Old Dec 27, 2010, 03:30 PM
ancora imparo
jj604's Avatar
Melbourne, Australia
Joined Jul 2005
See this post and the diagram in post 183 in the "2 supplies - safety" thread.
http://www.rcgroups.com/forums/showp...&postcount=209
John
Originally Posted by Heliskip View Post
Hey jj604,
earlier you have been talking about a neon light between the cases to warn about a short between them.
Which light did you use or can be used?
Cheers
Heliskip
jj604 is offline Find More Posts by jj604
Old Dec 31, 2010, 12:30 AM
USA, CA, Sunnyvale
Joined Nov 2008
Originally Posted by bobt2 View Post
ok, i got a hpdps600. when i plug it in, i get the fan in low speed and no light. . i have jumped the 3 pins and the supply doesn't come on. i used pins 6-8-10 and theres no change. it looks like 6&8 have 4 volts on them and i guess i,m grounding them.any ideas?
Hi,
6-8-10 has worked on 3 of these power supplies for me. 6 is the short pin. Some people have had problems with servo connector receptacles not working, I use JST-XH balance connector receptacles.
There is a link a few pages back to another web page with a slightly different jumper connection.
Maybe your p/s is bad? Slow fan speed on powerup is what I saw also.
Good Luck.
M
MDavis22 is offline Find More Posts by MDavis22
Old Jan 06, 2011, 11:59 AM
TJin(Guy + Tech)
tjinguy's Avatar
United States, NM, Socorro
Joined Jun 2008
Originally Posted by flarssen View Post
I have a supply for Dell PowerEdge 2650 (12V 57A max) and after reinventing the wheel, I saw this post . Grounding #19 fires up the 3.3V part, row 3 (-) and row 4 (+), only. Also gives some voltage on #18 and when this one is grounded, 12V output is turned on. I only get 11.9V though, both with a light load and noload.
Wish pinout was available. Maybe voltage can be adjusted via some of them?
Edit:
It happily delivered 48A to my charger and voltage was stable.
Part# Dell 7000814-0000
Connect both X's to ground (G):
G . - + . .
G . - + . X
X . - + . .
Fred
I believe you have the server model number wrong for this PS. The PS in PowerEdge 2650 is a 500W unit. Those units are very common on eBay and such. The unit you describe here sounds like a PowerEdge 2850 PS, which is indeed rated at 700W, or 12V 57A. The model number is NPS-700AB. Your pin-out works great on this unit. I have put together a how-to on my site.
https://sites.google.com/site/tjingu...-tos/server-ps
tjinguy is offline Find More Posts by tjinguy
Old Jan 06, 2011, 06:04 PM
Joined Dec 2010
The 2850/2950 dell series has been replaced by their 'n' series (n705...).
The power supply out of the N705 is a 'Z700P-00' which is about 40% shorter in size than the 2850/2950 supplies and has the exact same back side connectors (including no fan cover) :/
pretty good chances of the pin-outs matching your 2850 mod above?
looks like this one puts out 58A/700w, but that is probably at the full 240v source? not sure what it will push out at 120v.
iThinman is offline Find More Posts by iThinman
Old Jan 07, 2011, 01:34 AM
Son, Norway
Joined Sep 2004
You are correct. I have changed the server model in my post.
Fred
flarssen is offline Find More Posts by flarssen
Old Jan 07, 2011, 04:11 PM
Joined Dec 2010
Same pinouts worked. But the thing is a jet engine and I doubt I'll use it.
Old Jan 08, 2011, 03:27 AM
Son, Norway
Joined Sep 2004
The cooling is a bit overkill for usage in normal environments. Just turn the RPM down a bit using a series resistor or run the fan on 5V:
http://www.rcgroups.com/forums/showp...&postcount=219
Fred
Old Jan 08, 2011, 10:13 AM
TJin(Guy + Tech)
tjinguy's Avatar
Joined Jun 2008
I don't mind the sound cause it reminds me I am charging
Old Jan 17, 2011, 03:10 AM
outlawrc's Avatar
Deutschland, Schleswig-Holstein, Halstenbek
Joined Jan 2011
Originally Posted by hubgar View Post
Just finished mine thanks to you guys. I’ve had this supply for a while but just couldn’t get it to start. Reread all the posts, comparing to the other Dells, and about 15mins of trying different combinations on the control pins then BINGO, heard a relay click then the fans started. (He smiles).
