Old Nov 02, 2012, 10:55 PM
Ronnie Mund is offline
Find More Posts by Ronnie Mund
Joined Nov 2012
Originally Posted by BrushlesHeaven View Post
DELL Z930P-00 power up mod
Ok, after few days of working on it I was able to properly power it up!!!
Big thanks to all of you guys. Special thanks goes to XANDRIOS for sending me few important remarks on what to do.
Here is the deal. The only 1 pin that needs to be connected to -12V output is pin D2
I have ON/OFF swich wired directly to the board.
That is it!!!
Works like a charm. Now I just need to slow down the fan.... And this is done now and working.
http://www.youtube.com/watch?v=Bnf7-...layer_embedded
http://www.youtube.com/watch?v=AGeBY...layer_embedded
I recently got my hands on a Dell PSU (Dell P/N 0U8947), and I'm wondering how to wire a switch directly to the board? Your videos were very helpful, thank you! But my boards a bit different and don't know where to solder. I've attached a pic of what my board looks like...
I already soldered D2 to -12, w/o a switch and I'm only getting a single green light on plug-in. I then tried wiring a switch through A1, B1, B6 and it fires up for 10secs, then orange light. If I toggle the switch it will repeat. So I'm thinking I need to have the switch directly soldered to the board?
Ronnie Mund is offline Find More Posts by Ronnie Mund
Old Nov 03, 2012, 07:23 AM
xandrios is offline
Find More Posts by xandrios
Steven
xandrios's Avatar
United States, CT, East Hartford
Joined May 2010
Hey Ronnie,
Where is your pic ??
Look for a small hole in the power supply case that lines up to where a switch should be as seen in this pic. The small internal switch may or may not be installed. It will depend on the revision number of the PSU mainboard. If it's not there then just solder in your own.
xandrios is offline Find More Posts by xandrios
Old Nov 03, 2012, 12:47 PM
Joined Nov 2012
Hi xandrios,
I actually did upload pics - maybe b/c I'm a new member they're not showing? Here's the direct links to them:
http://imageshack.us/a/img9/711/img0381dyx.jpg
http://imageshack.us/a/img812/9453/img0384lh.jpg
http://imageshack.us/a/img195/9030/img0386cg.jpg
But I don't seem to have a hole in the side of the case. I've never dealt with soldering on a printed board, so I wouldn't know where to solder to for the switch. Can you point out where I'd need to solder to?
Do you think this will solve my problem?
Many thanks in advance!
Old Nov 04, 2012, 08:28 AM
peter11833 is offline
Find More Posts by peter11833
Joined Oct 2012
Astec 23650 / Sun Fire V240 Power Supply Pinout
Hi,
have checked this thread, but didn't find anything about such a Power Supply.
I have 'recycled' this PS from the pizza box in the trash
It's a nice slim PS - would be great to find out the pin out and hope somebody here could support me. Some pics here
peter11833 is offline Find More Posts by peter11833
Old Nov 04, 2012, 10:51 AM
xandrios is offline
Steven
xandrios's Avatar
Joined May 2010
You're right. That mainboard is totally different. If the mainboard doesn't have a location for a switch then you most likely can't wire in one of your own.
You've already tried wiring a switch through A1, B1, B6.
Try also pin B4 to ground through a 500 ohm resistor.
The orange error light comes on after 10 seconds.
That usually indicates a bad tach output from the fan. Do you have any way to test this ?
What DC voltage do you get when it's running ?
Some pin mapping will help. Find all the ground pins.
Find all the 3.3VSB(3.3V standby) pins. All 3.3VSB pins will be connected together so check for DC continuity between them. A true 3.3VSB pin will not drop voltage when slightly loaded(connected to ground through a 200 ohm resistor). A false 3.3VSB pin will drop voltage when slighty loaded.
Find out which pins (if any) raise the main DC output voltage. Connect each pin(one at a time) to the +12V output through a 470 Ohm resistor. Then check for DC output voltage rise.
Also connect each pin(one at a time) to ground through a 470 Ohm resistor. Check again for voltage rise.
Sense pins raise and lower the main DC output voltage. Current share pins only raise the main DC output voltage.
The output voltage of the Current share pin will increase in proportion to the main DC output load.
Compare your results with these two pinouts:
Old Nov 04, 2012, 12:49 PM
Robo1981 is offline
Find More Posts by Robo1981
Germany, TH, Hildburghausen
Joined Jul 2012
Hello,
unfortunately the 4 MosFET's of the DPS-1570 are more expensive as the DPS-1570 itself. :-(
That's why I've bought two of the DPS-2000BB Rev: S7 power supplys. (one as reserve :-) )
I want to operate the power supply together with an car audio amplifier, is that working ?
On the DPS-1570, the OVP unfortunately often shuts down on heavy basses.
On the DPS-2000BB, is that a problem too ?
Because there is no modification to deactivate the OVP...
What kind of 1kOhm pot. is required ? How many Watts ?
