Old May 02, 2012, 11:54 PM
rampman is online now
Find More Posts by rampman
Frankenstein recycled packs
rampman's Avatar
USA, AZ, Gilbert
Joined Jan 2006
IMO, pricey if not converted for rc use. In line if plug-n-play.
Rick
rampman is online now Find More Posts by rampman
Old May 05, 2012, 12:27 PM
Rodizio is offline
Find More Posts by Rodizio
Joined Mar 2012
Compaq/HP DS-SE2UP-AB silent Fan mod
Cool, now I've got a pretty decent power supply that's almost un-hearable.
Just get a silent 80mm fan (e.g. Arctic F8 Pro TC) and connect it to one of the
red and black wires that go to the DB-9 connector. The fan blows out so you
have to make sure that only the opposite side of the case is open to get good
airflow (I used shrinktube).
Unfortunately, the two holes at the backside do not fit for an 80mm fan, so
I used only one screw plus 2-component glue to secure the fan (I didnt't like
drilling because of the metal flakes ...).
See Post #1251 for instructions on howto make it run and more photos:
http://www.rcgroups.com/forums/showp...postcount=1251
Rodizio is offline Find More Posts by Rodizio
Old May 05, 2012, 03:13 PM
xandrios is offline
Find More Posts by xandrios
Steven
xandrios's Avatar
United States, CT, East Hartford
Joined May 2010
Hey Rodizio.
That's a nice setup.
And thank you for putting in the time and effort to get your PSU started.
Can you also post your instruction link (Post #1251) in this thread.
http://www.rcgroups.com/forums/showthread.php?t=1292514
Many people will find it useful.
xandrios is offline Find More Posts by xandrios
Old May 05, 2012, 07:14 PM
chriscap is offline
Find More Posts by chriscap
USA, CA, Los Angeles
Joined Jun 2010
Originally Posted by flarssen View Post
Same PSU? If so, I posted some info here: http://www.rcgroups.com/forums/showp...&postcount=731
Fred
I don't think it's the same. I'm talking about the NPS 700ab.
chriscap is offline Find More Posts by chriscap
Old May 05, 2012, 07:22 PM
Nelapaty is offline
Find More Posts by Nelapaty
KK4NZS
Nelapaty's Avatar
Virginia
Joined Sep 2006
Have you checked the how to convert a server psu thread..anyways is this what your looking for? this is dell NPS 700AB
http://www.tjinguytech.com/my-projects/server-ps
Nelapaty is offline Find More Posts by Nelapaty
Old May 05, 2012, 07:44 PM
chriscap is offline
Joined Jun 2010
I'm looking for a way of isolating the ground so I can run in series. I have seen that site and it appears that he has done it, but doesn't give any instructions on isolating the DC ground. He just isolates the AC ground. Not a huge fan of that as it's not as safe.
Old May 05, 2012, 08:51 PM
Nelapaty is offline
KK4NZS
Nelapaty's Avatar
Virginia
Joined Sep 2006
pm to kiloone seems like hes isolated the groundhttp://www.rcgroups.com/forums/showp...&postcount=444
Old May 07, 2012, 06:00 AM
Rodizio is offline
Joined Mar 2012
Fan airflow direction
Having converted some server PSUs now, I'm wondering about one thing.
Almost all of them have the fan 'pushing' air through the PSU case, is there
maybe a special reason for that?
Usually, as far as I know, 'sucking' the air through the case (i.e. blow out)
gives better results, and now I'm wondering if I shoud reverse the fan on my
DPS-600PB.
Has anybody tried that, or can give theoretical information on that topic?
Old May 07, 2012, 09:59 AM
rampman's Avatar
USA, AZ, Gilbert
Joined Jan 2006
The push through the case to also vent the main CPU case of the server. IMO, don't change it. You could be creating a hot spot if you do.
Rick
Old May 07, 2012, 01:19 PM
Rodizio is offline
Joined Mar 2012
Rick
No, actually with most 19" rack servers (atleast the ones I've seen) the airflow
through the case is from front to back. With the PSUs being at the back, they
receive air that has already been warmed up by the other components of the
server (CPU, mainboard, harddrives, etc.).
Old May 09, 2012, 02:40 AM
xandrios is offline
Steven
xandrios's Avatar
Joined May 2010
Astec/Emerson DS-2900-3, Sun ZFS Storage 7720 PSU (12V 240A) Full Pinout
Astec/Emerson DS-2900-3, Sun ZFS Storage 7720 PSU Full Pinout.
220V Input. 12V@240 2900W Output
The provided pin outputs are flipped versions of the other.
C6=C1 C2=C5 and so forth.
Test against ground and 3.3Vsb pins for correct pinout.
Connect Ps On and Ps Kill to ground to power up.
Old May 09, 2012, 09:36 AM
vnt17 is offline
Find More Posts by vnt17
Joined Apr 2012
hey xandrios,
i gave up on that FS011U psu.. no way to get it to run. so i went over to a poweredge 2800 (DELL 7000815-0000) psu wich starts and works well, got those "hurricane" fans quieter with the voltage divider method and now i would be happy to rise the voltage a bit. i get 12.05V without load. no pots inside. any suggestions? searched the whole thread but got no infos about that.
edit: drops to 11.99v unter 20Amp load
vnt17 is offline Find More Posts by vnt17
Old May 09, 2012, 05:03 PM
xandrios is offline
Steven
xandrios's Avatar
Joined May 2010
Hey vnt17.
The DELL 7000815-0000 PSU doesn't have external +V and -V sense lines so you can't adjust the main output voltage via the external pins.
The only way to kick up the main output voltage would be to connect pin A2(12v current share) to pin A4(3.3vsb).
That should give you a voltage boost to around 13.2v - 13.3v.
Old May 10, 2012, 12:43 AM
vnt17 is offline
Joined Apr 2012
is it possible to use that pin for voltage regulation AND fan control? or is there any other way to slow down the fans?
Old May 10, 2012, 04:14 AM
xandrios is offline
Steven
xandrios's Avatar
Joined May 2010
It may be possible to use the current share pin for double-duty,
but the desired results would be compromised.
You can simply short pin B2(fan control) to ground to slow the fans down.
Then connect pin A2 to A4 to get the voltage boost.
Alert Need advice on high grade power supply for ISL-8 Byron Betterly Batteries and Chargers 7 Dec 07, 2003 08:31 PM
12volt, 9amp power supply for sale Paul Susbauer Aircraft - Electric - Airplanes (FS/W) 1 Dec 03, 2003 12:44 PM
12volt wallwart power supply reading 14.6 ? (help) power Batteries and Chargers 4 Sep 09, 2003 04:21 PM
Where to Get A Quality Power Supply? Joe Elston Batteries and Chargers 4 Apr 29, 2003 02:09 PM
High end charger and power supply for sale! Very new. ted616 Aircraft - Electric - Airplanes (FS/W) 6 Dec 02, 2002 11:31 PM
