Old Sep 17, 2010, 05:54 AM
everydayflyer is offline
Southern Pride
everydayflyer's Avatar
Haralson County GA. USA
and the thread title is
A simple high quality 12Volt 100Amp Power Supply- Part1
My guess is that 95% plus of those use personal computer or server supplies do so to save money.
Charles
Old Sep 17, 2010, 06:44 AM
jj604 is online now
Find More Posts by jj604
ancora imparo
jj604's Avatar
Melbourne, Australia
Joined Jul 2005
And the other 5% of us just like the satisfaction of re-using good technology that is otherwise chucked out, and figuring out how to save everybody some money at the same time.
To be perfectly honest, a good PS is such a long term investment that personally I wouldn't resent spending several $100 on it - but where's the fun in that? These converted server supplies ARE the best you can buy - they were just built for another purpose.
Charles
jj604 is online now Find More Posts by jj604
Old Sep 17, 2010, 08:46 AM
Southern Pride
Problem is that one can not purchase a purpose built quality 50A 24V power supply for $100 or even $200 for that matter. Price some Meanwells or Mastech bench power supplies. On top of that it has recently came to light that these are not as clean / stable power out put wise as the server power supplies are.Well at least not when used with a specific charger.
Durability. I have had 3 nominal 12V 15A switcher power supplies to die on me over the years they all cost more and they all saw less usage than any of my server power supplies have. I have tried to kill my server power supplies but their built in safety devices are just to good. I am fairly sure that some do fail in service but it must be a very samll percentage.
If it were not for us tinkers RC would not be nearly as much fun and there would have been a lot less advancements made.
Charles
Old Sep 17, 2010, 10:48 AM
die4good is offline
Find More Posts by die4good
Airborn Maniac
United States, FL, Fort Myers
Joined Jan 2009
I have another question. which one is the most compact server PS that successfully converted.
die4good is offline Find More Posts by die4good
Old Sep 17, 2010, 02:49 PM
earlwb is offline
Find More Posts by earlwb
earlwb's Avatar
USA, TX, Grapevine
Joined Dec 2008
That is likely some of the power supplies that FeatherMerchant converts for battery charging purposes. http://www.rcgroups.com/forums/member.php?u=19395
earlwb is offline Find More Posts by earlwb
Old Sep 17, 2010, 05:48 PM
jj604 is online now
ancora imparo
jj604's Avatar
Joined Jul 2005
That's a slightly ambiguous question. PS supplies are like girls - they come in different configurations and everybody may have there own preference. Do you like them long and thin or short and compact?
In terms of brute Watts/cubic inch I suspect the original on this thread I started with is hard to beat. It puts out a lot of power for a very small box, the 2x12=24V version is even scarier. I personally use an old Cisco Router PS on the bench which is long and thin and fits better (as well as being lots quieter) because it supplies all the current I need most of the time.
I've seen two long thin ones put two together for 24V and put in a field box with chargers etc on top - nicely compact overall..
John
Old Sep 22, 2010, 07:10 AM
Ajohnw is offline
Find More Posts by Ajohnw
B'ham UK
Joined Jul 2010
The 12v 47amp one shown in the link is a HP DPS-600PB measuring 55x78x280mms+handle. I just converted one using the instructions from this site as far as which pins to short out to get it to power up. They are diagonally arranged so I used 3 0.1ins pitch connectors that I bought some time ago for servo's. These are dirt cheap and the wires have to be soldered on which works out ok in practice. The connections are ground,ps kill and ps enable. I suspect the enable is the shorter pin on the central matrix of pins.
It powers up well running a few tenths of a volt over spec with no load. The fan is a little on the noisy side. Going on amateur radio posts there is a slight chance that it may slow down when a load is applied. Some supplies those guys use have no fan but they advise fitting one if the supply is to be used without a load.
One thing I'm hoping some one can tell me is what these supplies do if overloaded? Some supplies will just dump max current into the load others will fold back to a much lower current and remain like that till something is done about it. Some need disconnecting from the mains to reset them. Any one have any experience? I mainly want to run a motor with mine and it may just happen to get over loaded. ;-) Hope they don't blow up.
John
Ajohnw is offline Find More Posts by Ajohnw
Old Sep 22, 2010, 07:36 AM
Southern Pride
Server power supplies I have used / tested are the IBM 235 and hp ESP114 and if overloaded,shorted ,etc. they just shut down and have to be powered down for around 30 seconds then powered back up. I have read the same thing happens with several other server types.
