Old Jan 30, 2013, 01:41 AM
still4given is offline
Find More Posts by still4given
Sky Pilot
still4given's Avatar
Victorville, CA
Joined Jun 2006
We'll need to know which unit you are using.
still4given is offline Find More Posts by still4given
Old Jan 30, 2013, 03:10 AM
BadBert is offline
Find More Posts by BadBert
BadBert's Avatar
Nederland, Noord-Brabant, Hoogerheide
Joined Mar 2007
3 of these: Delta Dps-350MB, Delta DPS-275DB
in a CAGE that my uncle got out of a server...
(my uncle said they should work parallel, so 75 amps max on 12v)
this is a ebay link of the cage:
http://www.ebay.de/itm/Delta-RPS-350...ht_3351wt_1139
this is de part number of the cage: A53590-003
BadBert is offline Find More Posts by BadBert
Old Jan 30, 2013, 10:05 AM
grimbeaver is offline
Find More Posts by grimbeaver
United States, MN
Joined Feb 2011
That basically converts them to an ATX power supply it looks like. Shove them in and short the green wire on the 24 pin connector to a ground (any black wire) and it will probably turn on.
grimbeaver is offline Find More Posts by grimbeaver
Old Jan 30, 2013, 12:57 PM
BadBert is offline
BadBert's Avatar
Joined Mar 2007
Thats the idea.
And ok, thanks!
Any idea which pins give me 12v then?
And what about the issue mentioned above (so.they devide the asked amps)
Old Jan 30, 2013, 01:07 PM
United States, MN
Joined Feb 2011
Any idea which pins give me 12 then?
Probably just take it from the 4 pin molex connectors like any other ATX power supply mod does.
Not a clue. These are setup for redundant purposes not load sharing so you're guess is as good as mine. You'll have to test but I'm guessing it won't like putting out more then the capacity of one supply.
Old Jan 30, 2013, 02:39 PM
BadBert is offline
BadBert's Avatar
Joined Mar 2007
Ok! Thanks so far. If anyone else has any info... please share.
My uncle told me that the cage could deliver 75amps max, that was also what they were ment for.
So ill test that! Thanks again
A am completely new to atx mods and conversions, so thanks for all the info!
Old Jan 31, 2013, 03:34 PM
Gerben is offline
Find More Posts by Gerben
Joined Dec 2004
Hi All,
Has anyone had their power supply quit on them?
Happened to me twice so far. On both cases something inside exploded with a decent bang when plugging the power supply into the mains.
Nothing visible like an exploded cap or so.
First one was a Dell DPS-600, second one a HP HSTNS-PL11 (100A).
Both used 'stand alone' at 12V. First one was here at home, second one in Romania, that may have been some dodgy mains-voltages.
One suspicion I have is that the power supplies may not like extended 'idling' times. Sometimes they are feeding a charger which is discharging a LiPo, so they hardly supply current but are switched on for quite some time (and ofcourse it's not a 'regenerative' discharge). Would a constant load of some sort help?
The other one is that maybe it;'s not good to switch them on by plugging in the mains. Would it be better to switch on by first plugging them into mains and then using a small switch on the appropriate pins?
Curious to hear about further experiences on this....
Gerben
Gerben is offline Find More Posts by Gerben
Old Jan 31, 2013, 03:49 PM
goldsworthy is offline
Find More Posts by goldsworthy
United States, AZ, Tucson
Joined Mar 2012
Originally Posted by Gerben View Post
Hi All,
Gerben
This is a interesting question! I too would like to know this. My server supply has gave me no trouble yet.
goldsworthy is offline Find More Posts by goldsworthy
Reply With Quote  (Disabled)
Old Jan 31, 2013, 09:54 PM
feathermerchant is offline
Find More Posts by feathermerchant
Use the 4S Luke
feathermerchant's Avatar
USA, TX, Euless
Joined Aug 2003
I have had a few that made a hole in the insulating paper between the main board and case. That can generate quite a bit of arcing. Then it will blow the fuse. The arcing burns up the circuit board and any surface mount devices nearby.
feathermerchant is offline Find More Posts by feathermerchant
Old Feb 01, 2013, 03:26 PM
rampman is offline
Find More Posts by rampman
Frankenstein recycled packs
rampman's Avatar
USA, AZ, Gilbert
Joined Jan 2006
I had a DPS-500 let go in my shop at 105F @ 38 amps of the 41 rated max on a 6 hour test. Failed at less than 1 hour. It was a decently loud POP.
