Go Back   RC Groups > Aircraft - General > Radios
This thread is privately moderated by foamflier84, who may elect to delete unwanted replies.
Old Apr 30, 2009, 10:13 AM   #31
Air, Land & Sea RC's.
Oblivion's Avatar
Send a message via ICQ to Oblivion Send a message via MSN to Oblivion
no free 6100's in australia.
they were even reluctant to check it out as "it affects very few radio's"
Oblivion is offline Find More Posts by Oblivion   Reply With Quote
Old May 08, 2009, 06:15 PM   #32
RC pilot,AMA Member.
sonicjet's Avatar
Got mine back,it came with the free AR6100,and an free hash browns box!
Thanks horizon!
sonicjet is offline Find More Posts by sonicjet   Reply With Quote
Old May 15, 2009, 09:11 AM   #33
Dub
DX6 receiver
Does anyone know if I can run the AR6200 by itself?,ie not connecting the satellite receiver
Dub is offline Find More Posts by Dub   Reply With Quote
Old May 15, 2009, 05:48 PM   #34
S.A.D. member
ivanc's Avatar
http://www.rcgroups.com/forums/showt...93#post9491393
BTW, the title of your post says "DX6 receiver". The DX6 receiver is AR6000. AR6200 comes with DX6i. Keep in mind that DX6 and AR6200 will not work together. DX6i and AR6200 will.
Ivan
ivanc is offline Find More Posts by ivanc   Reply With Quote
Old Jun 25, 2009, 08:38 PM   #35
hi guys my dx6i is one off the ones with dreaded recall codes. i have known nothin about the recalls til now. and have had no issues with mine at all until now.
my elevator has stopped working completely .
i already opened up my dx6i to replace a idle up switch and to remove the ratchet on throttle so do you think horizon will still stand by the radio?
i also noticed that the elevator potentiometre pot is very badly put in and has what looks like solder melt marks around. it was not done it me i might add
harryxtc is offline Find More Posts by harryxtc   Reply With Quote
Old Jun 25, 2009, 08:54 PM   #36
Prefectionist
Send a message via AIM to creapyd
you can try, they may, they may not honor the warrenty. Sounds like you have nothing to loose
creapyd is offline Find More Posts by creapyd   Reply With Quote
Old Jun 26, 2009, 11:18 PM   #37
Oblivion's Avatar
the manual actually mentions opening up the Tx to adjust tension on the sticks.
i prefer a slightly stiffer throttle stick to prevent it being bumped when im using the ailerons, and in Aus they honored my warranty, no probs
Old Jun 27, 2009, 07:16 PM   #38
thanks guys i got it sorted orizon hooby is picking it up at my front dor on monday and said there will be no problems with the warranty even though i have opened it up. so thanks to them judt hope they guy me one off those precious little 6100s as a consolation prize for having to do without my radio for a week... im looking for a t28 or corsair right now to plantit in if they give me 1
Old Sep 28, 2009, 02:32 PM   #39
foamie re-cycler
daddiozz's Avatar
...they gave me one of those "precious 6100's " as a consolation prize ..it sat around my shop for a couple of months before I installed it into something..a scratchbuilt sonicliner/xb70 clone...dang thing wont bind ,no lites,.. nothing. Power is apparently getting thru from the esc...it'l make 3 beeps when battery hooked up then nothing.Its like the rx isnt there at all.Hooked up a known good Rx to check the system ...all good .Put the rx in another "good" system/plane and and experienced same prob...thanks for nothing Spektrum.
I assume they fixed the radio from whatever prob it might have had ,but I don't know for sure.The radio they sent back to me wasn't the one I sent them.Not new...someone elses' apparently...the models programmed into the memory buffer weren't mine.. ...they did send it to my office rather than home as I requested though...so they at least got something right...
daddiozz is offline Find More Posts by daddiozz   Reply With Quote
Old Nov 04, 2009, 12:23 AM   #40
Quark, EP200V2se, E325se, mSR
mediclavina's Avatar
Horizon Hobby rocks!
I got my DX6i back from Horizon today. Wow, they included a free AR6110!
THANK YOU, HORIZON HOBBY!
mediclavina is offline Find More Posts by mediclavina   Reply With Quote
Spruce Goose 1:30 scale ncapener Scale Electric Planes 21 Sep 02, 2008 04:22 PM
Scale SA 1-30 1:5 96" span electric motorglider and towplane mmartin55 Scale Electric Planes 5 Jul 20, 2005 12:16 AM
Red CBP KANs 2/3A - $1.30 each - buy 100 cell PeterPan Aircraft - Electric - Airplanes (FS/W) 3 Apr 29, 2004 07:13 PM
fs: GMVis Commander Charger / Discharger 1-30 cells (nicad, nimh & li-ion / li-poly) Auger Aircraft - Electric - Airplanes (FS/W) 2 Jan 07, 2004 01:01 PM
CR123A non-rechargeable cells for $1.30 each asperkins Indoor and Micro Models 0 Jul 18, 2002 09:53 PM
Bored? Want to fight?
Join the RCGroups clan!
