Old Jul 19, 2012, 02:27 AM
KeldWN is offline
Find More Posts by KeldWN
Joined Jun 2012
Could you post some pictures of your "Charging suitcases" - I need some inspiration :-)
KeldWN is offline Find More Posts by KeldWN
Old Jul 19, 2012, 11:14 AM
feathermerchant is offline
Find More Posts by feathermerchant
Use the 4S Luke
feathermerchant's Avatar
USA, TX, Euless
Joined Aug 2003
KeldWN - Look in my blog. Several good ones there. None are mine.
feathermerchant is offline Find More Posts by feathermerchant
Old Jul 23, 2012, 10:27 AM
grimbeaver is offline
Find More Posts by grimbeaver
United States, MN
Joined Feb 2011
Here's a whole thread:
http://www.rcgroups.com/forums/showthread.php?t=1493834
grimbeaver is offline Find More Posts by grimbeaver
Old Jul 23, 2012, 03:39 PM
Bubba Gump is offline
Find More Posts by Bubba Gump
F3P, Slap, IMAC, Helis
Joined Jun 2007
Originally Posted by xandrios View Post
The DPS-650QB is pin compatible with your ColdWatt 650w CWA2-0650-IT01 PSU.
For a quick voltage boost connect the 12LS tab to the 5VSdBy tab.
To adjust voltage above 12V connect the +12VRS- tab to the 5VSdBy tab through a 5k or 10k potentiometer.
Let us know how high you can adjust the voltage.
Were does the 3rd line on the pot go to. Cause on a pot there's 3 connections. I picked up 2 10k pots but there's 3 connections on it were does the third go to.
Bubba Gump is offline Find More Posts by Bubba Gump
Old Jul 23, 2012, 07:02 PM
xandrios is offline
Find More Posts by xandrios
Steven
xandrios's Avatar
United States, CT, East Hartford
Joined May 2010
Hey Bubba Gump,
Connect the third pot line to ground. The pot wiper has to go to the +12VRS- tab. Connect the other pot line to the 5VSdBy tab.
xandrios is offline Find More Posts by xandrios
Old Jul 23, 2012, 07:39 PM
Joined Jun 2007
Hey Bubba Gump,
Thanks man
Old Jul 28, 2012, 10:50 AM
telfel is offline
Find More Posts by telfel
United Kingdom, Scottish Borders
Joined Jan 2012
HP Blade System BLC7000 C7000 parts numbers: 488603-001 500242-001
Hi
does anyone have information on HP Blade System BLC7000 C7000
I would like to use 2 in series for 24 volt motors
regards Terry
telfel is offline Find More Posts by telfel
Old Jul 29, 2012, 01:41 PM
BrushlesHeaven is offline
Find More Posts by BrushlesHeaven
Lipo Power
BrushlesHeaven's Avatar
Joined May 2009
DELL Z930P or DELL A930P mod
DELL Z930P-00 power up mod
Ok, after few days of working on it I was able to properly power it up!!!
Big thanks to all of you guys. Special thanks goes to XANDRIOS for sending me few important remarks on what to do.
Here is the deal. The only 1 pin that needs to be connected to -12V output is pin D2
I have ON/OFF swich wired directly to the board.
That is it!!!
Works like a charm. Now I just need to slow down the fan.... And this is done now and working.
http://www.youtube.com/watch?v=Bnf7-...layer_embedded
Z Dell Z930P-00 working fine (2 min 27 sec)
BrushlesHeaven is offline Find More Posts by BrushlesHeaven
Old Aug 03, 2012, 08:29 AM
Canucksparks is offline
Find More Posts by Canucksparks
Joined Aug 2012
09L4299 IBM Power Supply
Help !!
I have an 'nos' 09L4299 IBM Power Supply - originally used in an IBM 7133-D40 (among others), Could not find any information other than the 7133-D40 manual - which is pretty much useless for our purpose .
It has a 9-Pin D connector in the front - supposedly for remote power control. From the drive manual I reckon only 4 pins are used in the 9-Pin D, because the other end of that link cable, I suppose, has a 4-Pin mini-Din.
The Delta p/n is: D0009245/01
Sparks
Canucksparks is offline Find More Posts by Canucksparks
Old Aug 03, 2012, 02:50 PM
xandrios is offline
Steven
xandrios's Avatar
Joined May 2010
Hey Canucksparks.