Note to self: Either lessen ambient or amps.
Rick
rampman is offline Find More Posts by rampman
Old Feb 01, 2013, 11:24 PM
Kerbob is offline
Find More Posts by Kerbob
Kerbob's Avatar
Knoxville, TN
Joined Apr 2008
I know this is an old post, but I was hoping someone could help me with the fan noise of the AA23300 PSU. I've got two hooked into a series successfully and am charging like a boss. However, the fan noise eats my brain. I don't have much to spare. If anyone can show me either how to slow these guys down or how to control them, that would be fantastic.
The fans are SANS 40's and here is the data sheet:
http://db.sanyodenki.co.jp/product_d...1328170755.pdf
They're temp controlled, but for some reason they run at 100% all the time
Originally Posted by xandrios View Post
Dell 1850 AA23300 PSU and Astec DS550-3 voltage control modification.
The Dell 1850 AA23300 PSU(550w) and Astec DS550-3 lack the external voltage sense pins(+12V Sense and +12V Return Sense)
that are required for voltage adjustment of the main 12V output.
This easy modification will connect the internal +12V Return Sense(also called -Ve Sense or Vs-) line to external pin D3.
Output voltage is now adjustable from 12V-14.4V(OVP). Usable voltage range is 12V-14.2V.
Regulation is rock solid as output voltage will rise ever so slightly with load.
I've connected this Sense line to pin D3 because the +12V Sense Return pin is usually located at position D3 on similar PSUs.
You don't need to connect the internal Sense line to pin D3. I just did it this way for convenience.
Connect a 1k -10k pot for voltage increase with clockwise rotation. Left leg to pin C3. Center wiper to pin D3. Right leg to pin D4.(For an upright pot)
If voltage is adjusted above 14.4V then the OVP(Over Voltage Protection) will simply shut down the PSU.
P.S. To slow the fans down to a moderate level simply wire them in series and connect them to the main DC output.
If fan noise is not an issue then just leave them as they are.
Kerbob is offline Find More Posts by Kerbob
Old Feb 02, 2013, 03:47 AM
Joined Mar 2012
My server stations all have loud fan units. I just suck it up and live with the noise.
Old Feb 02, 2013, 07:43 AM
United States, MN
Joined Feb 2011
Search is a wonderful thing...
http://www.rcgroups.com/forums/showp...postcount=1592
Old Feb 02, 2013, 08:14 AM
xandrios is offline
Find More Posts by xandrios
Steven
xandrios's Avatar
United States, CT, East Hartford
Joined May 2010
There will be 4 power wires that come from the fan combo unit. Red+ and Black- from one fan. Orange+ and Grey- from the second fan.. To wire the fans in series just connect the Orange and Black wires together. Then connect the Red wire to the 12VDC output. And connect the Grey wire to DC ground.. The PDF that you included also contains this information..
xandrios is offline Find More Posts by xandrios
Old Feb 02, 2013, 08:56 AM
shadygrady is offline
Find More Posts by shadygrady
Joined Jan 2013
how to pin out astec aa23920l psu
does any one know how to pin out a astec psu power supply model astec aa23920l made by emerson for ibm ibm pn#39y7349 ibm fru pn# 39y7364 i tryed emerson an ibm both will not help me ???????
shadygrady is offline Find More Posts by shadygrady
Alert Need advice on high grade power supply for ISL-8 Byron Betterly Batteries and Chargers 7 Dec 07, 2003 08:31 PM
12volt, 9amp power supply for sale Paul Susbauer Aircraft - Electric - Airplanes (FS/W) 1 Dec 03, 2003 12:44 PM
12volt wallwart power supply reading 14.6 ? (help) power Batteries and Chargers 4 Sep 09, 2003 04:21 PM
Where to Get A Quality Power Supply? Joe Elston Batteries and Chargers 4 Apr 29, 2003 02:09 PM
High end charger and power supply for sale! Very new. ted616 Aircraft - Electric - Airplanes (FS/W) 6 Dec 02, 2002 11:31 PM
