Old Jun 26, 2010, 07:55 PM
jj604 is online now
Find More Posts by jj604
ancora imparo
jj604's Avatar
Melbourne, Australia
Joined Jul 2005
True, these PS are all well protected and will shut down if overloaded or shorted, and the regulators protect the logic pins.... but.
They are designed to provide up to 100A @12V in some cases. Put that through a bit of thin wire in your fingers by mistake if you happened to touch a working power out and it will do an excellent exploding fuse imitation. Ouch.
Pretty unlikely I admit since you would have to get it working and simultaneously touch a power out - but it could happen.
Originally Posted by linw View Post
The circ diagram for mine shows the -12V, -5V and +5 (stdby) being fed from LM337 (neg) and LM317 (pos) regulators which would make them overload/short safe.
jj604 is online now Find More Posts by jj604
Old Jun 28, 2010, 12:22 AM
linw is offline
Find More Posts by linw
Wellington, NZ
Joined Aug 2006
Agree, John. I was a bit slack with putting up this info. I just thought it would be useful knowledge for someone who had the PS4060. But these folk could look at the circ diagrams themselves!
My PSU is now in service waiting for me to need some big amps!
linw is offline Find More Posts by linw
Old Jul 04, 2010, 10:42 AM
tbirdulm is offline
Find More Posts by tbirdulm
Joined Jun 2010
Thanks to all the guys here, helped me made my 200A / 13V Power Supply!!
tbirdulm is offline Find More Posts by tbirdulm
Old Jul 05, 2010, 07:53 AM
flarssen is online now
Find More Posts by flarssen
Son, Norway
Joined Sep 2004
Originally Posted by Xargon321 View Post
Try plugging the pins
x . . . . .
. . . . . x
x . . . . .
and it should turn on i have a dell and that the ones i had to plug together to get to turn on and provide power
I have a supply for Dell PowerEdge 2850 (12V 57A max) and after reinventing the wheel, I saw this post . Grounding #19 fires up the 3.3V part, row 3 (-) and row 4 (+), only. Also gives some voltage on #18 and when this one is grounded, 12V output is turned on. I only get 11.9V though, both with a light load and noload.
Wish pinout was available. Maybe voltage can be adjusted via some of them?
Edit:
It happily delivered 48A to my charger and voltage was stable.
Part# Dell 7000814-0000
Connect both X's to ground (G):
G . - + . .
G . - + . X
X . - + . .
Fred
flarssen is online now Find More Posts by flarssen
Old Jul 06, 2010, 10:26 PM
linw is offline
Wellington, NZ
Joined Aug 2006
Congrats, guys.
tbird, do you think 200A will be enough??!!! Any one for arc welding?
Now Fred with 57A. My 25A sounds downright puny. Anyway, it's enough for my uses for now and the foreseeable future.
Old Jul 13, 2010, 05:27 AM
tbirdulm is offline
Joined Jun 2010
Congrats, guys.
200A are just enough to power my car hifi equipment when i'm at a carhifi-meeting
Old Jul 13, 2010, 04:10 PM
strimarc is offline
Find More Posts by strimarc
Joined Jun 2010
Any one wanting to use the HP DSP-600PB / P/N 321632-001 575W 12.15V 47amp supplies, If you get the P/N 321633-001 board for it, you will get the connectors needed instead of soldering to it.. I found them for $12 or so... http://www.amazon.com/Compaq-Convert.../dp/B001PPQXBY
strimarc is offline Find More Posts by strimarc
Old Jul 13, 2010, 10:38 PM
linw is offline
Wellington, NZ
Joined Aug 2006
Originally Posted by everydayflyer View Post
Post would be clearer / have more meaning if you stated that .....
pins # ? and ? are on one side of a SPST (single pole,single throw) switch and the enable pin (# ?) is on the other side.
Al mine start and run fine with control contacts wired solid(allways connected together) so that is my set up.
I am looking at 3 x HP 511777-001 which look to be DL360 G6 460W PSU's. Are these the same as the ones in the quote?
Which contacts need to be connected to the short one?