The power supply needs cooling fan's, how much airflow is minimal required ?
"Maximum output current for the DPS-2000BB PSU is 164A at 12.2v.
I've personally tested up to 200A at 14.4v (2800w) output !!"
^^- How long was this test-run ?
By the way, the DPS-2000BB power supply has only 4*+ powerpins,
is any pin really designed for up to 42 (50Amps) ??
Robo1981 is offline Find More Posts by Robo1981
Old Nov 04, 2012, 01:49 PM
xandrios is offline
Steven
xandrios's Avatar
Joined May 2010
Originally Posted by Robo1981 View Post
Hello,
Each pin will indeed handle 50A. I only used 6 pins total when I tested up to 200A.
You really don't need an OVP mod for the DPS-2000BB because It will already go up to 14.6V.
I use a 1/4W 1kOhm pot and have no problems.
The DPS-2000BB should not shut down on heavy bass If you are using the same car amplifier. It will have plenty of headroom.
Set It to 14.3V and you should be all set.
The 200A test was done for 10 seconds at which point the PSU started to literally ((((vibrate)))).
Minimal airflow will depend on how hard you drive the PSU.
Old Nov 05, 2012, 06:53 PM
Joined Nov 2012
OK I tried grounding B4 with a resistor, but it didn't seem to make a difference. Unit will run for about 10 seconds with 12+V DC, then shut down with yellow light. I can toggle the switch and it will repeat. I had ordered another PSU Friday, so that should be delivered soon. I was thinking of swapping the fan to see if that will fix it? I don't have any other means of testing the tach output...Hoping to avoid that pin mapping
Thanks for all this info!!!
Old Nov 07, 2012, 10:22 PM
baronthebaron is offline
Find More Posts by baronthebaron
Joined Nov 2012
power supply pin config.
i have some dell 7000815-Y000 12v 75A power supplies. any idea how to power em up?
baronthebaron is offline Find More Posts by baronthebaron
Old Nov 07, 2012, 11:41 PM
xandrios is offline
Steven
xandrios's Avatar
Joined May 2010
That would be the Dell PowerEdge 2800 PSU.
Pinout here:
http://www.rcgroups.com/forums/showp...&postcount=513
Old Nov 14, 2012, 04:38 PM
BilboBandwidth is offline
Find More Posts by BilboBandwidth
Joined Nov 2012
Hello Gentlemen,
I've just purchased an HP 337867-501 (the same one as in the first post in the thread) and even though I've followed all the instructions about which pins to short, I still only get 6V between the two pairs of blades on the left side and then about 30mV across the blades on the right side. This is the same output that I get even if I don't have the pins shorted. Am I doing something wrong? I should note that the power supply came from a seller that claimed it was 240V only and it has the european C19 plug, although it still works when I have it hooked up to the US 120VAC input with the correct cable. Also, the green light blinks the entire time.
Thanks!
BilboBandwidth is offline Find More Posts by BilboBandwidth
Old Nov 14, 2012, 09:27 PM
stgdz is offline
Find More Posts by stgdz
Volts>amps
stgdz's Avatar
United States, MN, Buffalo
Joined Jul 2011
91 amps and close to 1600 watts for that dell 6800, yeah that'll do
stgdz is offline Find More Posts by stgdz
Old Nov 15, 2012, 01:38 AM
xandrios is offline
Steven
xandrios's Avatar
Joined May 2010
Originally Posted by BilboBandwidth View Post
Hello Gentlemen,
Thanks!
You should have no DC voltage on the main output when the turn-on pins are not shorted.
A difference in voltage between the left and right pins indicates a problem..
The blinking green light should turn solid after shorting the correct pins.
Does the label on the side of your PSU indicate that It accepts 100V-240V input.
Old Nov 15, 2012, 01:51 AM
xandrios is offline
Steven
xandrios's Avatar
Joined May 2010
double post
Old Nov 24, 2012, 06:59 AM
Dylan_M is offline
Find More Posts by Dylan_M
Joined Oct 2012
This may be a little off topic, but I was just wondering if there are any other uses for these high current PSUs besides powering RC battery chargers. Considering the price of these units, it's tempting to buy lots of them but I can't seem to justify the purchases :P
Dylan_M is offline Find More Posts by Dylan_M
Alert Need advice on high grade power supply for ISL-8 Byron Betterly Batteries and Chargers 7 Dec 07, 2003 08:31 PM
12volt, 9amp power supply for sale Paul Susbauer Aircraft - Electric - Airplanes (FS/W) 1 Dec 03, 2003 12:44 PM
12volt wallwart power supply reading 14.6 ? (help) power Batteries and Chargers 4 Sep 09, 2003 04:21 PM
Where to Get A Quality Power Supply? Joe Elston Batteries and Chargers 4 Apr 29, 2003 02:09 PM
High end charger and power supply for sale! Very new. ted616 Aircraft - Electric - Airplanes (FS/W) 6 Dec 02, 2002 11:31 PM
