Old Sep 10, 2010, 04:18 PM
nairbg is offline
Find More Posts by nairbg
BrianG
Edonton, AB
Joined Jun 2009
Originally Posted by everydayflyer View Post
Well the max the PL8 can draw is 50amps. which should be a walk in the parkk for this supply so why not set it at that?
Charles
I am concerned about pulling 50A through just 4 output blades.
I have a "y" connector to couple both banks but In this instance I want to use the other bank for the TP601C.
Is pulling 50A from only one bank of output contacts OK?
nairbg is offline Find More Posts by nairbg
Old Sep 10, 2010, 04:52 PM
everydayflyer is offline
Southern Pride
everydayflyer's Avatar
Haralson County GA. USA
I pull 30A from single contact on IBM 235 server power supplies and 50 amps. from dual (2 sets) of contacts from my hp ESP 114 server power supplies. My rule of thumb is if they do not get very warm they are fine.
Your ps is rated 100 amps. so half of its' output should have no problem at 50A.
Charles
Old Sep 10, 2010, 05:09 PM
jj604 is online now
Find More Posts by jj604
ancora imparo
jj604's Avatar
Melbourne, Australia
Joined Jul 2005
1) No. The 580 will never go below 12V in operation - guarantee it. Leave it at the default 10V. It's irrelevant (but not for Pd supply batteries which is a separate setting on this charger if I read the manual correctly)
2) Set this to a bit below the current output specified from the PS on the nameplate. From memory it is 75A for 110V supply so you might want 70A. Will limit your total charger input to 70x12 = 840Watts. You could set it the same if you want. Again the 580 will protect itself in any case but it is better to have the charger manage any overload nicely than have the supply shut down. Won't happen since this supply has a lot more current capacity than your charger can draw. Note that your PS8 will never be a 1000W charger on 12V. Max is 600W with the 50A input limit.
It doesn't matter whether you use one or two connectors. The +12V and ground are all connected internally. The currents across the internal PC tracks may be a bit unbalanced if you use two separate connectors into two different packs but that has nothing to do with the total current.
John
PS Sorry, missed Charles reply before I wrote this (Charles do you never sleep!)
He is spot on and has the advantage of having a PL8 so speaks from experience.
Originally Posted by nairbg View Post
I still have questions with regard to the CellPro PowerLab8 setup information. It requests power source data in terms of lower voltage limit and upper current limit.
1. The manual suggests using 1/2 of the operating voltage (12v) for the lower voltage limit from a DC power supply. This would mean setting 6v for the DL580. Does this make sense for the DL580? (the PowerLab8 default setting is 10v)
2. The manual requests an upper current limit for charging. I am not sure what would be appropriate for the 1300W DL580, pulling from only one side (2 pairs) of the output contacts. (the PowerLab8 default setting is 25A)
Can anyone advise?
jj604 is online now Find More Posts by jj604
Old Sep 10, 2010, 05:46 PM
nairbg is offline
BrianG
Edonton, AB
Joined Jun 2009
Yes, it's 74A from the low voltage (100-125v) supply on this one.
I don't know, but it seems like you guys are missing my question...
Is it OK to pull that much from one one set of contact blades (2+/2-) on the the DL580?
Thanks!
Old Sep 10, 2010, 05:55 PM
jj604 is online now
ancora imparo
jj604's Avatar
Joined Jul 2005
Yes. See Charles comment. If it gets too hot stop.
One set of those contacts should carry the full load of your charger (50A).
John
Thanks!
Old Sep 10, 2010, 07:08 PM
Southern Pride
One of those great lines from a movie, I forget which one..
I will have plenty of time to sleep when I am dead.
FYI While testing a parallel charging/ balancing board today I pulled 40 A thrugh 24" of 14gagae supper flex, a pair of APP 45A connectors,a set of 4 mm bullets and a pair of Deans Ultras( real Dean male and fake female. All of this between the deep cycles and the balancing board. The APPs were the hottest at 145F in 94F ambient. Fake Deans 126F and the 14gage leads 113F .
Charles
Old Sep 10, 2010, 07:34 PM
Pdwight is offline
Find More Posts by Pdwight
North Alabama
Joined Feb 2005
What is Superflex ??
Pdwight is offline Find More Posts by Pdwight
Old Sep 10, 2010, 07:58 PM
Southern Pride
Wet noddle,super flex,high stan count with silicon insulation all the same. Same type wire used on ESC,LiPolys etc..
I was merely making the point that even 24" of this in only 14 gage with multi connectors did not get overly hot with 40A flowing thrugh it at 94F ambient.
Charles
Old Sep 10, 2010, 08:17 PM
Pdwight is offline
North Alabama
Joined Feb 2005
I have just gotten back into RC after 7 or 8 years off, Electric has really changed in those years. What is a good source for this type of wire ?
Dwight
Old Sep 10, 2010, 08:21 PM
Southern Pride
http://cheapbatterypacks.com/?menu=F...2A9&sid=593050
FYI Same type wire has been used in RC for at least 30 years that I am aware of and likely even longer.
Old Sep 10, 2010, 08:30 PM
Pdwight is offline
North Alabama
Joined Feb 2005
Thanks that is a good resource
Old Sep 16, 2010, 12:20 PM
die4good is offline
Find More Posts by die4good
Airborn Maniac
United States, FL, Fort Myers
Joined Jan 2009
http://www.rcgroups.com/forums/showthread.php?t=1307957
I wonder if anyone has ran across a server PS that could do 28V, 52 amp, 2000 watts like this?
All i've read is 2 12vPS = 24v
I know that it could be done with one Power supply with individual ground and wonder if anyone has come across one.
die4good is offline Find More Posts by die4good
Old Sep 16, 2010, 04:16 PM
feathermerchant is offline
Find More Posts by feathermerchant
Use the 4S Luke
feathermerchant's Avatar
USA, TX, Euless
Joined Aug 2003
If I did, I'd be all over it. They are just not used (AFAIK) in the industry now. That may change someday. See my blog. I have been using that one with my Duossince it was written. No problems. I have sold several sets to others who have done the same thing with no problems reported. It seems to be a good solution. Also inexpensive. I know others have used different supplies in series as well with good results.
RE: the link above - I'm sure those are great.
feathermerchant is offline Find More Posts by feathermerchant
Old Sep 16, 2010, 04:36 PM
Southern Pride
If I needed more than 24 volts as supplied by a couple server ps in series I would just ad a third and have 27.3 volts or perhaps 29 depending on the charge , power supplies and amps. needed and avaialble on the 3.3 and 5V outputs.
Charles
Old Sep 16, 2010, 10:36 PM
die4good is offline
Airborn Maniac
Joined Jan 2009
well, I guess that's the way to go taking the cheaper route!! LOL
Alert Need advice on high grade power supply for ISL-8 Byron Betterly Batteries and Chargers 7 Dec 07, 2003 08:31 PM
12volt, 9amp power supply for sale Paul Susbauer Aircraft - Electric - Airplanes (FS/W) 1 Dec 03, 2003 12:44 PM
12volt wallwart power supply reading 14.6 ? (help) power Batteries and Chargers 4 Sep 09, 2003 04:21 PM
Where to Get A Quality Power Supply? Joe Elston Batteries and Chargers 4 Apr 29, 2003 02:09 PM
High end charger and power supply for sale! Very new. ted616 Aircraft - Electric - Airplanes (FS/W) 6 Dec 02, 2002 11:31 PM