Old Jul 18, 2010, 03:29 AM
bob4432 is offline
Find More Posts by bob4432
bob4432's Avatar
United States, AZ, Phoenix
Joined May 2010
i would like to use one of these to act as the power supply for a quadcopter i am in the process of building. i am thinking my quad, being that i will be just using this to set it up, test it out, trim it inside will pull less than 50A burst and probably hover around 14A or so. for these types of A what would the recommended ga wire be as i would like 20-25' of length if it isn't too large of ga. i will be using the xt60 connectors and as described spread the load across all the copper on the back.
also, just to verify, do i need any additional load or after it is started, it will be g2g?
last, what type of power cord do i need for one of these and do i need to get it at a specialty store as i read it wasn't a normal socket.
i understand that my use is about 1/2 give or take max of what this can put out, but i would like to have the headroom, and also from my readings, this seems like a very easy psu to modify to work for my needs.
it is late, so i am just verifying i didn't miss anything...
thanks in advance,
bob
bob4432 is offline Find More Posts by bob4432
Old Jul 18, 2010, 07:41 AM
jj604 is online now
ancora imparo
jj604's Avatar
Joined Jul 2005
By "one of these" do you meant the original 1300 Watt HP supplies that started this thread? I ask since quite a few others have been discussed.
If so the answer is this supply will cope fine with the loads you propose and it needs no other modification. It will supply a constant 12.3V approx up to 50A no problem. The power cord is the high current variant of the "standard" IEC plug used on just about all computers. It has a different shape and pin configuration and can be hard to find unless you have a friend who works in the IT industry and can liberate one. You can buy them from the big suppliers but they tend to be a bit expensive. It is technically an IEC C19 16Amp plug - the ordinary ones are C13 10Amp. More info than you need to know about the IEC range of connectors here http://en.wikipedia.org/wiki/IEC_connector.
Sometimes these surplus supplies will come with them - mostly not. Simplest solution is just to solder the mains wires of an appliance cord to the three pins, suitably insulated with heat shrink of course! You will not be exceeding the current rating of ordinary appliance wiring.
On the connecting wire to the quadcopter - wire is wire, it's just a resistance. How much voltage drop can you tolerate between the supply and the input to the quadcopter? At 50 A you can then work out the resistance you can afford. There are tables that will give you the resistance per foot of any gauge wire.
My preferred alternative is the suck it and see method. Try some cheap twin flex and see what voltage you get at the copter. Long as the wire doesn't get too warm for comfort it doesn't matter to the supply. It will just keep pumping out 12.3V.
Hope this helps.
John
thanks in advance,
bob
Old Jul 18, 2010, 05:18 PM
everydayflyer is offline
Southern Pride
everydayflyer's Avatar
Haralson County GA. USA
Long power lreads as an input to a ESC is asking for troubles.
http://www.rcgroups.com/forums/showp...2&postcount=32
Charles
Old Jul 18, 2010, 08:03 PM
jj604 is online now
ancora imparo
jj604's Avatar
Joined Jul 2005
Charles, good advice. Wire isn't just wire of course but I wasn't aware the inductance would be such an issue in this application. Always wondered about the short lead recommendation and that now makes sense.
Wonder if a small 10cell NiMh in the quadcopter to act as hefty drain to dump any spikes would work? Shouldn't have any other effect on the ESCand control circuit I would think. Just speculation.
John
Charles
Old Jul 18, 2010, 08:31 PM
Southern Pride
Bob explains the ratio in post here
http://www.rcgroups.com/forums/showp...6&postcount=38
Caps cure the problem but I will leave it to the experts to calculate what value would be required.
Charles
Old Jul 18, 2010, 09:00 PM
bob4432 is offline
bob4432's Avatar
Joined May 2010
thanks for the that bit of information charles. i will contact astrobob and ask for his assistance w/ this matter.
Old Jul 18, 2010, 11:10 PM
linw is offline
Wellington, NZ
Joined Aug 2006
Interesting and potentially valuable info Charles/Astrobob. Thanks.
Alert Need advice on high grade power supply for ISL-8 Byron Betterly Batteries and Chargers 7 Dec 07, 2003 09:31 PM
12volt, 9amp power supply for sale Paul Susbauer Aircraft - Electric - Airplanes (FS/W) 1 Dec 03, 2003 01:44 PM
12volt wallwart power supply reading 14.6 ? (help) power Batteries and Chargers 4 Sep 09, 2003 05:21 PM
Where to Get A Quality Power Supply? Joe Elston Batteries and Chargers 4 Apr 29, 2003 03:09 PM
High end charger and power supply for sale! Very new. ted616 Aircraft - Electric - Airplanes (FS/W) 6 Dec 03, 2002 12:31 AM
