http://translate.google.com/translat...26prmd%3Dimvns |
Joined Dec 2012
Thanks xandrios, I know that site
![]() They have built an excellent conversion kit, but they have no information about all those trimmers inside (but the one with the silicone dot). There are many more! What else could these be used for if not for voltage trimming and overcurrent protection? Is there a way to find out? have a nice evening |
Xandrios,
That worked! It's half as loud but still not as quiet as I was hoping. Still worth the effort of the simple mod in my opinion. I wish there was a way to make it temp controlled and have it shut off completely when not needed. It looks like it has a temp sensor but, as you know, I'm no electrical person. With the total cost of this 1100 Watt power supply project at only $50, I really shouldn't complain. Thanks again for your help! Quote:
So I was ordering several Dell AA23300 power supplies from eBay and the picture label they showed was that of a typical AA23300. The units that came in look exactly like the AA23300 but the label is different as is the number CN-0UG634. Has anyone come across this unit before and anything I should be aware of. Looks like no problem isolating the board ground to the chassie ground. While it is apart if anyone wants any additional internal pictures let me know.
Latest blog entry: My 87” 3DHS Extra 300 SHP w/DA-60
Joined Apr 2012
which psu to buy?
hi folks,
i´m looking for a quiet psu (no fan at all or a really quiet one) that is happy to deliver a cuntinous 20amps at 13V minimum. got some server psu´s here but they are all loud as hell. so do you have any idea of a quiet one? i know there are some "fanless" ones around, maybe they can do 20amps with no fan or with a big and slow one attached to it? any suggestions? thank you guys! |
See my blog.
I have some fanless supplies that deliver just short of that. 17 amps at 13.4 if the POT is turned up from 12 volt or another of the same 210 watt supply but it can do over 14 volts (13.5 turned up all the way, I forget actual max volts) and 15 amps. Rick |
Latest blog entry: mean well S-210-12 power supply
Joined Apr 2012
thanks for your reply rick but i´m in need of about 22amps at a stable 13(to 15)volts for a ham radio transceiver, thats also why it should be quiet. also i need to get it here in germany (postage from the us would hurt i think) so i thought about another server psu to get off ebay
Not really difficult. You must drill out each of the 2 screw holes in the DC end of the PC board and isolate them top and bottom with non-conductive washers. The holes are plated through the board. Instead of drilling them you could use non-conductive screws and a washer under the board.
Joined Jan 2013
So I read a lot (but not all) of this thread and a few other threads. Is the Compaq HP ESP114 Series 12V 55A Power Supply still a good choice if size isn't a concern but noise is? I would plan to put two of them in series. I saw that the output can be floated... Or are there more recently "discovered" supplies that are easier to work with (use normal power plugs, etc) that are equally quiet?
Joined Apr 2012
help
Hey guys
I was wondering if anyone could help me get these supplies running for my battery charging station. I have two I bought ,both for a HP Proliant DL580 G5 ..power supplies part numbers 440785-001 and 441830-001 HSTNS-PD11 I have converted a bunch of pc ones,but I am not at all familiar with these. Are the pinouts gonna be the same as the one xandrios posted for the g3? what do I need to do to have it fire up and stay reliable . Any info would help. I know just enough to be dangerous!. here is a pic of them John Great Thread |
| Thread Tools | |
| Alert Need advice on high grade power supply for ISL-8 | Byron Betterly | Batteries and Chargers | 7 | Dec 07, 2003 08:31 PM |
| 12volt, 9amp power supply for sale | Paul Susbauer | Aircraft - Electric - Airplanes (FS/W) | 1 | Dec 03, 2003 12:44 PM |
| 12volt wallwart power supply reading 14.6 ? (help) | power | Batteries and Chargers | 4 | Sep 09, 2003 04:21 PM |
| Where to Get A Quality Power Supply? | Joe Elston | Batteries and Chargers | 4 | Apr 29, 2003 02:09 PM |
| High end charger and power supply for sale! Very new. | ted616 | Aircraft - Electric - Airplanes (FS/W) | 6 | Dec 02, 2002 11:31 PM |
