rely on these pins to monitor PS status. I don't see a fan speed output pin on this supply, although it may be integrated within the I2C stream. I have yet to see any monitoring software that can access the fan speed on these PSU's though. This leaves me to think there is no way to externally adjust fan speed. Damn!!
Old Mar 21, 2011, 12:35 PM
Joined Dec 2002
"This is a simple way to measure the current draw from a DL580 G3 PSU. The voltage output is directly proportional to the current where 1v = 10 amps. So when your pulling 100 amps out of this supply you will get a reading of 10v. It comes in handy when you don't have a large external shunt resistor on hand. Original pic by jj604."
??? I measure 2.17V on this pin with no load ???
rjpmodel is offline Find More Posts by rjpmodel
Old Mar 21, 2011, 01:36 PM
Steven
xandrios's Avatar
Joined May 2010
Yeah. Sorry about that. I'll be back with the correct pinout soon. I had a lot of wires running for the test. My voltage regulation/mod for the DL580 is guaranteed to work though. I've set up several PSU's that way. Thanks for the heads up...
Old Mar 21, 2011, 01:46 PM
Airborn Maniac
United States, FL, Fort Myers
Joined Jan 2009
I am still having problem trying to reduce the fan noise for HP PROLIANT DL580/ML570G3 RPS REDUNDANT POWER SUPPLY. P/N: 348114R-B21 that stated by JJ604 in the first thread. I wonder if anyone have pictures on the connections to where the resistor go or what to use to lower the noise.
Thank you,
teo
die4good is offline Find More Posts by die4good
Old Mar 21, 2011, 02:11 PM
Steven
xandrios's Avatar
Joined May 2010
Look back one page in this thread. There are some good pictures of what to to.
Old Mar 21, 2011, 07:54 PM
Airborn Maniac
Joined Jan 2009
I thank you soo much xandrios. I went to Radio Shacks but they do not have 2w 10ohm, so I pick up the 1w 10ohm and it is so quiet. I would rate it as equal to a desktop computer psu
Old Mar 21, 2011, 08:20 PM
Joined Dec 2002
I am confused why everyone is trying to lower the fan speed. This is a high power supply and wil certainly not put out the high power with the fan running at a slow speed to reduce the noise. If you wanted a lower power supply, you should have saved some money and bought a lower power supply. I personally appreciate the high power of this supply and accept the noise. I have 4 of these supplies.
Xandrios - I think I speak for all of us that own this great supply monitoring this thread in saying THANK YOU for sharing your findings.
Old Mar 21, 2011, 08:52 PM
Southern Pride
everydayflyer's Avatar
Haralson County GA. USA
Few hobbiest use these server power supplies at any where near a 100% load for over an hour much less 24/7. Also most do not have them in a fairly high temperature environment. My IBM 235s in series for 24V @ 30amps. spend most of their under load time at under50%.
Charles
Old Mar 21, 2011, 09:28 PM
Steven
xandrios's Avatar
Joined May 2010
Don't forget about jj604. He's the one who started this thread and the first to modify this power supply. He's been here since day one!!
Old Mar 22, 2011, 02:54 AM
Joined Dec 2002
Yes jj604. Thank you also. 24/7 or 1hr or 1/2 hour probably would not matter. I doubt you could run at full load for 20 minutes with a fan running at at half speed. Just my opinion. Have not tried. I have run at 8OA for 1/2hr with regular fan speed without heating problems.
Alert Need advice on high grade power supply for ISL-8 Byron Betterly Batteries and Chargers 7 Dec 07, 2003 08:31 PM
12volt, 9amp power supply for sale Paul Susbauer Aircraft - Electric - Airplanes (FS/W) 1 Dec 03, 2003 12:44 PM
12volt wallwart power supply reading 14.6 ? (help) power Batteries and Chargers 4 Sep 09, 2003 04:21 PM
Where to Get A Quality Power Supply? Joe Elston Batteries and Chargers 4 Apr 29, 2003 02:09 PM
High end charger and power supply for sale! Very new. ted616 Aircraft - Electric - Airplanes (FS/W) 6 Dec 02, 2002 11:31 PM
