Old Jun 29, 2012, 06:31 PM
R.Gareau is offline
Find More Posts by R.Gareau
Assistant Pitman's Helper
R.Gareau's Avatar
Laval, Quebec, Canada
Joined Jul 2009
Hi Steven,
I get 5V on D3 and D4 nothing on C3, and you were right B3 and C4 are shorter
R.Gareau is offline Find More Posts by R.Gareau
Old Jun 29, 2012, 06:44 PM
xandrios is offline
Find More Posts by xandrios
Steven
xandrios's Avatar
United States, CT, East Hartford
Joined May 2010
I've seen a short A0 pin before.
It looks like we may have it. So now you need to connect pin B3 and A1 to P3 and see if it starts up.
Use a 500 ohm resistor to connect pin B3 to P3 and then use a second 500 ohm resistor to connect pin A1 to P3 to be safe.
The resistors don't have to be exact. A 750 ohm should also work.
Hope we got it.
xandrios is offline Find More Posts by xandrios
Old Jun 29, 2012, 09:47 PM
R.Gareau is offline
R.Gareau's Avatar
Joined Jul 2009
First try did not work, but now I have to finish packing for the weekend (going to a funfly) I will try again on monday.
Thank for your help
Old Jun 30, 2012, 10:18 PM
satgod is offline
Find More Posts by satgod
satgod's Avatar
United States, KY, Hardin
Joined Jun 2011
well it seems our need for good cheap supplies is running the price of the jd200 up
serversupply.com has raised their price to 75.00 almost 4x as much as it was
now we need to find a good cheap replacement for this supply
its not going to be easy this supply is very easy to mod and puts out good clean power
satgod is offline Find More Posts by satgod
Old Jul 01, 2012, 08:36 AM
xandrios is offline
Steven
xandrios's Avatar
Joined May 2010
Ebay still has some for like $45.
At one time serversupply.com was selling the KD175 for $12 with free shipping. It sells for around $80 now.
Old Jul 01, 2012, 09:19 AM
satgod is offline
satgod's Avatar
Joined Jun 2011
yea, we drove the price up buying them
they figured they could get more so they are
I was buying jd200's for 20.00 each with free shipping and I always bought 3-6 units at a time
Old Jul 01, 2012, 09:41 AM
xandrios is offline
Steven
xandrios's Avatar
Joined May 2010
They shall be called ServerSupplyandDemand.com from now on.
Old Jul 02, 2012, 12:34 PM
R.Gareau is offline
R.Gareau's Avatar
Joined Jul 2009
I still have not been able to start the DPS 660, here are all the readings if this tell you guys anything
A1-0V A2-5,86V A3-.03V A4- 0V
B1-0 V B2-0V B3-.06V B4-.64V
C1-0V C2-0V C3-0V C4-5V
D1-0V D2-0V D3-5V D4-5V
B3 and C4 are shorter pins
Help please!
Old Jul 02, 2012, 02:29 PM
xandrios is offline
Steven
xandrios's Avatar
Joined May 2010
Pins A1 to D1 are ground. B3 wouldn't be Ps Kill because the voltage is to low. C4 looks to be the PS Kill pin because it is held high to 5v. Did you also do an impedance test for the pin matrix?(resistance values for each pin in matrix to ground)
Try connecting each of the 5v and greater pins to ground through a 500 ohm resistor to see which ones are not 5vsb. The pins that are not 5vsb will drop their voltage when you connect them to ground through the resistor.
Or just try connecting pins A2, A3, B3, B4 and C4 to ground with each through a 500 ohm(or about) resistor.
Old Jul 02, 2012, 07:10 PM
Bubba Gump is offline
Find More Posts by Bubba Gump
F3P, Slap, IMAC, Helis
Joined Jun 2007
Anybody been able to convert this yet. There pretty small and light. Was given one of these from a old server and I can get another one. Puts out some really good power from what it looks like.
Bubba Gump is offline Find More Posts by Bubba Gump
Old Jul 02, 2012, 09:43 PM
R.Gareau is offline
R.Gareau's Avatar
Joined Jul 2009
No 12V out of the DPS660, I am tired and just about ready to hit the thing with a sledge hammer.
Old Jul 02, 2012, 11:41 PM
xandrios is offline
Steven
xandrios's Avatar
Joined May 2010
Here ya go Bubba Gump for your ColdWatt 650w CWA2-0650-IT01 PSU.
http://www.rcgroups.com/forums/showp...&postcount=679
Old Jul 03, 2012, 10:35 AM
Joined Jun 2007
ColdWatt 650w CWA2-0650-IT01 and Intel SR1550 PS Full Pinout.
Connect PS On and PS Kill to ground to power up.
Cool thanks. I should be able to run these in series right so long as I drop a ground. I'm currently running some dl580s the 1200 watt and there starting to act up was using a non inverter genny to run them which is bad. So is there a issue running these in series the coldwatt ones
Old Jul 03, 2012, 11:36 AM
xandrios is offline
Steven
xandrios's Avatar
Joined May 2010
There should be no problem running them in series once you decouple the DC ground from the case.
Old Jul 03, 2012, 12:08 PM
Joined Jun 2007
What you mean decouple the ground on my dl580s I just dropped a ground from one of the powersupplies on the power cable side.
Alert Need advice on high grade power supply for ISL-8 Byron Betterly Batteries and Chargers 7 Dec 07, 2003 09:31 PM
12volt, 9amp power supply for sale Paul Susbauer Aircraft - Electric - Airplanes (FS/W) 1 Dec 03, 2003 01:44 PM
12volt wallwart power supply reading 14.6 ? (help) power Batteries and Chargers 4 Sep 09, 2003 05:21 PM
Where to Get A Quality Power Supply? Joe Elston Batteries and Chargers 4 Apr 29, 2003 03:09 PM
High end charger and power supply for sale! Very new. ted616 Aircraft - Electric - Airplanes (FS/W) 6 Dec 03, 2002 12:31 AM
