Old Dec 05, 2010, 12:19 AM
jj604 is offline
Find More Posts by jj604
ancora imparo
jj604's Avatar
Melbourne, Australia
Joined Jul 2005
Good news. I'll put a link to this post on the summary thread.
john
Originally Posted by hubgar View Post
<edit>.
The pictures below explain the connections.
Great thread, thanks guys.
jj604 is offline Find More Posts by jj604
Old Dec 10, 2010, 06:59 PM
Homesick_Angel is offline
Find More Posts by Homesick_Angel
Thermal Chaser
Homesick_Angel's Avatar
Joined Nov 2010
This thread has made me a power supply hoarder. Every time I see one I find myself looking at the amp/voltage outputs. LOL
Homesick_Angel is offline Find More Posts by Homesick_Angel
Old Dec 10, 2010, 07:24 PM
linw is offline
Find More Posts by linw
Wellington, NZ
Joined Aug 2006
Me, too! I had to discipline myself after no. 6!! Stopped looking, now.
Still looking for homes for a couple of mine.
linw is offline Find More Posts by linw
Old Dec 10, 2010, 10:58 PM
cron is offline
Find More Posts by cron
Gatineau, QC, Canada
Joined Oct 2007
I finally decided to bite the bullet. A friend of mine bought a Meanwell PS and started charging his batteries at 10A (about 15 minutes for two in parallel). Argh... My laptop PS (4A) lets me charge one battery in about 30 minutes. Time for a change.
PS: HP ESP-115 (Model PS-5551-2, Part No. 216068-002)
From what I can read, the output seems to be 30A at 12V, which is more than enough for my iCharger 106b+ (10A max).
The pins to short to make it start are the following:
N N N N N
Y Y N N N
N N N N N
N Y Y N N
There are 6 tabs on one side and 4 on the other side. From left to right, the first two are 3.3V, the next two are 5V and the last two before the pins are 12V. The 4 to the right are ground.
The first time I powered it up, I was surprised it's very silent. In fact, I thought it wasn't working properly. The fans run at 100% on connection (self test) and then go down to a level where it's barely impossible to hear them. I guess they'll make more noise when I'll start charging, but it shouldn't exceed the self test level which is quite similar to my laptop. I'm very impressed so far, but I still have to charge two batteries in parallel (tomorrow).
Anyway, thanks a lot for all the help and to give me the idea to reuse something that was going to be thrown away.
cron is offline Find More Posts by cron
Old Dec 14, 2010, 07:37 PM
tascheri is offline
Find More Posts by tascheri
Fly like never crash as always
tascheri's Avatar
Rio de Janeiro
Joined Mar 2007
Used Server PSīs
Does anyone know if these are any good? Itīs a deal ($70) for the whole lot. If size matters...
Wish I knew more.
tascheri is offline Find More Posts by tascheri
Old Dec 15, 2010, 04:25 PM
gtanoira is offline
Find More Posts by gtanoira
gtanoira's Avatar
Florida
Joined Aug 2008
AWG for 25A?
jj and others,
what AWG cable are you using?
I have a couple of HP 12V 106A PSs (same as JJ). Not sure if I should get AWG 12 or 14. I have some 14 avail and fits perfectly inside the blades but I am not sure if it is big enough to handle max 25A.
I am thinking of getting 12AWG but not sure if it fits inside the blades without braking them.
Any suggestion greatly appreciated.
Thanks!!
Gaston
gtanoira is offline Find More Posts by gtanoira
Old Dec 15, 2010, 06:46 PM
chrisf testpilot is offline
Find More Posts by chrisf testpilot
You can call me FANBOY!
Goodlettsville, TN
Joined Sep 2006
Personally with that much power available I would go with 12. You should be able to make it work without breaking anything if you are careful.
chrisf testpilot is offline Find More Posts by chrisf testpilot
Old Dec 15, 2010, 07:34 PM
jj604 is offline
ancora imparo
jj604's Avatar
Joined Jul 2005
12 will work fine. 10g is too big, hard to solder because of the thermal mass and unnecessary. I personally would use HK's 12g silicone wire. Cheap, good quality and it is very flexible and malleable. The strands just move around to fit between the blades. Theoretically you should tin the wire first but I would just push it between the blades and heat the whole thing to solder it. Really easy if you use a big enough soldering iron so it stays hot.