The turn on pins may be on the back in the center pin matrix..
PSUs used in IBM systems usually have a single turn on line.
Exclude the ground, 5vsb, 3vsb and pins that show no connection to ground.
Then try connecting the remaining pins to ground/each other through a 500 ohm resistor one at a time.
There isn't much info available for your PSU.
Old Aug 04, 2012, 10:04 AM
mige0 is offline
Find More Posts by mige0
Joined Jun 2012
Connect PS On and PS Kill to ground to power up.
If you get an orange light and no +12v power then go to this post for instructions.
http://www.rcgroups.com/forums/showp...&postcount=686
These are solder points to disable the Over Voltage Protection (OVP) on the Delta DPS-700EB PS.
Just solder a short wire across the two components highlighted in the picture.
They reside under the white cover on the rear side of the DC-1749 daughterboard.
Be sure to solder quickly as these are small components.
Voltage can be controlled externally by using a 1k or 5k potentiometer
between pin #63 (12VS) and ground.
Maximum voltage will depend on the individual PS.
It will be somewhere from 14.8v to 15.2v.
I suggest staying below 15.0v to keep everything within spec.
You may also set the internal voltage control trim potentiometer (at bottom of daughterboard) to maximum(counterclockwise) after modification is made.
I've tested this with my PS at 15.0v with a 65A load where OCP kicks in.
Over Current Protection (OCP) circuit still works with this mod.
This is just one method to disable the OVP. I opted not to remove any components.
And as always do this mod at your own risk.
Have here a DSP-750EB A witch should be quite similar to the DSP-700EB. Unfortunately I'm not able to get past 13.5V but need past 14V.
The daughter board is labeled DC-2173 (instead of DC-1749 for the DSP-700) and has different layout. So the modification on the daughterboard shown above is not possible.
Anyone could help please ?
mige0 is offline Find More Posts by mige0
Old Aug 04, 2012, 01:17 PM
Joined Aug 2012
Thank you Xandrios.
If I exclude gnd, 5vsb, 3vsb and pins that show no connection to gnd, will there be any other pins left that are not connected to one of the above ?
And, will I be able to see the 5V and 3V on the pins without the unit starting-up ?
I have returned it to the surplus dealer . Will get it back and give it a try, though.
Thanks again for your prompt response.
Old Aug 04, 2012, 02:10 PM
xandrios is offline
Steven
xandrios's Avatar
Joined May 2010
Hey Canucksparks.
The 5vsb and 3vsb pins will show voltage even without the PSU starting-up. These standby(sb) voltages will usually be spread across multiple pins. Also, signal ground is usually spread across multiple pins. Pins that show no connection to ground are just left as spare pins and don't connect to anything.
The pins that are required for PS turn-on will be within the remaining group.
Old Aug 04, 2012, 03:04 PM
xandrios is offline
Steven
xandrios's Avatar
Joined May 2010
Hello mige0.
For the DPS-700EB mod, I just shorted the corner non-inverting input of the LM339 to ground. The DPS-750EB has a similar setup. Just look for the same smd diode. It will connect to the same pin. Shorting this pin to ground with a 1k resistor should allow you to increase the voltage to around 14.8v.
Old Aug 05, 2012, 12:48 AM
Joined Jun 2007
Here they are up and running in series and was able to float the grounds on them. Did the pot mod and had the single one up to 13v and a 30 amp load on it no problem. Here is a pic of a 40 amp load on them, the second pics what I'm planning on setting up with them a 2600watt setup so I can run a pl8 and pl6 maxed out all day.
Alert Need advice on high grade power supply for ISL-8 Byron Betterly Batteries and Chargers 7 Dec 07, 2003 08:31 PM
12volt, 9amp power supply for sale Paul Susbauer Aircraft - Electric - Airplanes (FS/W) 1 Dec 03, 2003 12:44 PM
12volt wallwart power supply reading 14.6 ? (help) power Batteries and Chargers 4 Sep 09, 2003 04:21 PM
Where to Get A Quality Power Supply? Joe Elston Batteries and Chargers 4 Apr 29, 2003 02:09 PM
High end charger and power supply for sale! Very new. ted616 Aircraft - Electric - Airplanes (FS/W) 6 Dec 02, 2002 11:31 PM