Charles
Old Sep 22, 2010, 07:44 AM
jj604 is online now
ancora imparo
jj604's Avatar
Joined Jul 2005
I second Charle's advice for the ones I have played with. Given they are 24x7 supplies, it would make sense that if a fault was detected they would shut down (and the "Error" light comes on or blinks). They are probably smart enough to phone home to HP and get a replacement ordered and bill you automatically for all I know.
Also, if you start them under too high a load (such as cold light globes) they just won't power up.
John
Charles
Old Sep 22, 2010, 09:00 AM
Ajohnw is offline
B'ham UK
Joined Jul 2010
Thanks. That sounds great and all for 99 uk pence new.
I have a lathe and sometimes want to drill cross holes or mill the sides of turned parts and hope to adapt a 800kv 60 amp brushless motor and speed controller to the task. I've no idea what the motor will take at 12v hence the worry. I might also try to use it as a tool post grinder. With luck if it all overloads I will just have to turn it all off and back on again. The 47a rating of the supply might even save the speed controller.
John
Old Sep 22, 2010, 04:47 PM
jj604 is online now
ancora imparo
jj604's Avatar
Joined Jul 2005
John, the old "rule of thumb" suggests it will be fine. A big 1/2" 12V cordless drill would probably drill the holes and do the milling you want easily so the mechanical energy required is well within the capacity of a 12V, 25A device.
For example the "Dewalt DC940KA Heavy Duty XRP 12V Cordless Drill/Driver Specifications: Voltage 12 V Max Power 290 W"
John
John
Old Oct 02, 2010, 08:53 AM
Wayne Giles is offline
Find More Posts by Wayne Giles
Rugby, UK
Joined Feb 2007
I have just bought and converted an HP Power Supply DPS-600PB and it works fine. As it is difficult/impossible/expensive to obtain the mating rear connector, I have soldered a couple of 4mm test sockets between the blades of the existing connector which makes a convenient termination.
The extra low Z capacitor is only to reduce pk - pk ripple to about 60mV at full load and not strictly necessary.
BTW I think the only real ground pin is pin 8 which pins 6 and 10 should be commoned to in order to enable the main 12V output. Full Load regulation is only 0.11V and the overload characteristic is trip off at about 56A, break input to reset.
So as I paid 9.50, I now have a good 12V, 50A psu for just over a tenner!, ($16)
Wayne
Wayne Giles is offline Find More Posts by Wayne Giles
Old Oct 02, 2010, 02:34 PM
linw is offline
Find More Posts by linw
Wellington, NZ
Joined Aug 2006
Nice one. Hard to argue value for money!
linw is offline Find More Posts by linw
Old Oct 02, 2010, 06:30 PM
jj604 is online now
ancora imparo
jj604's Avatar
Joined Jul 2005
Thanks, Wayne. I have put a link to this on the summary page that starts here.
http://www.rcgroups.com/forums/showp...18&postcount=1
for folks who are converting this supply.
Can you post a picture of the PS label just to make it easy to positively identify it? There's at least two (quite different) HP "600" PS that I know of.
John
Old Oct 03, 2010, 12:09 PM
Rugby, UK
Joined Feb 2007
Here is the label identifying the PSU type modified in Post 312.
Wayne
PS Although it's HP, I note it's made in China - will it be reliable!! I remember buying a HP 4digit DVM in 1969 for 450, that's 5178 in todays' prices, over $8000! - how things change! - that wasn't made in China.
Alert Need advice on high grade power supply for ISL-8 Byron Betterly Batteries and Chargers 7 Dec 07, 2003 08:31 PM
12volt, 9amp power supply for sale Paul Susbauer Aircraft - Electric - Airplanes (FS/W) 1 Dec 03, 2003 12:44 PM
12volt wallwart power supply reading 14.6 ? (help) power Batteries and Chargers 4 Sep 09, 2003 04:21 PM
Where to Get A Quality Power Supply? Joe Elston Batteries and Chargers 4 Apr 29, 2003 02:09 PM
High end charger and power supply for sale! Very new. ted616 Aircraft - Electric - Airplanes (FS/W) 6 Dec 02, 2002 11:31 PM
