Old Sep 15, 2012, 12:31 PM
acetech09 is offline
Find More Posts by acetech09
I think I'm inverted. Maybe.
acetech09's Avatar
United States, CA, Pacifica
Joined Apr 2012
Wow. That is the same supply. I'm probably going to order one.
I've replaced fans in PSUs before, and unless this case is designed not to be opened (doubt it), replacing it with some higher-end equal-CFM-but-less-noise fans shouldn't be too much of a challenge.
acetech09 is offline Find More Posts by acetech09
Old Sep 15, 2012, 12:41 PM
xandrios is offline
Find More Posts by xandrios
Steven
xandrios's Avatar
United States, CT, East Hartford
Joined May 2010
The tach pulses from the fans need to remain above 155 Hz or the PSU will not run.
You can only slow them down to a certain degree.
The proprietary fans in this 1300w PSU seem to be of very high quality. It might be hard to replace them.
xandrios is offline Find More Posts by xandrios
Old Sep 15, 2012, 12:42 PM
acetech09's Avatar
Joined Apr 2012
Fans are proprietary? ugh... Either way, I can build a little sound insulation box for it and toss it under the desk .
Old Sep 15, 2012, 12:44 PM
xandrios is offline
Steven
xandrios's Avatar
Joined May 2010
That also works...
Old Sep 15, 2012, 12:47 PM
ttabbal is offline
Find More Posts by ttabbal
ttabbal's Avatar
United States, UT, Herriman
Joined Jan 2012
Could one feed a pulse train in from something like a basic 555 circuit to keep it happy?
ttabbal is offline Find More Posts by ttabbal
Old Sep 15, 2012, 12:49 PM
xandrios is offline
Steven
xandrios's Avatar
Joined May 2010
Yup. It's already been done.
http://www.rcgroups.com/forums/showp...postcount=1071
If you want to do it on the cheap then just use an old socket 7 or 370 cpu fan to get the needed tach signal.
You can run the little fan directly off of the 12V. Then slow down the main fans as much as needed.
Old Sep 15, 2012, 12:50 PM
acetech09's Avatar
Joined Apr 2012
Welp. I'm ordering that power supply... and now gotta buy a good charger to keep up with it
Old Sep 16, 2012, 11:18 AM
xandrios is offline
Steven
xandrios's Avatar
Joined May 2010
Does anyone have any experience with this dual display DC panel meter or anything similar ? They are inexpensive and look very interesting.
They can display voltage, current, power, capacity and time. Can also be expanded for higher currents via external current shunt.
http://www.ebay.com/itm/DC5-40V-20A-...item4604b15eae
Old Sep 16, 2012, 05:21 PM
jj604 is online now
Find More Posts by jj604
ancora imparo
jj604's Avatar
Melbourne, Australia
Joined Jul 2005
Neat find.
The 50Amp version looks particularly useful. Has a decent external shunt and connectors which you could mount separately. $24 delivered from this guy.
http://www.ebay.com/itm/50A-DC8-40V-...-/300747509526
There's some good detail on it in the User Manual - you need to be flexible with the English.
I have attached it as a pdf.
This more expensive vendor shows more details.
http://www.ebay.com.au/itm/Digital-V...ht_6034wt_1165
John
jj604 is online now Find More Posts by jj604
Old Sep 16, 2012, 06:38 PM
xandrios is offline
Steven
xandrios's Avatar
Joined May 2010
Even better.
It looks like the single active component on the extension board drives the external cut off relay.
The base models seem to be very hackable. New toys are always good to find.
Old Sep 16, 2012, 07:02 PM
jj604 is online now
ancora imparo
jj604's Avatar
Joined Jul 2005
Yep. Looks like a simple single transistor switch plus a damping diode across the relay coil on the external board.
Even better.
Old Sep 16, 2012, 07:59 PM
jj604 is online now
ancora imparo
jj604's Avatar
Joined Jul 2005
Well this guy charged me $24 including shipping for the 50Amp version and had posted it within an hour of me placing the order!
http://cgi.ebay.com/ws/eBayISAPI.dll...E:L:OU:AU:3160
Let you know if it arrives OK and what it looks like.
John
Old Sep 16, 2012, 10:35 PM
xandrios is offline
Steven
xandrios's Avatar
Joined May 2010
AWESOME !!!
Old Sep 18, 2012, 12:11 PM
jocanon is offline
Find More Posts by jocanon
jocanon's Avatar
United States, AZ, Phoenix
Joined Jul 2010
I have an idea for these PSUs, but need some input first. I wanted to make a Y-connector with an in-line on/off switch for the two PSUs run in series. I searched EVERYWHERE online to find such a device that can handle the level of current needed, but I do not think it exists. I cannot even find a cost effective plastic case to put a switch on and build my own. Well, to make a long story short, I got a quote from a company that does custom plastic enclosures for things like this and they can do it for a reasonable price, but I would need to order in bulk to make it worth the money (if I bought just one it would cost about $500!). Soooo, I was wondering if you all think there would be any interest out there for such a device if I were to say order a hundred or so, or would I be throwing my money away? Note: I would fully test the power cord under full load with the dummy load that I made to make sure it can fully handle the current. I will probably use 14 gauge computer power cords for the AC power. It would be a Y-connector that doubles as an on/off switch. The on/off switch will light up to indicate when the unit is turned on. I could probably sell them for about $20 which would include everything, the on/off switch Y-connector power cord and all. I think it will be pretty slick, what do you guys all think, yes, no, maybe…?
Here is a picture of what I am thinking of…
jocanon is offline Find More Posts by jocanon
Site Sponsor
Old Sep 18, 2012, 01:48 PM
acetech09's Avatar
Joined Apr 2012
I think they make them already. They're called squids:
http://www.walmart.com/ip/16503272?a...l5=pla&veh=sem
The PSU sucks 12 amps and the one I linked blows at 15.
Alert Need advice on high grade power supply for ISL-8 Byron Betterly Batteries and Chargers 7 Dec 07, 2003 08:31 PM
12volt, 9amp power supply for sale Paul Susbauer Aircraft - Electric - Airplanes (FS/W) 1 Dec 03, 2003 12:44 PM
12volt wallwart power supply reading 14.6 ? (help) power Batteries and Chargers 4 Sep 09, 2003 04:21 PM
Where to Get A Quality Power Supply? Joe Elston Batteries and Chargers 4 Apr 29, 2003 02:09 PM
High end charger and power supply for sale! Very new. ted616 Aircraft - Electric - Airplanes (FS/W) 6 Dec 02, 2002 11:31 PM
