Old Oct 26, 2012, 06:14 AM
xandrios is offline
Find More Posts by xandrios
Steven
xandrios's Avatar
United States, CT, East Hartford
Joined May 2010
Yo Changchung,
that PSU is the DPS-1200FB A.
The pinout to power it up is here:
http://www.rcgroups.com/forums/showp...postcount=1121
Picture courtesy of registered users zartoop and DSW
xandrios is offline Find More Posts by xandrios
Old Oct 26, 2012, 08:24 AM
Dylan_M is offline
Find More Posts by Dylan_M
Joined Oct 2012
Hey guys, just wondering if anyone with a DPS-2000BB could post the physical dimensions of the unit? Trying to determine what fan size I need to use.
Dylan_M is offline Find More Posts by Dylan_M
Old Oct 26, 2012, 09:24 AM
xandrios is offline
Steven
xandrios's Avatar
Joined May 2010
Here ya go Dylan_M
Old Oct 26, 2012, 02:07 PM
feathermerchant is offline
Find More Posts by feathermerchant
Use the 4S Luke
feathermerchant's Avatar
USA, TX, Euless
Joined Aug 2003
Does it include a fan(s)?
feathermerchant is offline Find More Posts by feathermerchant
Old Oct 26, 2012, 02:21 PM
xandrios is offline
Steven
xandrios's Avatar
Joined May 2010
Nope..
Old Oct 26, 2012, 06:20 PM
Dylan_M is offline
Joined Oct 2012
Originally Posted by xandrios View Post
Here ya go Dylan_M
Thanks man, you really are a legend on this forum. One more quick question if you don't mind, at about what wattage should I start getting concerned about cooling? Would I only need to use fans after 1000 watts for example? Or should I just have them on permanently to stay on the safe side?
Old Oct 26, 2012, 08:51 PM
Changchung is offline
Find More Posts by Changchung
Joined Oct 2012
Yo Changchung,
THANKS... You are my hero... I am just going to ebay to get mine... hahhaha
Changchung is offline Find More Posts by Changchung
Old Oct 26, 2012, 09:08 PM
TX Ham is offline
Find More Posts by TX Ham
Ham Operator, Central Texas
Joined Oct 2012
Originally Posted by TX Ham View Post
Further to #1844 -
Connecting 12K resistor from +12 to D5 increases output to 12.75V, using 4.7K does the same.
Readings earlier were due to bad connection, with 10+A load, drop is only 0.05V to 12.20V
Should have been C5 for the voltage increase.
D6 is the fan speed control.
PSU works fine, not bad for the price.
TX Ham is offline Find More Posts by TX Ham
Old Oct 26, 2012, 09:32 PM
jj604 is offline
Find More Posts by jj604
ancora imparo
jj604's Avatar
Melbourne, Australia
Joined Jul 2005
Can you do a post summarising the solution then post a link to this in the sticky thread here please?
http://www.rcgroups.com/forums/showthread.php?t=1292514
John
jj604 is offline Find More Posts by jj604
Old Oct 26, 2012, 10:38 PM
xandrios is offline
Steven
xandrios's Avatar
Joined May 2010
Thanks Dylan_M.
Have the fans on permanently. The PSU will get hot even at idle or low load without fans.
Old Oct 26, 2012, 11:05 PM
Gregor99 is offline
Find More Posts by Gregor99
Revolectrix Ambassador
Seattle
Joined Sep 2007
Delta DPS-1001AB-1 48V 700w/1000w, Delta DPS-1500AB A Full Pinout.
Connect PS on and PS Kill to ground to power up.
Do you know which pin is the current share pin (CSP)?
Gregor99 is offline Find More Posts by Gregor99
Old Oct 27, 2012, 07:42 AM
xandrios is offline
Steven
xandrios's Avatar
Joined May 2010
The 48VDC output current is balanced within +/-5% tolerance by wiring together each 48LS (pin D3) current balance signals.
700w output with 110V-120V input. 1100w or 1500w output with 220V - 240V input depending on model.
Old Oct 27, 2012, 09:49 AM
Gregor99 is offline
Seattle
Joined Sep 2007
Thanks!
Old Oct 28, 2012, 10:10 AM
xandrios is offline
Steven
xandrios's Avatar
Joined May 2010
Everyone wish me and others good luck.
Hurricane Sandy is on the way. It's expected to merge with a polar cold front to create a “hybrid vortex” and become a "Frankenstorm".
I really hope that it's not as bad as predicted.
Old Oct 28, 2012, 11:09 AM
jocanon is offline
Find More Posts by jocanon
jocanon's Avatar
United States, AZ, Phoenix
Joined Jul 2010
Good luck, I'm in Buffalo, NY so we might see some if the remnants of it. Makes for bad flying weather.
jocanon is offline Find More Posts by jocanon
Site Sponsor
Alert Need advice on high grade power supply for ISL-8 Byron Betterly Batteries and Chargers 7 Dec 07, 2003 08:31 PM
12volt, 9amp power supply for sale Paul Susbauer Aircraft - Electric - Airplanes (FS/W) 1 Dec 03, 2003 12:44 PM
12volt wallwart power supply reading 14.6 ? (help) power Batteries and Chargers 4 Sep 09, 2003 04:21 PM
Where to Get A Quality Power Supply? Joe Elston Batteries and Chargers 4 Apr 29, 2003 02:09 PM
High end charger and power supply for sale! Very new. ted616 Aircraft - Electric - Airplanes (FS/W) 6 Dec 02, 2002 11:31 PM
