Old Jun 26, 2012, 11:02 AM
cslim is offline
Find More Posts by cslim
Joined Jan 2012
Increasing voltage of DPS-835AB
Xandrios suggested grounding pin 17 to ground. Someone use a 1.2K resistor. This increases the voltage from 12.1 to 13.1 but regulation was extremely poor. Load with 2 amps, and the voltage drops to 11.99.
Without resistor, voltage is 12.1; load with 2 amps, the voltage drops to 12 volts.
Any way to increase to 13.8volts easily?
July 7, 2012
Reread Xandrios post again. He mentioned close connections to the motherboard.
Removed all molex signal and power connectors. Reconnect 1.2k ohms from pin 17 to ground. Got 13.14 volts.
Now tested with 1A, 2A, 5A and 10Amps load, perfect regulation. Voltage remained at 13.14.
Some power is reduced for ham radio but not too bad compared to 12.14.
Thanks to Xandrios and all.
cslim
cslim is offline Find More Posts by cslim
Old Jun 26, 2012, 07:14 PM
ON3RT is offline
Find More Posts by ON3RT
Joined Jun 2012
Hi Randy,
I just ordered a used DELL DPS-500CB A for use with my 100W HF transceiver.
Can you kindly guide me around the various mods that you were able to do on this unit ?
My aim is to use it as a back-up 12v DC PSU to power my 100W HF transceivers.
Could you please tell me the procedure to increase the voltage to 13.8v DC ? Ideally, I'd like to arrive at 14v DC by tweeking/moding the unit.
Also, what is the RFI suppression technique that you are using to avoid EMI noise ? Just a toroidal choke or something more elaborate ?
My e-mail ID at GMAIL.COM is "on3rt.ravi"
Thanks in advance ... best 73S !
Ravi ON8RT
ON3RT is offline Find More Posts by ON3RT
Old Jun 26, 2012, 10:58 PM
darthmaull is offline
Find More Posts by darthmaull
Joined Jun 2012
Hi all, Im new on the forum, my excuses if Im posting at the incorrect place, I am looking for info about how to power up my DPS-460 EB.
Tks in adv!
David
darthmaull is offline Find More Posts by darthmaull
Old Jun 27, 2012, 07:44 AM
xandrios is offline
Find More Posts by xandrios
Steven
xandrios's Avatar
United States, CT, East Hartford
Joined May 2010
Hey darthmaull
Can you shoot us a pic of the pins on your DPS-460 EB.
xandrios is offline Find More Posts by xandrios
Old Jun 28, 2012, 06:00 AM
xandrios is offline
Steven
xandrios's Avatar
Joined May 2010
Hey darthmaull.
Jointer may have already found the pinout for your DPS-460EB..
http://www.rcgroups.com/forums/showp...26&postcount=1
Old Jun 28, 2012, 02:50 PM
Joined Jun 2012
Hi, thanks for your replies..here are some shoots of my DPS-460EB
Old Jun 28, 2012, 03:38 PM
stocksy is offline
Find More Posts by stocksy
Joined Jun 2012
Originally Posted by racerxky View Post
Yea. I looked in the other thread and there is info but not for the supplies specifically in this thread. And xandrios is right, these are somewhat intractable. 3 of the holes in the PCB that you put screws through connect to the DC ground. Luckily, the standoffs in the case can be removed and the case does a good job of holding the PCB in place.
This is what I did:
Attachment 4012510
Use a hammer and a block of wood with a hole in it to knock these 3 standoffs out of the case. You'll probably have to beat the case back into shape a bit.
Attachment 4012511
Install a piece of hard thin plastic as a safety shield and to give the rubber feet something to stand on.
Attachment 4012512
Put 2 rubber feet on the bottom of the PCB. I had these from another project. The height is critical, too much and the case wont go back together, too little and the PCB can flop around.
