Old Jul 03, 2012, 01:26 PM
Steven
xandrios's Avatar
United States, CT, East Hartford
Joined May 2010
I just thought that you were taking the safer route. The way you did it makes it easy to run them in series but also makes it more dangerous if a problem should occur with the PSUs. If you take the proper precautions then you should have no problems.
xandrios is offline Find More Posts by xandrios
Old Jul 06, 2012, 06:47 AM
Steven
xandrios's Avatar
Joined May 2010
Dell 1850 AA23300 PSU and Astec DS550-3 voltage control modification.
The Dell 1850 AA23300 PSU(550w) and Astec DS550-3 lack the external voltage sense pins(+12V Sense and +12V Return Sense)
that are required for voltage adjustment of the main 12V output.
This easy modification will connect the internal +12V Return Sense(also called -Ve Sense or Vs-) line to external pin D3.
Output voltage is now adjustable from 12V-14.4V(OVP). Usable voltage range is 12V-14.2V.
Regulation is rock solid as output voltage will rise ever so slightly with load.
I've connected this Sense line to pin D3 because the +12V Sense Return pin is usually located at position D3 on similar PSUs.
You don't need to connect the internal Sense line to pin D3. I just did it this way for convenience.
Connect a 1k -10k pot for voltage increase with clockwise rotation. Left leg to pin C3. Center wiper to pin D3. Right leg to pin D4.(For an upright pot)
If voltage is adjusted above 14.4V then the OVP(Over Voltage Protection) will simply shut down the PSU.
P.S. To slow the fans down to a moderate level simply wire them in series and connect them to the main DC output.
There will be 4 power wires that come from the fan combo unit. Red+ and Black- from one fan. Orange+ and Grey- from the second fan.. To wire the fans in series just connect the Orange and Black wires together. Then connect the Red wire to the 12VDC output. And connect the Grey wire to DC ground..
If fan noise is not an issue then just leave them as they are.
Old Jul 06, 2012, 12:51 PM
Use the 4S Luke
feathermerchant's Avatar
USA, TX, Euless
Joined Aug 2003
xandrios - I'm curious as to why a 0-3.3V signal to the 12V sense works. It seems like it would require a 12V signal.
feathermerchant is offline Find More Posts by feathermerchant
Old Jul 06, 2012, 01:48 PM
Steven
xandrios's Avatar
Joined May 2010
Hello feathermerchant.
You're probably thinking of the +12V Sense line.
A PSU has two sense line.
I used the +12V Return Sense(also called -Ve Sense or Vs-) line that is connected to Ground by default.
Connecting this Sense line to ground yields a base voltage of +12V.
Any change in voltage to the +12V Return Sense will cause the main DC output voltage to change by the same amount.
Therefore:
-1V to pin D3 = 11V
0v to pin D3 = no change(12V)
+1V to pin D3 = 13V out
+2V to pin D3 = 14V out
+2.4V to pin D3 = 14.4V out
+3.3V to pin D3 = 15.3V and will cause the PSU to go into OVP.
Old Jul 06, 2012, 04:02 PM
KK4NZS
Nelapaty's Avatar
Virginia
Joined Sep 2006
Xandrios, thankyou thats just fantastic
Nelapaty is offline Find More Posts by Nelapaty
Old Jul 06, 2012, 04:11 PM
Telford,Shropshire,England
Joined Jan 2003
Would you be able to use this modification if you have two psu's connected in series? ( I have two dell poweredge 7000814-0000 they only have a output of 11.9v each)
LiftOff is offline Find More Posts by LiftOff
Old Jul 06, 2012, 04:18 PM
Steven
xandrios's Avatar
Joined May 2010
Hey LiftOff.
Yeah. It shouldn't be a problem. All you have to do is find an internal voltage sense line and tap into it.
Old Jul 09, 2012, 04:09 AM
Joined Jul 2012
I got 2 HP dps-1200 power supply, I want to use Current Share function, which pin I have to connect together?
bg1dcg is offline Find More Posts by bg1dcg
Old Jul 09, 2012, 07:56 PM
Steven
xandrios's Avatar
Joined May 2010
Hello bg1dcg.
Your best bet would be to send DSW a private message. He has some good experience with this PSU.
http://www.rcgroups.com/forums/showp...postcount=1121
Old Jul 09, 2012, 10:38 PM
Joined Jul 2012
Many thanks Xandrios:
I want to find the pin for Current Share, Any advice will be highly appreciate.
Old Jul 10, 2012, 11:22 AM
Steven
xandrios's Avatar
Joined May 2010
Hey bg1dcg.
You can find the current share for yourself if you already have your PSU up and running.
Old Jul 10, 2012, 11:30 AM
Lipo Power
BrushlesHeaven's Avatar
Joined May 2009
Hi Guys
Sorry to squeez in here but would you know or someone that may know the pinout of KX823 dell power supply? I have one and would like to use it with my chargers....
Robert
BrushlesHeaven is offline Find More Posts by BrushlesHeaven
Old Jul 10, 2012, 11:47 AM
Steven
xandrios's Avatar
Joined May 2010
Hello BrushlesHeaven
pete236 was able to get his Dell A930P-00 (same PSU as KX823) power supply to run for a short time by connecting pins A1 and B6 to ground.
http://www.rcgroups.com/forums/showp...postcount=1018
http://www.rcgroups.com/forums/showp...postcount=1021
http://www.rcgroups.com/forums/showp...postcount=1023
You might want to PM him to see if he was ever able to get it to run properly.
If a no start then try pins A1 and A6 to ground through a 500Ω resistor.
If a no start then try pins A1 and B4 to ground through a 500Ω resistor.
Old Jul 11, 2012, 02:56 AM
Joined May 2012
Hi guys, I have a power supply Supermicro PWS-721P-1R for inclusion in the network switch is turned on and turned the block, at first loud fan starts and then slowly turns, there are five on duty, after the closure of PON on the ground floor on the second unit starts - the fan starts to spin rapidly and there + 12V at the output. And then it all stops that tell me?
http://s017.radikal.ru/i422/1207/73/f674b4c52097t.jpg
http://s019.radikal.ru/i603/1207/6b/683b78ee6882t.jpg
http://i052.radikal.ru/1207/82/a299a48b57f3t.jpg
http://www.rom.by/files/bpln.GIF
mastermakc is offline Find More Posts by mastermakc
Old Jul 11, 2012, 06:45 AM
Joined Mar 2012
hello all again
any body are infos for this PSU ?
for running for 12V for my hobby Radio Amateur
many thanks
laurent on2vhf from Belgium
Originally Posted by on2vhf View Post
hi all i am 2 PSU
ESP 117
and pse for help for running 12V
regards
laurent on2vhf
on2vhf is offline Find More Posts by on2vhf
Alert Need advice on high grade power supply for ISL-8 Byron Betterly Batteries and Chargers 7 Dec 07, 2003 08:31 PM
12volt, 9amp power supply for sale Paul Susbauer Aircraft - Electric - Airplanes (FS/W) 1 Dec 03, 2003 12:44 PM
12volt wallwart power supply reading 14.6 ? (help) power Batteries and Chargers 4 Sep 09, 2003 04:21 PM
Where to Get A Quality Power Supply? Joe Elston Batteries and Chargers 4 Apr 29, 2003 02:09 PM
High end charger and power supply for sale! Very new. ted616 Aircraft - Electric - Airplanes (FS/W) 6 Dec 02, 2002 11:31 PM