I found three trim pots on a circuit board in the power supply which I hoped adjusted the voltage. I marked the wiper positions with a fine marker so I could always find the original settings in case something went wrong. One trim pot did indeed adjust the voltage. I don’t know what the other trim pots do. Range was 12.6v to 13.6v.
No problem with over voltage shutdown at 13.6v.
I’ll only be using this supply at about 20A for now hence the use of only one pair of output blades.
The pictures below explain the connections.
Great thread, thanks guys.
Hi
i have 4 of those here in my desk
I did the conversion based on your pitures.
I use Junsi iCharger 106b+
Sometimes, when the PSU is running and i connect the charger, the PSU will shutdown, the other way around, it works.
Have you seen anything like this ?
Can you take a picture of the pot, where you adjusted the voltage ?
There are 3 on a vertical board inside
I also could not get the switch to work...
outlawrc is offline Find More Posts by outlawrc
Old Jan 17, 2011, 09:13 AM
You can call me FANBOY!
Goodlettsville, TN
Joined Sep 2006
Most likely the current spike when you connect the charger causes the PSU to shut down to protect itself. Keep in mind even though these are hot swap capable supplies they have a soft start feature when used in a server. You should always connect the charger before powering the unit on.
chrisf testpilot is offline Find More Posts by chrisf testpilot
Old Jan 18, 2011, 08:53 AM
Joined Jan 2011
Did you get the dps-460BB running?
BattlerBritton is offline Find More Posts by BattlerBritton
Old Jan 18, 2011, 12:04 PM
outlawrc's Avatar
Joined Jan 2011
Looks like thats the problem...
Connect the charger first ... works !
This is the first time i can use the full power of my iChargers...
Old Jan 18, 2011, 08:59 PM
Toronto Canada
Hi outlawrc.
Here's the pic you wanted.
The pot with the driver adjusts the output voltage.
Same deal here with shutdown on charger connection. Connect charger before plugging supply in.
I don't know why your switch does not work. Are you sure you followed the pinout I posted? The yellow I used for
the connections did not show well.
Hope this helps,
hubgar.
hubgar is offline Find More Posts by hubgar
Old Jan 18, 2011, 09:42 PM
Bellbrook, Oh
Joined Jul 2008
Any ideas on a dell server ps nps330bba to get it running before i let the smoke out. I have the circuit board pluged in to the ps, there are several red 5.5v, yellow 12v, black wires gnd, and 1 blue wire all, all wires are on a plug that plugs into the circuit board
madatme is offline Find More Posts by madatme
Old Jan 19, 2011, 03:19 PM
Toronto Canada
Hi madatme.
I think what your describing is more of a regular pc power supply than the powerful server power supplies in this thread.
There are many conversions for the pc type. Check here.
http://web2.murraystate.edu/andy.bat...OWERSUPPLY.HTM
hubgar.
Alert Need advice on high grade power supply for ISL-8 Byron Betterly Batteries and Chargers 7 Dec 07, 2003 08:31 PM
12volt, 9amp power supply for sale Paul Susbauer Aircraft - Electric - Airplanes (FS/W) 1 Dec 03, 2003 12:44 PM
12volt wallwart power supply reading 14.6 ? (help) power Batteries and Chargers 4 Sep 09, 2003 04:21 PM
Where to Get A Quality Power Supply? Joe Elston Batteries and Chargers 4 Apr 29, 2003 02:09 PM
High end charger and power supply for sale! Very new. ted616 Aircraft - Electric - Airplanes (FS/W) 6 Dec 02, 2002 11:31 PM