Old Dec 15, 2010, 07:50 PM
Goodlettsville, TN
Joined Sep 2006
Thats the way I would do it. I order the good silicone wire from RadicalRC, surprisingly its not much more expensive than HK. Its $6 for 1 meter of red and black in 13ga. They have 11, 13, 14, and 16 but not 12. Always thought that was kinda funny for some reason.
Old Dec 15, 2010, 08:48 PM
jj604 is offline
ancora imparo
jj604's Avatar
Joined Jul 2005
For what it's worth here are the recommended current limits for chassis wiring of various American wire gauges. This is for solid Cu from memory but won't be far out. Also you can pass more current - it just gets warm!
10g - 55A
11g - 47A
12g - 41A
13g - 35A
14g - 32A
15g - 28A
16g - 22A
Old Dec 15, 2010, 08:58 PM
Goodlettsville, TN
Joined Sep 2006
10g - 55A
11g - 47A
12g - 41A
13g - 35A
14g - 32A
15g - 28A
16g - 22A
You have done this a few times havent you
http://www.powerstream.com/Wire_Size.htm
Old Dec 17, 2010, 08:44 PM
iThinman is offline
Find More Posts by iThinman
Joined Dec 2010
Hi extremely smart people.
I'm hoping for some help. I have an HP part #379123-001 that appears to have been mentioned here previuosly without resolution.
I have the following thread which contains a few detailed pictures that I am hope someone would be kind enough to review and reply to (here or there is fine).
RCTech forum thread
Thanks a lot for the time and help!
iThinman is offline Find More Posts by iThinman
Old Dec 20, 2010, 02:24 AM
linw is offline
Wellington, NZ
Joined Aug 2006
Couple of mysteries. Don't understand where you get the big pin nos. like 1-12 and 53-54.
Ref pic 5, the 3rd from left is annotated with 5.14V and 'continuity to body'. Can't both be right.
The first step is always to find the short pin or tab. Yours is the 2nd tab pic 5. Ground this and see if this starts it. My HP DL360/380 only needs this mod so yours might be the same.
In any case, this will be needed even if another one needs to be grounded as well.
Let's know how this goes.
Old Dec 20, 2010, 08:22 AM
iThinman is offline
Joined Dec 2010
Hi, Thanks for the reply.
The pin numbers are printed on the circuit board. by 1-12 i meant pins 1 through 12 (its just one big pin though).
i double checked the 5.14 noted and i had the meter backwards :| it does not ground to body.
So I soldered a wire to that second (shortest) pin and grounded it. Nothing.
Any ideas what to try next?
Thanks again!
Old Dec 20, 2010, 10:18 AM
Goodlettsville, TN
Joined Sep 2006
In most cases it takes two control pins to turn the supply on. And dont just go by the fan turning on as to whether or not its hot. I have a Compaq that the fans didnt turn on until there was a substantial load on it. I would try grounding both small pins that show voltage to the ground next to them while checking for 12+v on the large pins. One or the other or both should work.
Alert Need advice on high grade power supply for ISL-8 Byron Betterly Batteries and Chargers 7 Dec 07, 2003 08:31 PM
12volt, 9amp power supply for sale Paul Susbauer Aircraft - Electric - Airplanes (FS/W) 1 Dec 03, 2003 12:44 PM
12volt wallwart power supply reading 14.6 ? (help) power Batteries and Chargers 4 Sep 09, 2003 04:21 PM
Where to Get A Quality Power Supply? Joe Elston Batteries and Chargers 4 Apr 29, 2003 02:09 PM
High end charger and power supply for sale! Very new. ted616 Aircraft - Electric - Airplanes (FS/W) 6 Dec 02, 2002 11:31 PM