My meter says there is no path between any of the 12v contacts and the case. There is connectivity between the power plug ground and the case. I think that means the DC ground has been successfully floated. I believe that's a first for the 580 PSU.
hi
are these the same units HP Proliant DL580 G3 HSTNS-PA01 Power Supply Unit 406421-001 337867-501 if so did your method work on removing the dc ground buy just isolating the 3 post?
thanks
kyle
stocksy is offline Find More Posts by stocksy
Old Jun 28, 2012, 04:51 PM
xandrios is offline
Steven
xandrios's Avatar
Joined May 2010
Hey darthmaull.
Your DPS-460EB looks very similar to these:
http://www.rcgroups.com/forums/showp...&postcount=167
and here:
http://www.rcgroups.com/forums/showp...&postcount=169
It looks like you just need to connect pin 1 to pin 4 topside.
Use a 500 ohm resistor if in doubt.
Old Jun 28, 2012, 06:10 PM
jj604 is online now
Find More Posts by jj604
ancora imparo
jj604's Avatar
Melbourne, Australia
Joined Jul 2005
Don't forget guys. If you find a method that works for a supply that is not already on the sticky thread, be sure to post a link to the info in that thread.
http://www.rcgroups.com/forums/showthread.php?t=1292514
John
jj604 is online now Find More Posts by jj604
Old Jun 28, 2012, 06:40 PM
Joined Jun 2012
Hi Xandrios, You really make my day ! :-) I tied together top pins 1 & 4 and green light went up...12.33 VDC available now
Tks!!!
Dathmaull
Old Jun 29, 2012, 11:28 AM
R.Gareau is offline
Find More Posts by R.Gareau
Assistant Pitman's Helper
R.Gareau's Avatar
Laval, Quebec, Canada
Joined Jul 2009
I was wandering if anybody would have the pin out information on these power supplies
Delta Electronics DPS-660AB
Thanking you all in advance
R.Gareau is offline Find More Posts by R.Gareau
Old Jun 29, 2012, 12:16 PM
xandrios is offline
Steven
xandrios's Avatar
Joined May 2010
Hey R.Gareau.
I can't see the rest of your PSU from the pics.
Does your DPS-660AB look similar to the DPS-600RB??
If so then check to see if any of the pins match up even before you try to power it up.
Plug your DPS-660AB into the wall and check to see if you get 5V from pin C3 and pin D3 as shown below.
You may get a blinking green light when AC input is present.
Pin B3 may be shorter than the rest.
Old Jun 29, 2012, 12:56 PM
R.Gareau is offline
R.Gareau's Avatar
Joined Jul 2009
Yes it does look just like it except the handle is differrent. I'm back at work now so I cant test the 5V but I do remember 2 pins being shorter C3 and B4.
Richard
Old Jun 29, 2012, 02:04 PM
xandrios is offline
Steven
xandrios's Avatar
Joined May 2010
If so then either pin C3 or B4 will be the PS Kill pin.
Old Jun 29, 2012, 02:49 PM
Jeckler is offline
Find More Posts by Jeckler
Joined Jun 2012
Originally Posted by xandrios View Post
Next would be to connect a diode in parallel with output to prevent reverse voltage. The diode should be rated to at least the power supply rated output voltage and output current.
Thanks for the reply. I think at this point I'll just avoid adding or removing chargers with the supply powered up.
Jeckler is offline Find More Posts by Jeckler
Alert Need advice on high grade power supply for ISL-8 Byron Betterly Batteries and Chargers 7 Dec 07, 2003 08:31 PM
12volt, 9amp power supply for sale Paul Susbauer Aircraft - Electric - Airplanes (FS/W) 1 Dec 03, 2003 12:44 PM
12volt wallwart power supply reading 14.6 ? (help) power Batteries and Chargers 4 Sep 09, 2003 04:21 PM
Where to Get A Quality Power Supply? Joe Elston Batteries and Chargers 4 Apr 29, 2003 02:09 PM
High end charger and power supply for sale! Very new. ted616 Aircraft - Electric - Airplanes (FS/W) 6 Dec 02, 2002 11:31 PM
